Shelf Mounting Ventillation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-15-2002, 10:28 AM - Thread Starter
DVDer23's Avatar
Is there enough ventillation if you place your projector on a back wall on a shelf?
Thanks in advance.
DVDer23 is offline
post #2 of 3 Old 11-15-2002, 10:38 AM
Joseki's Avatar
That all depends on the projector. Obviously, if the air intake is on the back of the projector, you may want to rethink your solution. Likewise, the hot air must be able to exhaust from the projector case. Too little clearance could prevent the hot air from escaping from around the projector.
Projectors do not like overheating very much. I recommend that you verify the air intakes and exhausts before finalizing your mounting solution!
David
If one, jump two. If two, jump three.
Joseki is offline
post #3 of 3 Old 11-15-2002, 10:39 AM
rolast's Avatar
It will depend on the projector. Some exhaust from the front and have no problem being right up against a wall, others exhaust out the rear and require a foot or more rear clearance. Check manufacturer clearance requirements.
rolast is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
