Lens Filter For PJ - Look - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-09-2015, 09:08 AM - Thread Starter
afterlife2's Avatar
Quoted: 46 Post(s)
Liked: 31
Any one know if I can get a lens type filter for my Acer 5380 PJ for a longer throw so I can move my projector to the back of my room? As I move it back the screen gets bigger than I want. Is there such a lens? I hope you understand. Thanks!
afterlife2 is offline
post #2 of 5 Old 05-09-2015, 02:08 PM
airscapes's Avatar
Quoted: 165 Post(s)
Liked: 174
Yes, but they are about $1000
http://www.navitar.com/categories/sc...on-lenses.aspx
Doug
Planar PD8150 paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #3 of 5 Old 05-09-2015, 04:34 PM
Ftoast's Avatar
Quoted: 801 Post(s)
Liked: 303
I've seen videos of people using a $50-80 camera zoom lens to create a larger image from closer. I'd have to believe you could do the opposite with a similar workaround for a small amount of money.
Check around for something like a 2X telephoto lens (unless I'm a dunce and that's the opposite type of lens...I don't know words).
Simple <$250 dedicated black-fabric theater room, build in a day, takedown in an hour.
Easy $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Ftoast is online now
post #4 of 5 Old 05-10-2015, 06:21 AM - Thread Starter
afterlife2's Avatar
Quoted: 46 Post(s)
Liked: 31
Originally Posted by airscapes View Post
Thanks Air, Yikes. I guess when I upgrade in a couple of years I will get one with a long throw.
post #5 of 5 Old 05-10-2015, 12:12 PM
airscapes's Avatar
Quoted: 165 Post(s)
Liked: 174
Yes, just goes to show you how low quality the lenses in the projectors are these days.. New projector costs less than a quality lens. This is one of the ways they have lowered the prices, cheap plastic lenses.. high end stuff has better lenses..
Doug
