weird issue with lamp timer panasonic pt-vw440 - AVS | Home Theater Discussions And Reviews
post #1 of 6 Old 05-20-2015, 07:34 PM - Thread Starter
aae42's Avatar
Unhappy weird issue with lamp timer panasonic pt-vw440
we have 2x pt-vw440u in our auditorium, and one of them has a lamp run timer that's going crazy...
it says it has 18943 hours on it.... which is crazy (the other one is below 800 hours i think)
i took a screenshot of the status window for the web interface for it one at 9:25pm, and the lamp had 18852 hours on it, and again at 9:56pm the same night saying it has 18,943 hours on it.... so it's obviously messed up
it wouldn't bother me so much if we could manually reset it, but it seems that's not an option on this model...
also, to make matters worse, it shuts itself off after 10 minutes, i don't know why, i guess in attempt to protect itself?
any ideas on what to do here? i'd really hate to have to replace a bulb that has so few true hours on it
Name:	Screen Shot 2015-05-20 at 9.25.26 PM.png
ID:	728050   Click image for larger version
Name:	Screen Shot 2015-05-20 at 9.56.31 PM.png
aae42 is online now
post #2 of 6 Old 05-21-2015, 05:52 AM
jarrod1937's Avatar
Quoted: 50 Post(s)
Liked: 33
Very odd, I doubt it but if this unit is capable of firmware upgrades check if there is a new firmware. Otherwise, just go off of the projector runtime and make a note that the lamp needs replaced after runtime+lamp life hours.
jarrod1937 is online now
post #3 of 6 Old 05-21-2015, 07:21 AM
Mr.G's Avatar
Quoted: 256 Post(s)
Liked: 150
Originally Posted by aae42 View Post
we have 2x pt-vuw440u in our auditorium, and one of them has a lamp run timer that's going crazy...
According to the manual it states that the timer resets whenever the lamp is replaced with a new one. How it manages to detect the lamp is new is a mystery at least to me. So what I would do is follow the instructions for replacement of the lamp but re-insert the old lamp and see if it resets the timer.
There is obviously something wrong with the firmware and could be repaired at a dealer. Is it beyond the 2 year warranty?
Otherwise the PT-VUW440U could be replaced with the newer PT-VZ570U.
http://www.projectorpeople.com/Panas...rojector/33754
All I Really Need to Know I Learned in Movies
Mr.G is offline
post #4 of 6 Old 05-22-2015, 04:05 AM - Thread Starter
aae42's Avatar
and we would be fine with doing this if the thing wouldn't go into auto shutdown after 10 minutes...
i'm not sure if the firmware is update-able, but i was planning on looking into it...
i noticed this as well, i'm assuming there is a chip or some type of firmware on the lamp assembly itself... i was going to try exactly what you suggested, taking it out and putting it back in again in the hopes that it will re-seat and fix...
we were also going to try swapping the lamp with the other projector to see if the problems persist on that one...
just feels really crappy to replace a lamp with so few hours on it for what amounts to a programming error
sadly i believe this unit will be JUST out of the warranty.... we may still contact panasonic though, because this is ridiculous...
EDIT: if we were to replace the unit, it would probably be with the pt-vw530u, but i'm wholly unwilling to spend nearly $3000 (to make sure we match) for an issue this stupid
aae42 is online now
post #5 of 6 Old 05-22-2015, 05:11 AM
jarrod1937's Avatar
Quoted: 50 Post(s)
Liked: 33
They could be using an RFID chip, I've seen those used in printer cartridges, if so there should be a visible chip enclosure on the lamp. However, more than likely it's a simple microswitch that gets toggled when you pull the lamp out and add a new one back in.
post #6 of 6 Unread Today, 08:51 AM - Thread Starter
aae42's Avatar
just wanted to update this thread with the resolution... i send the unit in to panasonic service and they had it back to me within 5 days...
they updated the firmware and it fixed the issue.... it's non-user upgradable firmware...
aae42 is online now
