I'm almost all set to ceiling mount my pj, but something puzzles me. The bottom of the pj (manual link below) only has two screw holes near the front. There is a rubber gromit near the rear. Should I pry that off and see if there is a screw hole there? There are two additional screw holes on the rear of the machine, which seems a little odd to me. What would they be for?
The manual shows ceiling mounting on page 21 so I know it should be designed for it. Does my mount need to have a flap on the back for the two rear screw holes?
Any help would be appreciated, I really want to get this thing mounted this weekend!
http://tacpservice.toshiba.com/Consu.../LCD/x10ue.pdf
Anthony
Anthony
