Ben Q 1080st issues..... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-02-2015, 04:17 PM - Thread Starter
friggins's Avatar
Hi all, this has been my first and only projector. I bought it in January of 2014 and was amazed that such a picture could be had at such a low price. Recently the picture has degraded. Colors seemed washed out and contrast is all but gone. There is a halo around white words on a dark background etc.. The unit is in a light controlled room and the walls are blacked out around the screen. The bulb has 1500 hrs on it. I have attaced a few pics and any advice/comments would be greatly appreciated.
ID:	752353   Click image for larger version
ID:	752361   Click image for larger version
friggins is offline
post #2 of 4 Old 06-02-2015, 04:30 PM
kreeturez's Avatar
Quoted: 268 Post(s)
Liked: 253
That's an optical issue... Looks almost like your lens has smudges or the like on it? (Sounds obvious, but have you recently done anything lens-related: cleaned with an abrasive agent or something? Alternatively perhaps it needs a wipe? With just a damp spectacle-cleaning non-abrasive cloth?)
It's less likely but it's also possible something of the sort is elsewhere in the light path, though it's tough to tell from photos...
BenQ W1070 Projector; Xtreamer Ultra 2 (running XBMC on OpenELEC) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio. MediaBrowser3 for Mobile Streaming.
Helpful post? Click the 'Like' button!
kreeturez is offline
post #3 of 4 Old 06-02-2015, 04:58 PM - Thread Starter
friggins's Avatar
Wow. I feel like a complete fool. I have been through every menu....twice. I checked the lens and it looked fine but I never actually cleaned it. Well after cleaning it it looks a million times better. Thanks for the advice.
friggins is offline
post #4 of 4 Old 06-02-2015, 05:03 PM
kreeturez's Avatar
Quoted: 268 Post(s)
Liked: 253
Lol, no problem. Rather something as simple as that than anything more complex
Enjoy your revitalized image. And tell the Mrs/pets/kids/etc to keep their hands, feet and paws away from the lens in future!
Gear in this thread - 1080st by PriceGrabber.com
