Does using a projector at its maximum vertical shift affect image quality? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-10-2016, 05:58 PM - Thread Starter
Liked: 2
I want to keep the projector as close to the ceiling as possible. I was thinking of setting the vertical shift to its lowest possible setting, then adjust the pole vertically to align the image to the screen. Is this a bad idea?
Sony HW40es
10' ceilings
Peerless ceiling mount
ulyssis is offline
post #2 of 4 Old 01-10-2016, 06:07 PM
coderguy's Avatar
Quoted: 207 Post(s)
Liked: 235
It depends on the specific projector, you can try it and see for yourself. It shouldn't be too much of a difference.
Access HERE from this thread
OLD --- Coder's Top Projector Picks of 2012 --http://www.avsforum.com/avs-vb/showthread....
coderguy is offline
post #3 of 4 Old 01-10-2016, 06:10 PM - Thread Starter
Liked: 2
Sony HW40es?
ulyssis is offline
post #4 of 4 Old 01-11-2016, 06:04 PM
Legairre's Avatar
Quoted: 193 Post(s)
Liked: 139
Originally Posted by ulyssis View Post
Sony HW40es?
Based on these post it sounds like you don't want to be at the limits of lens shift if you want the best image quality. Owners thread Sony Hw55ES
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is online now
