LMP-H201 vs LMP-H202 Interchangeable? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-13-2016, 10:10 AM - Thread Starter
Liked: 0
Hi,
Is this lamp interchangeable? I'm seeing these listed together so i'm a little confused. I have the chance to buy a backup lamp, OEM, for very cheap but its the LMP-H201. It would be for PJ HW30ES. Anyone know?
thanks
Michael Medeiros is offline
post #2 of 3 Old 01-13-2016, 10:40 AM
Verge2's Avatar
Quoted: 493 Post(s)
Liked: 129
I wouldn't chance it. The 201 is cheap because it was for projectors from 8 years ago. I belive the wattage is different as well.
Verge2 is offline
post #3 of 3 Old 08-01-2016, 10:38 PM
ndabunka's Avatar
Quoted: 117 Post(s)
Liked: 32
I am trying to work through this myself as I picked up a used projector where it looks like the prior owner used the H201's in the HW50ES which actually calls for a H202. Having some issues with noise when using the sharpness setting so trying to understand if switching these out might fix the issue.
Found this on the BH Photo Q&A....
It H202 has a different current (0.8) I believe the HW40 had a H201 bulb assembly which was current of (1.0). I can not tell you what will happen if you tried, but I can tell you the housing is identical.
From time to time, the Gene Pool could use a little chlorine ...
ndabunka is offline
