DIY Sanyo Z1 Ceiling Mount $20 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #1 of 40 Old 03-03-2003, 05:29 PM - Thread Starter
BreakStuff's Avatar
First off I have to give all my credit to Monkey Man who's DIY mount gave me the idea for this project. I didn't feel the need for compression springs,so I just secured the the plastic with 4mm flange nuts..Total cost was just under twenty bucks :)
Parts list
(2) 1/2 Floor flange
(1) 1/2 X 10" Black steel pipe
(4) 1/4" X3/4" nut and bolt (machine)
(1) 1/4" plexi glass 9x13
(3) M6 X 50mm bolts
(9) M6 flange nuts
Monkey Man's DIY Ceiling mount
http://www.avsforum.com/avs-vb/showt...hreadid=232749
http://pdquickk.tripod.com/P1.jpg
http://pdquickk.tripod.com/P2.jpg
http://pdquickk.tripod.com/P3.jpg
Visit me at petedz.com
BreakStuff is offline
post #2 of 40 Old 03-08-2003, 11:23 AM - Thread Starter
BreakStuff's Avatar
Picture of mount w/ parts description...
http://home.nycap.rr.com/pdquickk/Parts.jpg
Update (6.14.03).. original incorrect M4 has been edited to the correct M6 size..sorry for the confusion..
Also a Flange nut is a nut manufactured with a washer attached to it, conventional nuts and washers will work just as good...
post #3 of 40 Old 04-10-2003, 08:17 AM
TSOLfan's Avatar
How did the M4's work for you? I picked some up, but I was left with a lot of room and they were quite loose when I tried to screw them into the projector.
I ended up picking up some M6's as I hauled the projector into Home Depot and tried them until I found one that was snug.
I've already finished the project with the M6, but I'm still curious about the M4's.
TSOLfan is offline
post #4 of 40 Old 05-25-2003, 08:03 PM
turbo1's Avatar
M4's don't work. Guess he should edit his parts list to (3) M6 X50MM bolts and (9) M6 nuts.
turbo1 is offline
post #5 of 40 Old 05-26-2003, 08:09 AM
hoops10's Avatar
Break,
Did you mount the top flange on the DIY mount directly to a floor joist? If not, what did you screw the top flange into?
hoops10 is offline
post #6 of 40 Old 05-26-2003, 06:35 PM - Thread Starter
BreakStuff's Avatar
Mounted directly to a joist in the ceiling..
I was lucky considering the support that runs across the ceiling is exactly 10' from my screen which is perfect for the Z1...
post #7 of 40 Old 05-26-2003, 06:57 PM
hoops10's Avatar
Break,
So assuming your floor joists are 2x10's, you mounted the top flange to the narrow side (2") of the 2x10? Do you think that would supply enough support? I ask because this is what I may have to do.
hoops10 is offline
post #8 of 40 Old 05-26-2003, 11:28 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
hoops, if you can get 2 screws dead center into the ceiling joist and use a couple of drywall expamding screws for any toher holes you will be plenty secure. Just use screws that will go through your mount then extend 1.5 inches or moor into the ceiling/joist.
lespurgeon is offline
post #9 of 40 Old 05-27-2003, 07:07 AM
hoops10's Avatar
Thanks for the tip. My ceiling is plaster so would that make a difference when using the drywall-expanding screws? It would be easy to find dead center on the joists with a studfinder, correct?
hoops10 is offline
post #10 of 40 Old 05-30-2003, 01:03 PM
turbo1's Avatar
I added a few minor upgrades to your mount Breakstuff.
http://zbestoftheweb.com/CARS/PJ.jpg
turbo1 is offline
post #11 of 40 Old 05-30-2003, 06:44 PM
TreyCarr's Avatar
That is the exact same set up I have.. Except i used particle board where he used plastic.. GOOD Job..
What was once tame is now wild.
TreyCarr is offline
post #12 of 40 Old 05-30-2003, 06:53 PM
hoops10's Avatar
turbo, do you just have the flange screwed into a 2x10 (joist)? Also, what is that black cable coming off of the pj?
hoops10 is offline
post #13 of 40 Old 05-30-2003, 10:33 PM
turbo1's Avatar
hoops10,
Oh, I have an 18" pipe by the way, 10" would shine the picture into the path of my ceiling fan. I have 2 wood screws in the flange going into the joist. I mounted it last week but was rainy so I saved painting for this week. Took out wood screws and found out only 1 of the 2 were actually in the beam. That black cable is the new fiber optical digital video cable. I get res up to 3200X2400.
http://www.raceworx.com/funnypics/wh...the%20hell.jpg
Ok, so its not fiber digital video cable. I have conduit around the power, rgb, component, and rca cables. Makes everthing looks neat and tidy.
turbo1 is offline
post #14 of 40 Old 06-12-2003, 02:46 AM
jimmyz's Avatar
Just curious, where did you pick up that conduit? Is it something home depot or lowes would have?
jimmyz is offline
post #15 of 40 Old 06-12-2003, 09:32 AM
hoops10's Avatar
A question about using plexiglass. I know that the Z1 has an exaust output on the bottom of the pj. If the pj sits right on the plexiglass, wouldn't this block the vent? Does this matter?
hoops10 is offline
post #16 of 40 Old 06-12-2003, 10:43 AM
Tannehill's Avatar
Even if the fan WAS too close to the plexiglas, I suppose you could drill a few air holes to help dissipate the heat.
Tannehill is offline
post #17 of 40 Old 06-14-2003, 07:25 PM
turbo1's Avatar
I got mine at Home Depot. Someone told me CompUSA has it as well but I didn't check on it.
turbo1 is offline
post #18 of 40 Old 06-14-2003, 07:34 PM
turbo1's Avatar
The setup I have has 2 inches from the Plexiglas just like Breakstuff's so the exhaust is fine. It's not possible to block the vent because even if the Plexiglas was touching the PJ rubber stoppers on the bottom it would be equivalent to the PJ sitting on a table and the wood that the PJ sits on when it is table mounted doesn't block it either.
Originally posted by hoops10
A question about using Plexiglas. I know that the Z1 has an exhaust output on the bottom of the pj. If the pj sits right on the Plexiglas, wouldn't this block the vent? Does this matter?
turbo1 is offline
post #19 of 40 Old 06-14-2003, 09:28 PM - Thread Starter
BreakStuff's Avatar
I edited this thread to the correct bolt/nut sizes which should be 6mm as Turbo mentioned.. You would figure a 14 year auto tech should know the difference, my bad! :p
post #20 of 40 Old 07-01-2003, 09:32 AM
z1fan's Avatar
Breakstuff
yours is great, I am gonna built one too, where did you get these M6 flange nuts? I coun't find any of theses in Homedepot or lowes.
z1fan is offline
post #21 of 40 Old 07-04-2003, 11:32 AM
turbo1's Avatar
Try local auto parts store or hardware store.
turbo1 is offline
post #22 of 40 Old 07-05-2003, 06:56 PM
paul.n3w's Avatar
Breakstuff, thank you very much for this post! This is going to come in handy when I order my 1HD (very soon I hope :)) Thanks!
paul.n3w is offline
post #23 of 40 Old 07-12-2003, 03:52 PM
Chris Otto's Avatar
Flange nuts will be easier to find at an auto parts store than just about anywhere else.
EDIT: Guess I should have kept reading the rest of the thread first. :/
Chris Otto is offline
post #24 of 40 Old 10-07-2003, 01:36 AM
orbitalpunk's Avatar
do i need to ground the projector when using this kind of mount system?
orbitalpunk is offline
post #25 of 40 Old 10-16-2003, 09:13 AM
mickeyGoUp's Avatar
This might be a simple question to handy people, but I am so new to all these DIY and home improvement stuffs, I would really like to get some guidelines from you experts.
How do I connect the floor flange and the steel pipe? Do I use some kind of glue?
Any help will be greatly appreciated. Thanks in advance!
Mickey
mickeyGoUp is offline
post #26 of 40 Old 10-16-2003, 10:16 AM
miketc's Avatar
Orbital, Your pj is grounded thru. the AC plug.
mickey, Metal pipes and floor flange are threaded while PVC pipes and floor flange are usually glue together but they could be threaded as well. I just started a thread where I use metal electrical conduit which is less weigh than metal plumbing pipes and more strength than PVC.
Hope this help.
MIKeTC
miketc is offline
post #27 of 40 Old 10-16-2003, 07:03 PM - Thread Starter
BreakStuff's Avatar
Hi mickeyGoUp -
On my particular mount, the PVC pipe was threaded and easily attached by screwing the pipe into the floor flange...
post #28 of 40 Old 03-04-2004, 09:03 PM
chuckvb's Avatar
Given the frequent cleaning the Z2 needs I wonder how the removal could be made easier
chuckvb is offline
post #29 of 40 Old 03-04-2004, 09:51 PM
Legairre's Avatar
Quoted: 470 Post(s)
Liked: 270
I made my mount with the board cut an odd shape that didn't cover the filter. That way I could remove the filter without taking down the Z2. There's pics on my site. Look under the "Equipment" menu then go to "Projector".
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is online now
post #30 of 40 Old 03-04-2004, 10:20 PM
chinch's Avatar
good ideas here.
would it be easiest to use one board with four M6 bolts with nuts affixed to the projector (ie. making four posts) with 4 more nuts/washers on top of the board which lets the PJ hang from the "posts" while being able to adjust it from the top with an open ended wrench?
finally does anyone know the thread size for a Z2 and where online you might be able to order 2-3" long "m6" bolts?
DVD's are about movies & people watch them in living rooms, how many people actually use their computer drives to sit and watch movies- Bluray's Andy Parsons
chinch is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
