Has anyone used the Monster cable htps7000 with their pj? - AVS Forum | Home Theater Discussions And Reviews
Old 03-17-2003, 04:46 AM - Thread Starter
Ingeborgdot's Avatar
Quoted: 145 Post(s)
Liked: 27
What did you notice with the 7000? Did it make a big difference or was it all hype? I have a dealer that says I can use it for a while and if it doesn't he will take it back no questions asked.
Ingeborgdot is offline
Old 03-17-2003, 03:49 PM
Andrew_Ballew's Avatar
I never really noticed the improvements with video. But, my system had a much lower noise floor audio-wise on the 7000 than it does now running on a 3500.
Andrew B.
Andrew_Ballew is offline
