Noob here - Looking for short throw options - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-26-2016, 09:08 PM - Thread Starter
Liked: 0
Question Noob here - Looking for short throw options
My current setup is with a 110" screen and my projector is hanging about 1ft down from the ceiling at 15' away from the screen. I would really like to get a projector that can sit on the floor in front of the screen. The reason for this is that the room is long and narrow, but the ceilings are fairly short. I would really like to be able to setup better seating (maybe stadium?) in the room without worrying about casting shadows on the screen whenever someone sits up or whatever.
Are there projectors out there that can sit within 3-4ft of a 110" screen and project 1080p @ 60FPS?
fubak is offline
post #2 of 5 Old 06-26-2016, 09:23 PM
Quoted: 47 Post(s)
The best one seems to be LG PF1000u.
I havent seen one in person, but it gets good reviews.
Krob3 is offline
post #3 of 5 Old 06-27-2016, 06:54 AM
Dave in Green's Avatar
Quoted: 1283 Post(s)
Liked: 853
Short throw 1080p projector selection is limited. Optoma GT1080 will do 110" from 4', but it's primarily designed for gaming and not the most accurate for movies. BenQ HT1085ST is generally considered the best of the short throw projectors for movies, but needs minimum 5' 6" throw to hit 110".
Dave in Green is offline
post #4 of 5 Old 06-27-2016, 08:22 AM
AV_Integrated's Avatar
Quoted: 972 Post(s)
Liked: 718
The BenQ 1080/1085ST models are the best out there right now. Using a RGB/RGB color wheel you will get a very good image. The LG is nice, but it is a short throw version of the PF1500U, which is well reviewed, but suffers from some LED issues, most notably it is not terribly bright in comparison to the 1080ST series. About half or less the brightness. It is a ultra short throw, which is pretty cool with the PF1000, but I'm not sure I would trade that for the brightness, especially in a permanent home theater situation.
At 5-6 feet of throw distance, it should be well in front of the seated audience and placement is with the center of the lens right near the top of the screen, so it should be out of the way and work nicely with your lower ceilings just fine.
I installed one a year or so ago in front of a soffit for a client and it worked very well.
Make sure you have a very flat screen. Any waves in the screen material will significantly distort the image.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #5 of 5 Old 06-28-2016, 06:47 PM - Thread Starter
Liked: 0
Thanks for the advice all. I'm currently looking at the BenQ HT1085ST as my replacement projector. The current projector is a Optoma H79, which has half the lumens (1,000) and is only 720p. The only advantage that I would lose with the upgrade would be loss of a powered lens focus and the new projector is about 8dB louder. I just want to make sure I'm making the right move here...
fubak is offline
short throw
