Panasonic PT-AE900U/720p projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-26-2016, 08:07 AM - Thread Starter
Liked: 0
Someone is offering to sell me a Panasonic PT-AE900U with a brand new bulb for 300 CAD (227 USD). I've never owned a projector and I was wondering if this was a decent deal. It will be going in my basement (where getting the lighting down to pitch black is not difficult) and I want to use a 90"-110" screen. Does 1080 vs 720 make a huge difference when it comes to projectors? I know it's a fairly subjective question but I just have no idea if I will be happy with picture quality.
Any info is appreciated.
thehypnotoad88 is offline
post #2 of 4 Old 07-26-2016, 10:36 AM
bud16415's Avatar
Quoted: 806 Post(s)
Liked: 301
I think the price is high even with a new lamp for a used 720p projector. I bought a new projector last year with a 3 year warranty and one year on the bulb that was WXGA roughly 720P resolution for 365 USD for around 300 USD I think you can buy the same projector as a new factory refurb now. with warranty.
720 P resolution is fine and I love the image on mine and I sit about 2X screen height away. If you are on a budget and don’t want to get up in the 600-800 USD range for a 1080P you will enjoy a 720P every bit as much for a first projector.
Bud
bud16415 is offline
post #3 of 4 Old 07-26-2016, 02:35 PM
rekbones's Avatar
Quoted: 408 Post(s)
Liked: 198
If the replacement lamp is a genuine Panasonic OEM replacement lamp and the projector has no other issues like burnt optics, panel aliment issues or dust blobs then its a good buy. That's a lot of ifs so unless this is a very trusted seller that will let you see it in operation before you buy or refund your money if it has any issues then steer clear.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
post #4 of 4 Old 07-26-2016, 04:06 PM
Dave in Green's Avatar
Quoted: 1346 Post(s)
Liked: 895
The PT-AE900U was a fairly high range projector when introduced and has lots of features today's cheaper 720p projectors lack, such as 2:1 zoom and vertical and horizontal lens shift. But it's also fairly dim by today's standards. It all depends on whether you need a lot of zoom and lens shift for your application or if you would prefer a brighter image.
Dave in Green is offline
