Official Epson 5040ub/6040ub owners thread - Page 301 - AVS Forum | Home Theater Discussions And Reviews
 8402Likes
post #9001 of 10437 Old 06-19-2017, 08:19 PM
hnupe's Avatar
Quoted: 22 Post(s)
Originally Posted by gene4ht View Post
Although Epson utilizes both methods, the current 5040 FW update (1.09/1.04) appears to be USB only.
https://epson.com/Support/wa00805
Can anyone tell what the firmware does?
hnupe is offline
post #9002 of 10437 Old 06-20-2017, 10:02 AM
impetigo's Avatar
Quoted: 118 Post(s)
Liked: 55
Originally Posted by gnolivos View Post
Just move it well away from your final intended position. Then move the image in ONE direction only vertically. And then in ONE direction horizontally. Make sure more than 10 clicks are needed. Done.
So I redid all my lens shift memory last night and so far it does seem that it is more accurate now. For the "10 clicks" part, does it actually have to be 10 or more consecutive individual clicks up to the final click, or can you hold down the direction to get close to the desired spot then just click a few times to get to the exact spot you want? Just to be safe I ended up clicking individually.
Also, does this rule of thumb/guideline also include zoom and focus? That is, when setting up a particular lens shift memory that requires zooming in or out, that you do it only in one "direction" (i.e. not overshoot and then go in the opposite direction to fine tune)? The same thing with focus. It's harder follow the rule of thumb with both focus and zoom I feel because the focus is so subtle and the zoom is so slow if you use individual clicks rather than hold down.
Furthermore, does the focus get saved with lens position memory? Zoom has to of course but not sure if focus does as well, although it obviously should as well as zooming in/out can affect the fine focus.
impetigo is offline
post #9003 of 10437 Old 06-20-2017, 10:13 AM
Oledurt's Avatar
Quoted: 382 Post(s)
Liked: 427
Sorry to crash the party but here are my settings for HDR in their entirety...Enjoy.
Bright Cinema Mode. HDR 1 Auto Bright
Brightness = 50
Contrast = 49
Color Saturation = 50
Tint = 50
Color Temp = 4
Skin Tone = 4
Offset R = 50
Offser G = 50
Offset B = 51
Gain R = 50
Gain G = 50
Gain B = 43
Power Consumption = Medium
RGBCMY
R 53,50,50
G 40,94,27
B 61,49,47
C 59,46,44
M 62,50,50
Y 37,50,48
Auto Iris = Off
Epson Super White = Off
Lens Iris = 0
Gamma (left to right). 0,1,7,13,22,29,29,14,0
Your welcome...
Oledurt is online now
post #9004 of 10437 Old 06-20-2017, 11:30 AM
robc1976's Avatar
Quoted: 419 Post(s)
Liked: 217
Brightness = 50
Contrast = 49
Tint = 50
Color Temp = 4
Skin Tone = 4
Offset R = 50
Offser G = 50
Offset B = 51
Gain R = 50
Gain G = 50
Gain B = 43
RGBCMY
R 53,50,50
G 40,94,27
B 61,49,47
C 59,46,44
M 62,50,50
Y 37,50,48
Auto Iris = Off
Lens Iris = 0
Your welcome...
sorry??? NO!. Thankv you for taking the time to do this.
RF7II Fronts & Wides RC64II Center RB61II Heights & Surround back RF7II surrounds 2X Elemental design 15" subs Denon X7200WA 2X Emotiva XPA-5 epson 5040ub & 158" screen panny UD900 Full GIK treatments
robc1976 is offline
post #9005 of 10437 Old 06-20-2017, 11:36 AM
robc1976's Avatar
Quoted: 419 Post(s)
Liked: 217
Can someone chime in here? On xbox 1s I have the following options
Color depth
24 bits per pixel 8 bit
30 bits per pixel 10 bit
36 bits per pixel 12 bit
I am guessing 8 bit since projector can only support max of 10 bit I believe.
robc1976 is offline
post #9006 of 10437 Old 06-20-2017, 11:44 AM
robc1976's Avatar
Quoted: 419 Post(s)
Liked: 217
Originally Posted by Dave Harper View Post
@tuckerpc389 , Have you tried my HarperVision HDR on SDR settings for HDR content? It helps with the darkness you mentioned but maintains the wide color gamut filter.
The link with settings is just below my signature here.
Dave, do you have epson super white on or off?
robc1976 is offline
post #9007 of 10437 Old 06-20-2017, 11:58 AM
aka: HarperVision
Dave Harper's Avatar
Quoted: 1480 Post(s)
Liked: 682
Brightness = 50
Contrast = 49
Tint = 50
Color Temp = 4
Skin Tone = 4
Offset R = 50
Offser G = 50
Offset B = 51
Gain R = 50
Gain G = 50
Gain B = 43
RGBCMY
R 53,50,50
G 40,94,27
B 61,49,47
C 59,46,44
M 62,50,50
Y 37,50,48
Auto Iris = Off
Lens Iris = 0
Your welcome...
Exactly! Your curves and settings have been awesome Oledurt! I just wish I sill had the 5040 here to check them out.
OFF
Dave Harper is offline
post #9008 of 10437 Old 06-20-2017, 01:04 PM
robc1976's Avatar
Quoted: 419 Post(s)
Liked: 217
OFF
oh man, he has it on, should I leave it off? Will that hurt the calibration?
Edit: its off
robc1976 is offline
post #9009 of 10437 Old 06-20-2017, 02:33 PM
panman40's Avatar
Quoted: 205 Post(s)
Liked: 101
Edit: its off
Most calibrators I have spoken to leave superwhite ON, I do myself for rec709 but and 3D, when it comes to UHD/HDR though Its Off.
Dave Harper likes this.
panman40 is offline
post #9010 of 10437 Old 06-20-2017, 03:47 PM
robc1976's Avatar
Quoted: 419 Post(s)
Liked: 217
[QUOTE=panman40;53770281]Most calibrators I have spoken to leave superwhite ON, I do myself for rec709 but and 3D, when it comes to UHD/HDR though I pits Off.[bQUOTE]exactly what he did, you may be able to tell me this why is it suggested to turn off YCC in xbox 1s again?. something about better color?
robc1976 is offline
post #9011 of 10437 Old 06-20-2017, 04:29 PM
john barlow's Avatar
Quoted: 106 Post(s)
Liked: 153
Brightness = 50
Contrast = 49
Tint = 50
Color Temp = 4
Skin Tone = 4
Offset R = 50
Offser G = 50
Offset B = 51
Gain R = 50
Gain G = 50
Gain B = 43
RGBCMY
R 53,50,50
G 40,94,27
B 61,49,47
C 59,46,44
M 62,50,50
Y 37,50,48
Auto Iris = Off
Lens Iris = 0
Your welcome...
Thanks, I'm going to try your settings after I finally install the firmware upgrade. I was hoping one of the more astute owners here would be able to flesh out what improvements I can expect. It would be nice to know what to look for with the firmware. The only thing I remember is someone said if you set HDR to auto that info screen will show HDR mode 1. That's great but, is that all that they added with this update?
john barlow is offline
post #9012 of 10437 Old 06-20-2017, 05:00 PM
DavidHir's Avatar
Quoted: 1996 Post(s)
Liked: 1636
Does the 5040 have a manual iris? I am considering one, but the manual seems to indicate only the 6040 has it. It's something I will need in my set-up.
Name:	5040 manual.png
DavidHir is online now
post #9013 of 10437 Old 06-20-2017, 06:44 PM
robc1976's Avatar
Quoted: 419 Post(s)
Liked: 217
OFF
Dave, maybe your will no answer to this,
I have these choices, default is 8bit
Color depth
robc1976 is offline
post #9014 of 10437 Old 06-20-2017, 07:27 PM
ac388's Avatar
Quoted: 117 Post(s)
Liked: 39
Thanks. Will definitely try it out this weekend.
Brightness = 50
Contrast = 49
Tint = 50
Color Temp = 4
Skin Tone = 4
Offset R = 50
Offser G = 50
Offset B = 51
Gain R = 50
Gain G = 50
Gain B = 43
RGBCMY
R 53,50,50
G 40,94,27
B 61,49,47
C 59,46,44
M 62,50,50
Y 37,50,48
Auto Iris = Off
Lens Iris = 0
Your welcome...
Man see things as they are n say why. I dream of things that never were, n say why not ....... A Perfect PROJECTOR
ac388 is offline
post #9015 of 10437 Old 06-20-2017, 08:06 PM
hnupe's Avatar
Quoted: 22 Post(s)
Silly HDR Question
When people refer to HDR Setting is that a reference to playing 4K movies or for regular TV like DIRECTV?
hnupe is offline
post #9016 of 10437 Old 06-20-2017, 08:17 PM
ac388's Avatar
Quoted: 117 Post(s)
Liked: 39
That's a setting on your TV or projector for playing back 4K HDR discs or files or even other media suppliers ,like Netflix etc.. But those you found in this link are only for 5040/6040.
ac388 is offline
post #9017 of 10437 Old 06-20-2017, 08:24 PM
robc1976's Avatar
Quoted: 419 Post(s)
Liked: 217
Brightness = 50
Contrast = 49
Tint = 50
Color Temp = 4
Skin Tone = 4
Offset R = 50
Offser G = 50
Offset B = 51
Gain R = 50
Gain G = 50
Gain B = 43
RGBCMY
R 53,50,50
G 40,94,27
B 61,49,47
C 59,46,44
M 62,50,50
Y 37,50,48
Auto Iris = Off
Lens Iris = 0
Your welcome...
question, it says HDR1 auto bright, I can only choose one or the other auto bright or HDR1. Wich do I choose?
robc1976 is offline
post #9018 of 10437 Old 06-20-2017, 08:26 PM
Oledurt's Avatar
Quoted: 382 Post(s)
Liked: 427
They are the same just use auto bright
post #9019 of 10437 Old 06-20-2017, 08:35 PM
robc1976's Avatar
Quoted: 419 Post(s)
Liked: 217
just to be sure, this is in signal menu, then under "dynamic range" setting correct?
robc1976 is offline
post #9020 of 10437 Old 06-20-2017, 08:36 PM
Oledurt's Avatar
Quoted: 382 Post(s)
Liked: 427
yep
post #9021 of 10437 Old 06-20-2017, 08:52 PM
gene4ht's Avatar
Quoted: 990 Post(s)
Liked: 1024
AFAIK there is no...nor have I seen...formal/official Epson FW update logs or any 1.09/1.04 descriptive information for the 5040/6040. Like @john barlow indicated, my understanding is also limited to anecdotal information I gleened from these threads basically saying that HDR Auto will default to HDR mode 1 instead of HDR mode 2 when HDR content is detected...presumably to improve brightness.
Epson: 5040UB | Elite: 115" Fixed Frame CinemaScope (2.35:1) | Onkyo: TX-NR636 (5.2.2) | Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6 | SVS: PB16-Ultra x 2 | Philips: BDP7501, Panasonic: DMP UB900, Oppo: UDP-203
gene4ht is offline
post #9022 of 10437 Old 06-20-2017, 10:24 PM
panman40's Avatar
Quoted: 205 Post(s)
Liked: 101
[quote=robc1976;53771849]
Really sorry I don't know anything about the Xbox or gaming consoles as Im not really into gaming
panman40 is offline
post #9023 of 10437 Old 06-20-2017, 10:55 PM
aka: HarperVision
Liked: 682
Color depth
Well if the max is 10 bit, then use 10 bit. It is more dependent on the total bandwidth than any one setting like the bit depth. For example, it may work fine with 4K 24p 4:2:0 BT2020 HDR 10 bit, but if you go to 60p or 4:2:2, then it could be too much and you would have to drop down to 8 bit for it to work. Here's a chart that shows the bandwidth limits and what can be sent with them:
post #9024 of 10437 Old 06-21-2017, 10:41 AM
robc1976's Avatar
Quoted: 419 Post(s)
Liked: 217
awesome Dave!
Also when you adjust focus is that saved to the memory of thatc selection?. I would think it is because when honingl going from 240.1 to 16:9 there is a lot of zooming involved that would interfere with focusing.
robc1976 is offline
post #9025 of 10437 Old 06-21-2017, 12:01 PM
aka: HarperVision
Liked: 682
I don't think it is actually
post #9026 of 10437 Old 06-21-2017, 12:07 PM
jaychatbonneau's Avatar
Quoted: 177 Post(s)
Liked: 48
Is the lens on the 5040ub relatively flat and large? Also, how would you rate its 3D performance? Is there much flicker? I want to buy one but I live in China and the people at the home theater market will not even take one out of a box, let alone demo it.
jaychatbonneau is offline
post #9027 of 10437 Old 06-21-2017, 04:36 PM
Jameshtx's Avatar
Quoted: 70 Post(s)
Liked: 8
Hey everyone
Just curious what you got your settings at for blu ray movies since Harpervision is for movies in 4k uhd?? All comments and feedback are absolutely welcomed
James fr Houston Tx
Jameshtx is offline
post #9028 of 10437 Old 06-21-2017, 04:51 PM
Jameshtx's Avatar
Quoted: 70 Post(s)
Liked: 8
Brightness = 50
Contrast = 49
Tint = 50
Color Temp = 4
Skin Tone = 4
Offset R = 50
Offser G = 50
Offset B = 51
Gain R = 50
Gain G = 50
Gain B = 43
RGBCMY
R 53,50,50
G 40,94,27
B 61,49,47
C 59,46,44
M 62,50,50
Y 37,50,48
Auto Iris = Off
Lens Iris = 0
Your welcome...
Oledurt,
Can these settings be used for blu ray and 4k movies with hdr? Does anyone else know? thanks
Jameshtx is offline
post #9029 of 10437 Old 06-21-2017, 04:53 PM
Oledurt's Avatar
Quoted: 382 Post(s)
Liked: 427
Originally Posted by Jameshtx View Post
Oledurt,
These are my settings for 4k UHD discs.
hnupe likes this.
post #9030 of 10437 Old 06-21-2017, 06:00 PM
Just Another Member
ht guy's Avatar
Quoted: 94 Post(s)
Liked: 69
Bright Cinema...
...to right). 0,1,7,13,22,29,29,14,0
Your welcome...
Wow. Fantastic.
Thank-you!
ht guy is offline
atmos
