Will component to vga cable work for Davis 650? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-25-2003, 10:02 AM - Thread Starter
skilzygw's Avatar
Will this cable work from the xbox to the davis 650?
http://www.pccables.com/cgi-bin/ord...48&partno=02803
Andhow exactly do you connect this to the xbox? The hi def pack only has 3 component outputs and the cable shows 5? how does it physically get connected? thanks!
skilzygw is offline
post #2 of 2 Old 05-25-2003, 10:33 AM
mikejz84's Avatar
No, you will need a transcoder
Going to BB means rubbing elbows w/ the Unwashed Masses
No thanks
Netflix for me!
mikejz84 is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
