Hi, I have Mitsubishi HC4900, and after many years of use, the projector would not turn on. It gives a sort of soft clicking noise when I try to turn it on. Obviously, it does not turn on. I tried trouble shooting, and according to the lights on "Power" & "Status", it seems I have to change the bulb. The bulb inside does not seem to be blown (filament is intact).
So, my question is... is it necessary to change the bulb? And, if so, where can i buy a good bulb? There seems to be all sorts of bulbs and I see that many more expensive bulbs do not have any reviews; and the cheap ones have similar reviews...
