Optoma UHD60 & UHD65 4K/UHD HDR DLP Projectors Now Available - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 855Likes
post #61 of 1934 Old 06-06-2017, 08:45 AM
Nexgen76's Avatar
Quoted: 513 Post(s)
Liked: 128
Okay I guess the only issue is BT2020 vs Rec 709. But I heard something very interesting from the sales rep Vivtek new 4K projector which is kinda the same as Optoma 4K PJ. He said they didn't feel it was necessary to have BT2020 because you need at leasing 8000 lumens to display it correctly. That really has me thinking.
Sent from my SAMSUNG-SM-N900A using Tapatalk
JVC DLA-RS400U
Sliver Ticket 120' Cinema white screen
Aggressive 1299 L/C/R/, Volt 10XL x 2 surround, MKII Atmos Modules x 4(Jav's build)
Denon AVRX6200W /Acurus A125x5
Panasonic DMP-UB900 4K UHD Player
Ported Primate SI 18" HST subs x 2(DIY) V.B.S.S.x 4(MBM)
Nexgen76 is offline
post #62 of 1934 Old 06-06-2017, 08:57 AM
Frank714's Avatar
Quoted: 696 Post(s)
Liked: 281
Originally Posted by JRock3x8 View Post
the trick is how far down would I have to hang the projector to get the image to land right?
The rule of thumb remains that the horizontal level of the (ceiling mounted) projector lens is above the top edge of your image on your screen surface. How much the projector has to hang above the top edge of your image is determined by the distance between the UHD 65 and the screen, please check the user manual on pages 50 and 51 for details.
At a projection distance of 17' the lens level has to be approx. 0.7 (screen diagonal around 110") - 1 foot (screen diagonal around 170') higher than the top edge of your screen surface, ultimately depending on the size of your screen.
The key in understanding how an Optoma lens works is to remember that usually an Optoma hangs much higher on the opposite side of the room than the top edge of the screen. Optoma has understood that this doesn't work in most home theater environments, the 'lens shift' (remember the Sharp DLP projectors where lens shift did mean "lens shift"?) in their case is mostly to correct this terrible "offset", i.e. to enable the user to bring the projector down and closer to the top of the screen.
"It is only about things that do not interest one that one can give a really unbiased opinion, which is no doubt the reason why an unbiased opinion is always absolutely valueless." Oscar Wilde
Frank714 is offline
post #63 of 1934 Old 06-06-2017, 09:05 AM
JRock3x8's Avatar
Quoted: 770 Post(s)
Liked: 199
that's very interesting because my Benq 1070 - the lens is more or less at the top of the screen and I have to do a fair amount of keystone adjustment (push the image down) just to make it right.
Sounds like I might actually need the vertical shift to push the image up instead of down.
edit : my screen is 144 x 60 (homemade with spandex) and is about 9" - 12" from the ceiling. PJ is probably 4" - 6" from ceiling? I have the cheapie videosecu mount from amazon
JRock3x8 is offline
post #64 of 1934 Old 06-06-2017, 09:11 AM
Verge2's Avatar
Quoted: 796 Post(s)
Liked: 204
AFAIK import tax in Germany for consumer electronic products is 0%, but a VAT of 19% is imposed on all products which I already considered / subtracted, so my question remains.
Or Optoma USA is anticipating the implementation of the new import taxes the 45th president has announced. So eventually we'll all pay the same price.
You certain, there's 400 euros of cost somewhere in the chain.
Verge2 is offline
post #65 of 1934 Old 06-06-2017, 09:27 AM
JeffR1's Avatar
Quoted: 748 Post(s)
Liked: 263
If it does the same good job as his predecessor HD 83(00) did with DVDs and BDs now with UHD BDs I'm not worried one bit.
Had a chance to test the FI performance of a JVC DLA-X35 and was rather underwhelmed, none of the Clear Motion Drive settings got close to the performance of the Optoma HD 83 and its siblings up to the HD 50, I think I understood for the first time why there is talk of haloes and artifacts (in contrast the latest JVC DLA-X5500 delivers a good FI performance that's almost indistinguishable from the PureMotion FI performance I've seen with Optomas).
Go to the parachute scene in the movie "kingsman: The Secret Service" and see what happens there with your HD83, see if that scene stays together.
I haven't come across one FI algorithm that can handle that scene.
Also, "The Shawshank Redemption"
Near the end after Morgan Freeman is dropped off in front of a corn field, see how much halo effect there is here.
It's an FI nightmare for any algorithm.
Of all the FI systems I've dealt with, my Sony 300es works best, my old Panny 4000 takes second place _ DmitriRender does OK too and takes 3rd.
None however is perfect, it's a very difficult scene to handle and it makes a good test.
JeffR1 is offline
post #66 of 1934 Old 06-06-2017, 09:59 AM
Frank714's Avatar
Quoted: 696 Post(s)
Liked: 281
Didn't we talk about that a long time ago? I don't remember seeing that much or severe halo effects there. As it turned out it's rather slow scenes that appear to constitute a problem for FI.
2001 example: The scene where Dr. Floyd has arrived in the outer ring of Space Station V and the elevator doors open, both the outside and inside of the white elevator cabin are covered with sheets of tiny square inlets:
Optoma (HD 83/ HD 50): Only one panel behind the Stewardess sitting there with Dr. Floyd wobbles
JVC DLA-X35: Several Panels wooble
JVC DLA-X5500: There are shortly large and blank triangles on the outer cabin
Other than that both Optoma's PureMotion or JVC's Clear Motion Drive (on the X5500) perform rather nicely and almost halo- and artifact-free. If you see characters in House of Cards moving against each other there are sometimes tiny areas of "digital confusion" next to the characters with PureMotion while C.M.D. has the tendency to feature tiny vertical ghost images trailing the characters.
But those are rather exceptions than general observations.
Another great image test are the rolling screen credits at the end of each House of cards episode, PureMotion rolls these smoothly without any apparent problems, the X5500 sometimes has to catch up (refresh).
Frank714 is offline
post #67 of 1934 Old 06-06-2017, 11:19 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 4145 Post(s)
Liked: 4229
You never want to use keystone adjustment. Not good for picture quality. Just FYI.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #68 of 1934 Old 06-06-2017, 11:20 AM
JRock3x8's Avatar
Quoted: 770 Post(s)
Liked: 199
unless I want my back row to wear fire retardant hats I don't really have a choice.
JRock3x8 is offline
post #69 of 1934 Old 06-06-2017, 12:07 PM
aka: HarperVision
Dave Harper's Avatar
Quoted: 1599 Post(s)
Liked: 746
It sounds like your sales rep is confusing bt2020 WCG with HDR.
Your choice was to buy and use a projector that worked in your environment without having to use keystone.
Dave Harper is offline
post #70 of 1934 Old 06-06-2017, 12:09 PM
JRock3x8's Avatar
Quoted: 770 Post(s)
Liked: 199
my choice was to get started with my theater or wait 5 years to buy a "real" projector. I happen to think I made a great choice.
Dave Harper and dreamer like this.
JRock3x8 is offline
post #71 of 1934 Old 06-06-2017, 12:21 PM
aka: HarperVision
Liked: 746
So there really wasn't one other projector in your budget range that could've done it without having to use keystone? OK, fair enough, but that's a pretty big trade off considering keystone destroys your native resolution. If you bought a 1080p projector it's closer to 720p now with aliasing, moire' and other artifacts being introduced as well.
post #72 of 1934 Old 06-06-2017, 12:24 PM
JRock3x8's Avatar
Quoted: 770 Post(s)
Liked: 199
I've never owned a projector before so I have no idea what you're talking about - I think my movies look damn good on my 12' wide screen. I look forward (as was always the plan) to upgrading to nicer tech as time and money allows and seeing a better quality product. But it was always going to have to be throw away money. I was never going to spend 5 or 10 grand on a projector. I have 3 kids to put through college.
Dave Harper and Aceklub96 like this.
JRock3x8 is offline
post #73 of 1934 Old 06-06-2017, 12:27 PM
sage11x's Avatar
Quoted: 1099 Post(s)
Liked: 1059
I don't understand... the W1070 should be able to easily clear heads and project onto even a fairly low mounted screen without the use of keystone correction. I use a short extension tube with my benq HT2050 but that's only because I wanted my screen as close to the floor as possible.
Do you have pictures of your setup?
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #74 of 1934 Old 06-06-2017, 12:31 PM
JRock3x8's Avatar
Quoted: 770 Post(s)
Liked: 199
boy we are way off topic here...
Shermer Theater - Construction Wrapping Up
that couch is gone btw.
JRock3x8 is offline
post #75 of 1934 Old 06-06-2017, 12:35 PM
sage11x's Avatar
Liked: 1059
Ok. Someone tell me what I'm missing because that mounting looks fine. Just level off the projector and use the lens shift to move the picture down. I'm shocked you can't square that screen from that mounting point.
sage11x is offline
post #76 of 1934 Old 06-06-2017, 12:38 PM
JRock3x8's Avatar
Quoted: 770 Post(s)
Liked: 199
maybe I don't know how to use the the lens shift but I turned the little knob and it did almost nothing.
JRock3x8 is offline
post #77 of 1934 Old 06-06-2017, 12:47 PM
sage11x's Avatar
Liked: 1059
Hm... On the w1070 you need to use a screw driver to adjust the lens shift. The adjustment is hidden under a plastic cover titled... well, lens shift. Without meaning offense: did you try that?
sage11x is offline
post #78 of 1934 Old 06-06-2017, 12:50 PM
JeffR1's Avatar
Quoted: 748 Post(s)
Liked: 263
Probably yeah.
There's been so many posts here and on a few other places, I can't remember.
At any rate it will be interesting to see what the new Optoma can do.
JeffR1 is offline
post #79 of 1934 Old 06-06-2017, 12:51 PM
JRock3x8's Avatar
Quoted: 770 Post(s)
Liked: 199
no offense taken and yes that's what I was referring to.
Maybe mine is stuck? Although I think I have a different projector than the one I bought (dead pixel, swapped out for new, god bless benq...) - I should probably try it again.
JRock3x8 is offline
post #80 of 1934 Old 06-06-2017, 01:04 PM
aka: HarperVision
Liked: 746
....... But it was always going to have to be throw away money. I was never going to spend 5 or 10 grand on a projector. I have 3 kids to put through college.
Which is why I made sure to say "in your budget range".
post #81 of 1934 Old 06-06-2017, 01:04 PM
sage11x's Avatar
Liked: 1059
It's worth a shot. I found his diagram on the web. Obviously you'd need to flip this upside down to a ceiling mount but the concept is the same.
Your screen looks unusually wide. Is that a 2.35? If it is do you over shoot or do you just not use the extra space along the sides?
sage11x is offline
post #82 of 1934 Old 06-06-2017, 01:11 PM
JRock3x8's Avatar
Quoted: 770 Post(s)
Liked: 199
i will manually zoom out for blu ray movies - most of the time the sides are not used - will address that at some point with some masking of some form.
the beauty of the benq and where I've positioned it is that the zoom is ALL the way one way for 16:9 and ALL the way the other way for 2.35
Thanks for the img - like I said I did that and a) the knob didn't move much and b) it didn't affect the image much at all - maybe mine is broken.
JRock3x8 is offline
post #83 of 1934 Old 06-06-2017, 01:25 PM
sage11x's Avatar
Liked: 1059
You know, if you're over shooting the screen that could be your issue. By over shooting you might have the top edge of the image (the top of the black bar) above the center point of the lens which the projector cannot do. Idk. I feel like you should be able to make that work somehow without keystone. It's not like the w1070 is especially limited and, to be honest, eliminating the need for keystone correction would be like upgrading your projector, IMO. I believe you that it looks fine now but squaring the projector and being able to utilize all your available resolution as well as being able to completely focus your lens should represent a pretty substantial increase in picture quality.
sage11x is offline
post #84 of 1934 Old 06-06-2017, 01:28 PM
JRock3x8's Avatar
Quoted: 770 Post(s)
Liked: 199
well I don't have to adjust keystone between 16:9 and 2.35:1 so whatever like I said it doesn't bother me because I don't know any better but I'll give the vertical shift another shot when I put my screen back up (theater is torn down for pending carpet install at the moment)
JRock3x8 is offline
post #85 of 1934 Old 06-06-2017, 02:02 PM
Quoted: 165 Post(s)
Liked: 114
am i allowed to start screaming incoherently with joy? cuz I wanna...
is this HDR finally going to be XBox compatible?
yeah, the optoma info page lists xbox one and ps4pro HDR compatibilities!!
am2model3 is offline
post #86 of 1934 Old 06-06-2017, 02:04 PM
JRock3x8's Avatar
Quoted: 770 Post(s)
Liked: 199
if Destiny 2 supports Scorpio at all, I'm going to have a really hard time not buying this
jcavner likes this.
JRock3x8 is offline
post #87 of 1934 Old 06-06-2017, 02:09 PM
Frank714's Avatar
Quoted: 696 Post(s)
Liked: 281
Just to avoid any misunderstandings: The new 4K Optoma projectors do not feature any "keystone" adjustment controls!
Went to the German HiFi Forum today and a certain George L. - whom I remember to be a reliable person - stated that the Optoma UHD 65 - unlike its 'little' brothers - will not become available in Germany before September (apparently to coincide with IFA 2017 in Berlin). I'll verify this tomorrow with Optoma.
So President # 45 should like Optoma - America First (and the Krauts will pay an extra premium once they can get a UHD 65 in September)!
ttn333 likes this.
Frank714 is offline
post #88 of 1934 Old 06-06-2017, 03:05 PM
RLBURNSIDE's Avatar
Quoted: 2012 Post(s)
Liked: 1394
Mine got stuck too until I loosed the lens bolts during a full rebuild, it's not exactly a super awesome sliding mechanism behind the scenes, but it's pretty obvious what went wrong: I didn't follow the instructions in the service manual fully to avoid tightening them too much. I'm sure dust and grime can make the lens shift stop sliding too. Probably just needs a cleanup.
RLBURNSIDE is offline
post #89 of 1934 Old 06-06-2017, 03:50 PM
RapalloAV's Avatar
Quoted: 1652 Post(s)
Liked: 479
No. Like most DLPs this projector has very limited lens shift. No horizontal and the vertical shift amounts to 18% of the image height. This is a unit designed for ceiling mount and ceiling mount only.
The lens shift is terrible for me since my proj is shelf mounted up high close to the ceiling.
Didnt Sim 2 used to have good vertical lens shift?
I wish we could get great blacks and good lens shift with DLP
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is offline
post #90 of 1934 Old 06-06-2017, 04:12 PM
Quoted: 121 Post(s)
No 3D? On a high end projector?
AVMB is offline
dlp , hdr , Optoma , uhd , uhd60
