Optoma UHD60/65 Owners Thread - Page 45 - AVS Forum | Home Theater Discussions And Reviews
 701Likes
post #1321 of 1523 Old 10-04-2017, 01:32 PM
rmerlano's Avatar
Quoted: 73 Post(s)
Originally Posted by Ruined View Post
Vivitek HK2299 should be out very shortly (this month sometime). Uses same chips as UHD65. We will see how the lens is but Vivitek is usually a step up from Optoma.
Ah! Good. I will wait a little bit before pull the trigger for a new projector.
Enviado desde mi iPhone utilizando Tapatalk Pro
Oppo UDP-203 - Receiver Denon X5200W - Projector Epson 5020UB - Projection Screen Elite Screen Mate White 150" gain 1.1
5 Channels Amplifier Emotiva XPA-5 - PreAmplifier Emotiva USP-1 - NAS Qnap 412 4x3TB Disks.
JBL Synthesis : LS80, LS Central, Subwoofer LS120P setup for ATMOS 7.1.4
rmerlano is offline
post #1322 of 1523 Old 10-04-2017, 01:50 PM
RUN-NE1's Avatar
Quoted: 24 Post(s)
Might want to try the Vivitek HK2299 instead, it uses a more powerful lamp than the UHD65 that may help with your large screen.
What pricing have you seen on the HK2299? Any other advantages of it over UHD65?
106" Mitsubishi HC7900DW and JVC coming soon.
Denon x4300h Atmos
Phillips 4K Bluray player
Polk Mon 60 fronts Mon 40 rears 80i ceiling
Klipsch 12"sub
Xbox One and X is on order.
RUN-NE1 is offline
post #1323 of 1523 Old 10-04-2017, 02:32 PM
RUN-NE1's Avatar
Quoted: 24 Post(s)
Little more info on Vivitek 2299/2288 and Optoma even.
http://www.projectorreviews.com/vivi...et-projectors/
Denon x4300h Atmos
Klipsch 12"sub
RUN-NE1 is offline
post #1324 of 1523 Old 10-04-2017, 03:23 PM
Decisions decisions...the Viviteks also have 3 HDMI 2.0 ports if that matters to you.
KingBeef79 is offline
post #1325 of 1523 Old 10-04-2017, 03:39 PM - Thread Starter
Quoted: 234 Post(s)
Liked: 179
Since we are having pictures here are some UHD65
ID:	2292724   Click image for larger version
ID:	2292726   Click image for larger version
Home Theater: Optoma UHD65, B&W 802 Nautilus, HTM1, 4-B&W 805's for surround, 4-Martin Logan 22's ceiling speakers ATMOS, 2- 18" Velodyn Subs, Marantz 8802A, MacIntosh 8207 AMP and Proceed AMP 5, Oppo 203, XBox One
BondDonBond is offline
post #1326 of 1523 Old 10-04-2017, 05:07 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 4145 Post(s)
Liked: 4229
Then I'll post a few more from the UHD60 !
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #1327 of 1523 Old 10-04-2017, 06:27 PM
Hyabusha's Avatar
Quoted: 95 Post(s)
Liked: 69
Originally Posted by BondDonBond View Post
Originally Posted by Hyabusha View Post
These are great settings thank you!
Do you have the HDR settings too?
I will have them this weekend. Going to take a little time.
Hey Don, how did the HDR tests go?
Video Games, and Home Theater Forever! ^_^
My Theater Video-https://www.youtube.com/watch?v=ICvMefl03_s&t=145s
Hyabusha is offline
post #1328 of 1523 Old 10-05-2017, 06:07 AM - Thread Starter
Quoted: 234 Post(s)
Liked: 179
I started and ended with the setting from Projectorreviews.com paid section so I did not post them because they are their settings. I think it is like $10 to get them.
I do need to do more tweaking but I found out that I need to learn more about doing HDR with Calman before I mess things up.
post #1329 of 1523 Old 10-05-2017, 06:08 AM - Thread Starter
Quoted: 234 Post(s)
Liked: 179
Craig,
So the question I have compared to some of the other projectors have worked with that would be twice as much or less would you say the 60 is 50% as good, 75% as good??
post #1330 of 1523 Old 10-05-2017, 08:32 AM
Hyabusha's Avatar
Quoted: 95 Post(s)
Liked: 69
Thanks, I just subscribed.
Hyabusha is offline
post #1331 of 1523 Old 10-05-2017, 08:47 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 4229
Craig,
It's more a matter of examining the pros and cons of each projector, and seeing if there is a " deal killer " in there. These new XPR DLP projectors ( most of them I think ) have limited lens shift / narrow installation requirements. If it works in your room, good. Then they do have lower native contrast than some other similarly priced projectors. But, this one I had appears really sharp ( oh DLP - I've missed you ). So, if your room isn't a perfect " bat cave ", like a living room, it won't matter - you wouldn't be able to see that extra contrast anyway. But if you can easily afford a $5K projector, you might not be looking at this machine to begin with. Better to compare it to $1800.00 - $2500.00 projectors. I will say that it looked better in my theater than what I saw at Cedia - which isn't surprising since I have a dedicated theater !
So I side stepped your question. Yes, most $5K projectors are better than the $2K - $2500.00 offerings, for a variety of reasons - more flexible installation being one. But, if you don't want to spend that much, or can't spend that much, you can get a surprisingly good picture on one of these new DLP projectors with 4K or 1080p. I was pleasantly surprised
post #1332 of 1523 Old 10-05-2017, 10:26 AM - Thread Starter
Quoted: 234 Post(s)
Liked: 179
Thanks, my wife and I have been surprised looking at projectors at different dealers. The UHD65 works fine without lens shift etc for my environment. I am looking at upgrading but when I look at the picture from some of the JVC and Sony products they are better BUT are they worth the $3000-12,000 better we are just like Hmmmm. If it blew me away like the UHD65 did compared to my Epson 1080P it would be like SOLD.
woodhead2 likes this.
post #1333 of 1523 Old 10-05-2017, 08:07 PM
Quoted: 172 Post(s)
Liked: 57
Hi, Craig Peer
How do the blacks and contrast compare to something like Benq W1070?
jsil is online now
post #1334 of 1523 Old 10-05-2017, 08:26 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 4229
Originally Posted by jsil View Post
Hi, Craig Peer
No idea - I've never owned or spent time with a 1070. Check Sound and Vision and projectorreviews.com for hard numbers. I'd guess probably similar, but the UHD60 has the 4K picture capability advantage !
post #1335 of 1523 Old 10-06-2017, 05:30 AM
Chris Blount's Avatar
Quoted: 86 Post(s)
Liked: 93
That's actually a very good analysis. The lower priced DLP projectors are perfect for those who just want a better home theater experience but don't have a dedicated room and a lot of money. Even if you have a dedicated room, the DLP projectors are not necessarily a bad choice. It just really depends on your money and installation situation.
Craig Peer likes this.
Chris Blount
Chris Blount is offline
post #1336 of 1523 Old 10-06-2017, 06:02 AM
Ruined's Avatar
Quoted: 1049 Post(s)
Liked: 445
Some criticize dlp native contrast but if you can get to around 5000:1 with a dynamic iris that is not annoying, that contrast level will satisfy 99% of consumers imo.
Chris Blount likes this.
Ruined is online now
post #1337 of 1523 Old 10-06-2017, 06:10 AM
madbrain's Avatar
Quoted: 154 Post(s)
Liked: 46
The dynamic iris is also not distractingly noisy when opening and closing, like it was on my Sanyo PLV-Z2000 . I had to turn that off as it was driving me nuts. Not so on the UHD65.
madbrain is offline
post #1338 of 1523 Old 10-06-2017, 06:14 AM
madbrain's Avatar
Quoted: 154 Post(s)
Liked: 46
I have a dedicated room, but also have a budget, I want to retire some day, sooner than later It wasn't that long ago that the cheapest 4K projector cost $25K, so I decided to wait on that.
I have some friends abroad who purchased some in recent years, but there wasn't much 4K content to view in the first place. Being an early adopter is always costly.
Now at least there is some serviceable amount of content, even though most is still HD. Heck, some movies are only on DVD bit rates still
madbrain is offline
post #1339 of 1523 Old 10-06-2017, 07:09 AM - Thread Starter
Quoted: 234 Post(s)
Liked: 179
I have a dedicated room also and retirement is just a myth. I can get a new JVC640 or Sony 385 but it still has me saying Hmmmm is the cost benefit analysis worth it. My UHD65 in my dark room looks good. Now if I could get the JVC Z1 for 15K or less that to me is a big step up like the UHD was from the Epson.
post #1340 of 1523 Old 10-06-2017, 07:49 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 4229
I'll call you when I decide to sell mine.
post #1341 of 1523 Old 10-06-2017, 08:05 AM
rayan1910's Avatar
Quoted: 39 Post(s)
Update on my UHD65.
Absolutely love the projector and have no regrets whatsoever.
Colors pop and the image is ultra sharp. Compared to my last optima DLP this one is sooo much better in terms or RBE, I rarely see it and its extremely faint. Black levels are more than enough for me. The Image is fairly bright but I wouldn't count on using it in a room without blinds though. The remote is kinda annoying compared to my last optoma as this doesn't have correct labels for the functions but instead have a bunch of random buttons that you have to figure out. The zoom wheel is also kind of rough but besides those two things I don't really have that much bad to say about it. Decided to watch The Fate Of The Furious in 4K and WOW the image had great color to it mediocre blacks and was as sharp as a knife.
All in all for the money I'm extremely satisfied, if you're little less into movies with lots of dark scenes and have a non-controlled room I would definitely recommend you seriously consider it.
rayan1910 is offline
post #1342 of 1523 Old 10-06-2017, 10:24 AM
Parsnips's Avatar
Liked: 2
I've been interested in looking at a UHD65 but I find that I'm looking forthem... Not B&H, not Amazon, not Best Buy, weird.
I read about a firmware update somewhere on here, are they holding them for that, maybe?
Also, I've read (somewhere on here ) that the lens should be at the level of the top on the screen for a ceiling mount... Does that work in reverse if I want to put my projector on an AV cabinet, i.e. should the lens be level with the bottom of the screen? I have a dedicated screening room (by which I mean it's the ONLY room, I live in a NYC apartment) and I don't care about people stumbling in front of the picture since crowds aren't really an issue.
(Also the building is built like a fortress and the ceiling is steel covered by concrete and not easily drilled into).
I want my UHD65! Aaaaahhhh!!!!
Parsnips is offline
post #1343 of 1523 Old 10-06-2017, 11:08 AM
aka: HarperVision
Dave Harper's Avatar
Quoted: 1599 Post(s)
Liked: 746
SOLD....to me!!! Now go get your replacement Sony VW885ES and let's get this sale moving along Craig!
Dave Harper is offline
post #1344 of 1523 Old 10-06-2017, 11:13 AM - Thread Starter
Quoted: 234 Post(s)
Liked: 179
Yeah...been watching your posts in that thread. Looks great but 35K is a little too much. I like the 15K Europe price of the 785 but we need to support Sony so they can sell lower in the rest of the world. Like the drug companies overcharging the US so you can buy in Canada at 1/3 the price.
Dave Harper, dreamer and woodhead2 like this.
post #1345 of 1523 Old 10-06-2017, 11:16 AM
Ruined's Avatar
Liked: 445
Yes lens either needs to be level with top of screen and higher; or level with bottom of screen and lower
post #1346 of 1523 Old 10-06-2017, 11:50 AM
Parsnips's Avatar
Liked: 2
Thanks, I'm all set!!!! Oh, wait...
Parsnips is offline
post #1347 of 1523 Old 10-06-2017, 01:09 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 4229
There are b stocks available !
BondDonBond likes this.
post #1348 of 1523 Old 10-07-2017, 03:35 AM
Star56's Avatar
Location: In my armed redoubt deep in the mountains of northern Ohio
Quoted: 126 Post(s)
Liked: 89
So I hooked up my 65 to my Xbox1 earlier tonight. I tried Call of Duty online and Forza 7 ( I have a wheel/pedals setup). Maybe I am clueless but I could not detect any lag at all. I expected a lag fest given the lag numbers posted here. Nada. I am getting a Xbox 1x so I was quite please to see that Forza 7 in 4K will be usable on the 65.
s.morris and batfinkus like this.
42" in the dining room. 50" in the bedroom. 80" in the living room. 65" in the family room. 70" in the family room. 106" in the family room "This is the voice of world control" Video Modes:EDTV-XGA-HDTV-4K HDR
Star56 is offline
post #1349 of 1523 Old 10-07-2017, 05:50 AM
Liked: 0
Are you guys using white or grey screens with your UHD60s in light controlled rooms?
mcstephen is offline
post #1350 of 1523 Old 10-07-2017, 05:53 AM
Ruined's Avatar
Liked: 445
IMO you should be using at most a 1.0 gain screen if your size is not too large (ie no bigger than 140"). I use a 120" 0.9 gain screen (da lite HD progressive 0.9) with a projector that has native contrast in the same ballpark and around 25% less lumens. And this combo feels perfect to me.
0.9-1.0 is ideal. If the pic is still too bright with a 0.9 you should buy a UHD65 instead of a uhd60 IMO. By going with a 0.7 grey or something like this you are limiting the whites. If it's too dark (like if you are over 140") then look into a 1.1 gain.
