Projector hush box glass from Edmund Optic - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By JonasHansen
  • 1 Post By TheBrandon
post #1 of 9 Old 07-08-2017, 01:45 AM - Thread Starter
JonasHansen's Avatar
Quoted: 150 Post(s)
Liked: 51
I just received the glass for my projector hush box which I bought because several threads mentioned it should be the best.
This is the glass I bought: https://www.edmundoptics.eu/optics/w...ciency-window/
I am surprised about how it looks and wanted to verify that I haven't bought the wrong piece.
See attachment. It's really blue and it seems to blur anything in front of it. If the blue cover is something I should remove from the glass, it's attached really well to the glass, because I cannot seem to remove it
Home Theater: JBL M2 & SUB18 powered by Crown and BSS.
JonasHansen is offline
post #2 of 9 Old 07-08-2017, 02:37 AM
Verge2's Avatar
Quoted: 795 Post(s)
Liked: 204
Errr you sure it's not a sticker? It's listed as up to 99 percent transmission. It should be clear.
Verge2 is online now
post #3 of 9 Old 07-08-2017, 03:13 AM
dreamer's Avatar
Quoted: 1068 Post(s)
Liked: 322
Looks like protective plastic to me. Use a razor blade and try to peel up a corner.
Kirk Ellis
BenQ W1070 VuTec 122" Screen
Harmon Kardon AVR 247 Parasound L&R Amp
Psycoustic Mark III L&R Towers, Boston Center
Energy Take 5 Surrounds, HSU Research Sub
dreamer is offline
post #4 of 9 Old 07-08-2017, 04:48 AM - Thread Starter
Quoted: 150 Post(s)
Liked: 51
Haha, human error
You guys were right - it is possible to peel it off with a knife. I was just too careful to try that out in the first place. $70 glass and knives if not a combo I liked in the first place!
TheBrandon and Uppsalaing like this.
post #5 of 9 Old 07-08-2017, 05:03 AM
TheBrandon's Avatar
Quoted: 370 Post(s)
Liked: 148
Haha, human error
This is exactly what my morning needed lol. Thanks to this thread, I'm going to research this though as it may help with some mounting rearrangements I'm making. Thanks!
JonasHansen likes this.
TheBrandon is online now
post #6 of 9 Old 07-08-2017, 06:55 PM
Verge2's Avatar
Quoted: 795 Post(s)
Liked: 204
Haha, human error
Fantastic, from the picture it looks like that coating is on there perfectly. I would have been confused as well, you'd think there would be imperfections hinting at it... but i don't see any.
post #7 of 9 Old 10-01-2017, 03:42 AM
elmalloc's Avatar
Quoted: 173 Post(s)
Liked: 105
I'm thinking at using Edmund Optics, so I can use my projector in a protected environment - but outside!
I'd probably cover the optics when not in use (outside) by sliding some panel/enclosure over it, but when my projector is mounted in the protected/heated environment, I'd use edmund optics in front of it, by sliding that panel/enclosure outside.
Do you think this could actually work to keep my projector protected and use it outside in the winter without much degradation to the picture? (I have an outdoor setup, but I didn't build the heated room yet until I figure this out).
elmalloc is offline
post #8 of 9 Old 10-04-2017, 07:10 AM
DTI
DTI's Avatar
Quoted: 26 Post(s)
Why spend that much on a piece of glass. just buy a tablet gorilla glass like this https://www.amazon.ca/Samsung-Temper...+gorilla+glass
DIY dust box / hush box / ceiling light... http://imagizer.imageshack.us/v2/640...633/7qBblE.jpg
DTI is offline
post #9 of 9 Old 10-04-2017, 07:19 AM
elmalloc's Avatar
Quoted: 173 Post(s)
Liked: 105
As far as I know, Edmund Optics is pretty dirt cheap, and it's 99.X% non reflective, it's meant for hush box scenarios. Don't know if Gorilla glass is meant to work here, we don't need to be able to touch the lens, I would say that isn't a good route to go, but dunno.
I doubt Edmund Optics has any R-rating worth mentioning, so probably not a good insulator in my scenario, but most of the time the room will be fully closed and heated. Usually something the size of a baseball hole will create a major heating issue in a cold environment though.
Projects:
NOT STARTED - Theater (Sim2 HT380, CIH 13ft wide).
IN PROGRESS (10%) - Home LAN (4 PCs).
Game room:
Epson 5040UBE, Denon S920W, Philips BDP7501, NVidia Shield TV, PS4 Pro, SI 110"
elmalloc is offline
