People that own home projectors, how big are your screens? - AVS Forum | Home Theater Discussions And Reviews
 67Likes
post #1 of 169 Old 07-12-2017, 12:07 PM - Thread Starter
slayerming2's Avatar
Quoted: 12 Post(s)
Just curious, I use the Carl’s ProGray Projector screen Material, and I use the full 126 by 71 inches.
But it seems like most people go a lot smaller? Which makes no sense to me since I would think we would want the image to be as large as possible.
Does it make a big difference in image quality?
slayerming2 is offline
post #2 of 169 Old 07-12-2017, 12:11 PM
eljaycanuck's Avatar
Quoted: 1346 Post(s)
Liked: 1962
Mine's 100", but I could (and probably should) have gone 106".
lizrussspike likes this.
eljaycanuck is offline
post #3 of 169 Old 07-12-2017, 12:56 PM
Hawkmarket's Avatar
Quoted: 111 Post(s)
Liked: 51
I went with 150" which is about as big as I could make work for my room. Projection technology has trade offs and the ace in the hole has always been the size of the image. The smaller you go the more flat panel televisions make sense.
JoeBoy73 likes this.
Hawkmarket is offline
post #4 of 169 Old 07-12-2017, 01:20 PM
Paganmoon's Avatar
Quoted: 48 Post(s)
Liked: 27
Mine's 117" (diagonal), felt a bit too big at first, after 1 week I regretted not getting a bigger one, now 3 years on, I'm pretty ok with it.
Paganmoon is online now
post #5 of 169 Old 07-12-2017, 01:25 PM
Balbolito's Avatar
Quoted: 38 Post(s)
Liked: 38
in my sig.
7.2.4 HT | AT 8200e LCR & Surrnds | AT 4400 x 4 Surrnd B & Front H | AT IC-6 OBA x 2 Ceiling | SVS SB16-Ultra x 2 | Epson 5040 4K | SI Black Diamond 113'' | Wireworld HDMI , Spkr , P.Cords & XLRs | Emotiva XPA Amps x 3 | Marantz AV7703 |
Balbolito is online now
post #6 of 169 Old 07-12-2017, 01:54 PM
steve1106's Avatar
Quoted: 659 Post(s)
Liked: 385
We are fans of larger so we do 151.5" or 143.5" of scope using every available inch of width and height allowed by the room.
xxrb1 likes this.
http://www.avsforum.com/forum/15-gen...eap-build.html
Epson HC3700/HC2000; Screen - 151.5" 16:9/TV or 143.5" 2.35:1/HT at a seating distance of 13/14 feet; Yamaha RXV675 for 7.4; Speakers - Infinity Primus; Subs - 3 Polk PSW10s, 1 BIC F12; Headphones - 4 JVC wireless; Sony 3D Blu-ray player/six pairs 3D glasses.
steve1106 is offline
post #7 of 169 Old 07-12-2017, 04:06 PM
Tony~M's Avatar
Quoted: 48 Post(s)
Liked: 40
135" Wide x 65" High
Hello All,
Hope you are all well.
135" Wide X 65" High Multi Aspect Ratio 2.0:1 unity gain screen.
Sitting Distance is 11 feet. Viewing Angle is 54 degrees.
Here it is with 2.35 content.
Projector is a Sony VPL-HW10 which would not belong in this forum since it was over $3,000 when new.
Later,
Tony
Aceklub96 likes this.
Tony~M is offline
post #8 of 169 Old 07-12-2017, 04:50 PM
Dave in Green's Avatar
Quoted: 1965 Post(s)
Liked: 1287
Any discussion of screen size needs to include viewing distance. My wife and I view a 100" 16:9 screen from exactly 10', or 10" of diagonal per 1' of viewing distance. I could tolerate a little larger from 10' but my wife can't. It still beats our 60" plasma from 10'.
Dave in Green is offline
post #9 of 169 Old 07-12-2017, 05:17 PM
TheBrandon's Avatar
Quoted: 222 Post(s)
Liked: 85
135, 9 feet seating position.
TheBrandon is online now
post #10 of 169 Old 07-12-2017, 05:26 PM
sharp360's Avatar
Quoted: 31 Post(s)
119" and I sit in the first row about 9' away. Very happy.
My Theater build
http://www.avsforum.com/avs-vb/showt...9#post21268949
xboxone gamertag: MASTERpTWINKIE
PS3: zaczimer
sharp360 is offline
post #11 of 169 Old 07-12-2017, 06:57 PM
elmalloc's Avatar
Quoted: 170 Post(s)
Liked: 105
13.5ft wide 2.4 AR, 13ft seating
Jets69 likes this.
Projects:
NOT STARTED - Theater (Sim2 HT380, CIH 13ft wide).
IN PROGRESS (10%) - Home LAN (4 PCs).
Game room:
Epson 5040UBE, Denon S920W, Philips BDP7501, NVidia Shield TV, PS4 Pro, SI 110"
elmalloc is offline
post #12 of 169 Old 07-12-2017, 07:35 PM
Tony~M's Avatar
Quoted: 48 Post(s)
Liked: 40
Hello Dave,
Indeed, that is very important information. I also think viewing angle should also be included.
Wife and I in a theater usually sit at about the 50 degree viewing angle in a theater, and that is what I recreated for our home viewing.
Later,
Tony
Tony~M is offline
post #13 of 169 Old 07-12-2017, 07:42 PM
rekbones's Avatar
Quoted: 479 Post(s)
Liked: 246
110" 16:9 fixed screen and sit 8' back in a 12' x 12' dedicated fully light controlled room. Perfect size for IMAX movies like Avatar but I wish I could go a little larger for 2:35 content but with my large OHM mains on each side it's the widest I could make the screen. Power masking and shifting image to the bottom of the screen brings the screen all the way to 2:70 to 1 for those super wide screen movies like Hateful Eight, Bridge Over the River Kwai and Once Upon a Time in the West.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
post #14 of 169 Old 07-12-2017, 08:36 PM
AMartin56's Avatar
Quoted: 2042 Post(s)
Liked: 1027
130 inch 2.35 screen at about 13 feet. I could move my seats a little closer with a pristine source but current distance is a compromise because it helps mask some of the flaws of crappy cable TV etc.
AMartin56 is offline
post #15 of 169 Old 07-12-2017, 09:58 PM
Quoted: 476 Post(s)
Liked: 118
As big as the zoom range or wall allows.
TheronB is offline
post #16 of 169 Old 07-13-2017, 03:52 AM
bud16415's Avatar
Quoted: 1067 Post(s)
Liked: 409
Dave is correct it is a function of screen size and seating distance, and of course how many people you are planning to entertain. If you want your room to hold 16 people you are going to need a bigger screen than the conventional HT that holds 4.
The system that works best is CIH constant image height or CIH+Imax .
Immersive viewing as CIH for most people starts around with a viewing distance that is 2X the screen height and most people fall someplace between 2X and 3X screen height. As an example the back row in a commercial theater is closer to 4X.
One advantage of not going excessively large is the smaller the image the more lumens you have available and for that reason and that my seating max out at 6 people in a single row and 95% of the time 4 or less our screen is 110” and seating is about 2.5 X the screen height. That size screen gave me the immersion we wanted and also enough lumens to fight some ambient light we wanted in the room for sports viewing and such.
Ftoast likes this.
Bud
bud16415 is offline
post #17 of 169 Old 07-13-2017, 04:07 AM
LFE Junkie's Avatar
Quoted: 500 Post(s)
Liked: 640
133" CinemaScope
LFE Junkie is offline
post #18 of 169 Old 07-13-2017, 04:24 AM
Quoted: 38 Post(s)
150" screen, Epson 5030ub, 16 feet from screen. I started with a 120", then, then 150". Had to go to inwall's and A/T screen so I could have room to go 150". You can read a lot on this, butt the simple thing is to install you projector and just project up on the wall to the size you feel is right, then pick the screen.
Pianist718 likes this.
James Stephens 2 is online now
post #19 of 169 Old 07-13-2017, 04:46 AM
johnson636's Avatar
Quoted: 381 Post(s)
Liked: 147
10' 5" wide 2.4 white over silver spandex and 10' 5" wide 16x9 white over black spandex at 9' seating distance. I switch the screens depending on what I'm watching or how I'm feeling. I'd go larger if my room would allow it
johnson636 is online now
post #20 of 169 Old 07-13-2017, 05:21 AM
JRock3x8's Avatar
Quoted: 754 Post(s)
Liked: 197
I built a room width (12.5 foot) white over black spandex screen - I care less about image quality than I do about image size. People can hate me all they want for that but that's how I like to watch a movie. First row is roughly 10' from the screen.
That being said, text in movies or games is most definitely "chunky" on the screen.
My PJ is the BenQ 1070 and I run it min/max where I slide the zoom all the way one way for 16:9 (9.5 feet wide) and all the way the other way for 21:9 content (12' wide)
dreamer and steve1106 like this.
JRock3x8 is offline
post #21 of 169 Old 07-13-2017, 06:31 AM
AV_Integrated's Avatar
Quoted: 1126 Post(s)
Liked: 819
I do a 161" diagonal in my unfinished basement. Sitting about 16' away from it.
W1070 With The Lights On - 161" Screen
It's pretty darn cool. It will be better when I finish the basement.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #22 of 169 Old 07-13-2017, 06:36 AM
steve1106's Avatar
Quoted: 659 Post(s)
Liked: 385
But still even an old Gamecube game that looks really "bad" by today's standards looks "really" great when it is over a 150".
smilingangel likes this.
post #23 of 169 Old 07-13-2017, 07:14 AM
JRock3x8's Avatar
Quoted: 754 Post(s)
Liked: 197
how are you running that in 16:9? Is that an emulator? I really like Mech Assault, KOTOR, etc from OG XBox but good god the 4x3 framing just drives me nuts.
JRock3x8 is offline
post #24 of 169 Old 07-13-2017, 07:42 AM
Tony~M's Avatar
Quoted: 48 Post(s)
Liked: 40
GameCube and Progressive Scan Capability
Hello,
Hope you are well.
Many GameCube games support progressive scan and 16:9 aspect ratio natively if you have the component cable for the GameCube, or play them on a Wii with component cables. No emulator required.
Later,
Tony
sage11x likes this.
Tony~M is offline
post #25 of 169 Old 07-13-2017, 07:59 AM
Verge2's Avatar
Quoted: 782 Post(s)
Liked: 204
Dolphin
Verge2 is offline
post #26 of 169 Old 07-13-2017, 08:02 AM
Quoted: 44 Post(s)
Originally Posted by Verge2 View Post
Dolphin
110" Silver ticket arrives today and will be sitting just a smudge under 12' away
inspector likes this.
Chase_Monkey is online now
post #27 of 169 Old 07-13-2017, 08:08 AM
Quoted: 209 Post(s)
Liked: 58
106" here. While the inclination to most is to get the biggest screen you can throw on the wall its usually a bad idea. The key factor here is seating distance and viewing angle. If your seating area is to close to accommodate an over sized screen your viewing experience will actually suck. (its the same effect of sitting in the front row at the movie theater when you showed up late). There are formulas out there to determine proper screen size.
Dbruce13 is offline
post #28 of 169 Old 07-13-2017, 08:14 AM
sage11x's Avatar
Quoted: 1094 Post(s)
Liked: 1052
Dolphin
Not necessary. GameCube supports 16:9 right out of the box as long as you have component cables.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #29 of 169 Old 07-13-2017, 08:25 AM
Scarriere's Avatar
Quoted: 80 Post(s)
Liked: 40
I am currently in transition, but when my system was up, we sat 8 feet from a 92" 16:9 screen and it was great.
I now have the space for a 106, maybe 110" screen. I'm still working on it, but look forward to the larger screen and sitting further away.
Scarriere is offline
post #30 of 169 Old 07-13-2017, 08:27 AM
73shark's Avatar
Quoted: 414 Post(s)
Liked: 213
110" 16:9
In space, no one can hear you scream . . .
73shark is offline
