Sony hw45es screen flicker normal? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By robinw
post #1 of 6 Old 09-30-2017, 10:14 AM - Thread Starter
Liked: 1
Dear avs forum readers,
Recently i became the proud owner of a sony hw45es. The lamp has some 180 hours on it and i'm noticing a flicker effect. It's the same kind of flicker which is produced by fluorescent lights. (just google fluorescent light flicker if you've never noticed)
I'm not sure if it was already there from the start or it developed over time, i just noticed it recently.
It's constant and especially visible in high power mode which i usually use.
This is my first projector. Is this normal or should i ask for a repair/replacement?
robinw is offline
post #2 of 6 Old 09-30-2017, 12:03 PM
Quoted: 361 Post(s)
Liked: 194
This is a well-known defect with Sony projectors and their lamps. Certain members here were spreading misinformation stating that the defect had been fixed with the new Sony 45es model. But obviously this defect has continued with the new 45ES.
LumensLover is online now
post #3 of 6 Old 09-30-2017, 01:24 PM - Thread Starter
Liked: 1
Thanks i'll contact my store then.
I searched for people having similar problems but couldn't find them since they we're all related to flickering in low lamp setting which is a different and more obvious flicker i noticed on an epson 3700, which i tried and in the end didn't keep in favor of the sony.
robinw is offline
post #4 of 6 Old 09-30-2017, 01:52 PM
Dave in Green's Avatar
Quoted: 2040 Post(s)
Liked: 1310
@robinw , check the HW45ES owners thread where dozens of satisfied HW45ES owners have reported no sign of lamp flicker. If it was a common issue with the HW45ES there would be many more reports of it.
As previously discussed when this subject came up flicker is a characteristic that can develop in any projector with any brand of UHP lamp. If you do a search for BenQ projector flicker or Optoma projector flicker or Epson projector flicker or (Insert Any Brand) projector flicker you'll see reports for all of them, not just Sony.
I haven't seen a sign of a flicker with my HW45ES but my old Panasonic projector did develop flicker. The simple fix for me was to change from low to high lamp for about 20 hours before switching back to low lamp. End of flicker. Others who developed flicker in high lamp mode cured it by running in low lamp for awhile.
Here's what a real professional (ISF calibrator Jeff Meier) has to say about UHP lamp flicker:
This behavior is inherent to UHP lamps.
homecinemaguru.com/why-is-my-projector-flickering/
Dave in Green is offline
post #5 of 6 Old 09-30-2017, 02:27 PM - Thread Starter
Liked: 1
Ok guys,
Thanks so much for the quick responses. I found the cause!
Running the power chord next to the hdmi cable in the same enclosure along the wall for 4 meters or so...
I tried a separate power chord and the flicker was gone.
I wouldn't expect a digital signal to pickup analog interference but i guess it does.
Dave in Green likes this.
robinw is offline
post #6 of 6 Old 09-30-2017, 06:43 PM
dolphinc's Avatar
Quoted: 97 Post(s)
Liked: 68
Ok guys,
Nice job in figuring out the issue. Dave is correct that pretty much any projector can suffer from flicker. I'm at about 650hrs on my Sony and it hasn't ever flickered once.
dolphinc is offline
hw45 flicker
