Need specs for "feet" of Epson 4000 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By AV_Integrated
post #1 of 5 Old 09-30-2017, 11:30 AM - Thread Starter
old corps's Avatar
Quoted: 159 Post(s)
Liked: 91
If anyone can provide the length/distance between the "feet" of the 4000 I'd greatly appreciate it! I'm trying to determine if I can use the shelf that my 5030 sits on.
Ed
old corps is offline
post #2 of 5 Old 09-30-2017, 06:41 PM - Thread Starter
old corps's Avatar
Quoted: 159 Post(s)
Liked: 91
Ed
C'mon guys, gotta be a 4000 owner out there in AVS land that can break out a tape measure. I just need to know the distance between the "feet" or pads that actually touch the surface when shelf mounted--both left to right & front to rear. I've got a 5030 on this shelf now but previously had a Viewsonic Pro8100 that was much larger. Because of where it's feet were it still fit on it. I know the 4000 is huge but I'm hoping the feet are inboard enough to fit.
Ed
post #3 of 5 Old 10-01-2017, 10:51 PM
AV_Integrated's Avatar
Quoted: 1148 Post(s)
Liked: 825
Since the 5040 and 4000 use the same chassis, then I would imagine this would work...
http://uploads.tapatalk-cdn.com/2016...f35b083053.jpg
old corps likes this.
AV_Integrated is offline
post #4 of 5 Old 10-03-2017, 02:53 AM
headcase151's Avatar
Quoted: 18 Post(s)
Go to Best Buy. They have a scale size case on display.
headcase151 is online now
post #5 of 5 Old 10-03-2017, 07:14 PM - Thread Starter
old corps's Avatar
Quoted: 159 Post(s)
Liked: 91
Thanks so much for taking the time! Looks like it would fit on my current shelf just fine. For anyone else: Distance between front feet would be 17.09". Assuming the diagram is to scale (doesn't actually show this) the distance between the front feet and the support at the rear would be approximately 10".
Ed
