How can you tell when the bulb is about to go? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-03-2017, 05:42 PM - Thread Starter
04rex's Avatar
Quoted: 138 Post(s)
Hello, have the Benq W1070. Lately it looks like the picture is getting more washed out. Is this a sign that the bulb is starting to go?
FAMILY ROOM - Totem Tribe II LCR, JL Audio E-112, Anthem MRX 300, Apple TV Gen 3, WD HDTV, Panasonic 55" Plasma
BASEMENT THEATRE - Paradigm Studio 100 v.5 L/R, CC-690 v.5 C, Studio 10 v.5 x4 Surround Side and Backs, 4x DIY 15" Ultimax Subwoofers in 3.0 Cu Ft sealed boxes, Cerwin Vega CV-5000 for Subs, Anthem MRX 720, Outlaw Audio 7700, HTPC, Apple TV Gen 4, X-Box One, Harmony Ultimate Remote, Ben-Q W1070, 92" screen
04rex is offline
post #2 of 7 Old 10-03-2017, 07:32 PM
Quoted: 28 Post(s)
Liked: 4
How many hours on the lamp?
DunMunro is online now
post #3 of 7 Old 10-03-2017, 07:41 PM
rekbones's Avatar
Quoted: 499 Post(s)
Liked: 253
It will keep getting dimmer so if their is ambient light in the room then yes it will look more washed out.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is online now
post #4 of 7 Old 10-03-2017, 08:29 PM
Dave in Green's Avatar
Quoted: 2025 Post(s)
Liked: 1306
All projector lamps dim with age. If the image is getting more and more washed out from the same amount of ambient light that's simply a function of the same amount of ambient light having a larger and larger effect on an increasingly dimmer lamp. As to being able to predict when it might completely fail there's no way. Manufacturing variances and different use patterns mean that, like snowflakes, no two projector lamps are exactly alike. At some point some will simply dim to nothing and a small percentage will fail catastrophically. When the image quality degrades to a certain point most people will want a new lamp to restore the projector to its original bright image. YMMV.
Dave in Green is offline
post #5 of 7 Old 10-04-2017, 07:36 AM - Thread Starter
04rex's Avatar
Quoted: 138 Post(s)
Thanks guys. I forgot to check how many hours are on it but I believe it is around 2,000 maybe?? I will have to check.
Something else happened. I was watching something, and it looked washed out. But then all of a sudden it wasn?t washed out anymore. Like a switch was turned on or something. And I didn?t change anything. I was just sitting there watching. Is this the lamp still or would it be a projector issue? It went almost back to normal. Then I watched it again a day later and it was washed out. Weird.
04rex is offline
post #6 of 7 Old 10-04-2017, 10:37 AM
Liked: 1306
The average W1070 lamp lasts more than 2,000 hours before it's too dim for viewing. Your latest description makes it sound as if the issue is not lamp related. It could be a cable issue, a failing component in the electronic circuitry or a source issue. If the issue occurs with different sources then you could rule that out. Another simple and obvious thing to check is to see that all of your cables are firmly inserted into their respective inputs/outputs. If you have extra cables you might also want to try at least temporarily replacing the current cables with the spares.
post #7 of 7 Old 10-05-2017, 07:57 AM - Thread Starter
04rex's Avatar
Quoted: 138 Post(s)
I will check the cables as well then. I have noticed that for some reason the projector has been dropping its connection a few times. The receiver's display doesn't change, but the picture drops then comes back after a few seconds. So I think it can be the cable or the projector at this point. I will double check the connection though.
04rex is offline
