Panasonic picture has spots! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-04-2017, 03:25 PM - Thread Starter
mcaskey's Avatar
Hey guys, my Panasonic PT-AE4000U has some blotchy spots and fuzziness. Mainly in the lower-right of the image.
Any idea why?
Are you able to tell anything from these pictures?
https://photos.app.*******/h7L8UpH2dzweAle52
ID:	2292710   Click image for larger version
ID:	2292712   Click image for larger version
ID:	2292714   Click image for larger version
ID:	2292716   Click image for larger version
mcaskey is offline
post #2 of 4 Old 10-04-2017, 07:28 PM
rekbones's Avatar
Quoted: 505 Post(s)
Liked: 257
Looks like dust blobs, adjust the focus and see if they come into focus. Burnt polerizers are also a possibility and they can't be focused. Dust blobs can be cleaned out if you know what you are doing, burnt polerizers are not worth fixing..
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is online now
post #3 of 4 Old 10-04-2017, 09:16 PM
dreamer's Avatar
Quoted: 1072 Post(s)
Liked: 322
Any idea why?
Burnt polarizers are generally more rounded, while your issues on the separate colors are blocky and in different areas. That rules out lens and dichroic mirror as well. That make me think the lcd panels for green and blue are failing. Time to replace that pj. One of the many reasons I stay away from lcd projectors.
Kirk Ellis
BenQ W1070 VuTec 122" Screen
Harmon Kardon AVR 247 Parasound L&R Amp
Psycoustic Mark III L&R Towers, Boston Center
Energy Take 5 Surrounds, HSU Research Sub
dreamer is offline
post #4 of 4 Old 10-05-2017, 08:16 AM
Signal's Avatar
Any idea why?
I'm not sure, but I suspect that the red polarizer in your projector has heat damage. Your red screen shot looks like the green image on my Panasonic PT-AE4000U. I was not able to focus on the spots. I opened the projector anyway and tried blowing out the polarizers and LCD panels, but to no effect.
In August I replaced my Panasonic with a BenQ HT2050 DLP projector. Overall, I'm much happier with the BenQ at about 1/3 the price of the Panasonic. The BenQ's picture is much sharper than the Panasonic's. With lens shift, my Panasonic had what has been variously described as ghosting, bleeding, smearing or blurring:
Panasonic PT-AE4000 MSRP $1999
Subjectively, after about 200 hours on the lamp, I find the black level at Economy or Smart Eco setting no better than the Panasonic, but little if any worse. The BenQ is significantly brighter, even at the Economy and Smart Eco lamp setting. The Smart Eco setting is like an electronic version of a dynamic iris. It lowers lamp power in dark scenes and increases power in bright scenes. The Panasonic has better screen uniformity. The BenQ is brighter at the center of the screen than the corners, but this is rarely noticeable in normal content.
It's most disappointing. I shall have to go all-out on some modifications.
Signal is offline
