HS10 in Manhattan? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-17-2003, 11:06 AM - Thread Starter
vkottas's Avatar
anyone have a Sony HS10 set up in Manhattan that I could see?
I will bring the beverages of choice.
I am itching to order an HS20 but at least want to check out the HS10 and see that it's sufficiently good. from what I've heard picture quality should be substantially improved; only thing hard to verify is that it's quieter enough not to be annoying.
I saw the HS10 at the Sony store and it didn't look good at all, but the setup was somewhat lousy (bright lighting, huge image, probably not calibrated very well).
-vas
vkottas is offline
post #2 of 2 Old 10-17-2003, 11:08 AM - Thread Starter
vkottas's Avatar
sorry - not being clear. the HS20 should be substantially improved from the HS10. but you know what I meant.
-vas
vkottas is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
