Comments on EpsonTW100? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-17-2003, 02:30 PM - Thread Starter
DKALANIM's Avatar
I'm looking for a sub $3500 FP. I really like the Sony HS20, but I just read a review on the epson and it sounds like a good contender.
Does anyone have any experience on this they can share?
There is a difference between knowing the path...and walking the path.
DKALANIM is offline
post #2 of 9 Old 11-17-2003, 02:54 PM
rlindo's Avatar
Quoted: 694 Post(s)
Liked: 522
well from all accounts the tw100 is a great pj but I believe they have discontinued it and for a lower price you can get the sanyo plv-z2 or the panasonic ae500 which may both outpeform the tw100 in certain key areas.
rlindo is offline
post #3 of 9 Old 11-17-2003, 03:05 PM
Xander's Avatar
It also depends whether it is a TW100 or TW100H (the newer version with higher contrast). Either way the newer Z2, AE500 and HS20 will be superior in the black levels and contrast areas (and specifically shadow details area), but more so with the older TW100. If you can get a TW100H at a really good and substantially lower price than any of the new three, it might be different.
o AE100->TW100->AE300->HS10->AE500->AX100->TW700->TW3000->TW8000
Xander is offline
post #4 of 9 Old 11-17-2003, 03:43 PM
Andrew_Ballew's Avatar
Hey Xander
I am not really sure that these newer guys will be that much better contrast wise over the 100H.... maybe a little, but man, the H version had killer contrast for an LCD... at least as good as its 800:1 rating. I would be willing to bet that the AE500, Z2, HS20 before any major calibration are going to be closer to the just under 1000:1 range than they are their actual ratings... but we will see... who knows!
Andrew B.
Andrew_Ballew is offline
post #5 of 9 Old 11-18-2003, 06:30 AM
AlienArchbishop's Avatar
I am thinking the epson TW might have the advantage of the Faroudja chip, which all the other do not have, but I quess i you are using a HTPC it should make no difference.
Cheers,
the A.A.
AlienArchbishop is offline
post #6 of 9 Old 11-18-2003, 12:19 PM
djstatik's Avatar
The TW100 is EOL. (end of life) I wouldn't waste my time with it. There are several better options out there now than this PJ.
"Better to have loved a home theater and lost, then to have never had a home theater at all"
djstatik is offline
post #7 of 9 Old 11-18-2003, 04:27 PM
cpc
AVS Club Gold
cpc's Avatar
I agree. The TW100 and TW100H were good, but get a really good price used and its worth it, otherwise, go for the Z2, AE500 or HS20.
cpc is offline
post #8 of 9 Old 11-20-2003, 01:49 AM
EmuMannen's Avatar
I still love my TW100; it’s not perfect but has proven to be very versatile. I can connect almost anything to it and it just syncs and delivers. I am just now running it with a Brainwave V880 trough DVI with a custom resolution of 720p@50Hz (for PAL). The picture is 1:1 pixel perfect, panning is smooth as silk and the PQ is absolutely stunning! I compared my picture to the HS20, TW200 and Z2 last weekend and I still prefer my TW100. It could be due to insufficient calibration of the others and heavy tweaking of my own. I must admit that I was surprised that these new projectors, other than noise level wize, didn’t impress me more. I have already lost interest in today’s new LCD and DLP and I am now waiting eagerly for the next generation... :o
It is comforting to know that my old TW100 will serve me well while waiting... :D
The answer is technology! What was the question?
EmuMannen is offline
post #9 of 9 Old 11-20-2003, 02:41 AM
Kane D Williams's Avatar
How come the new TW200 does not have a DVI input? It is down to £1500 in the UK now and if it did have a DVI, would be a contender, as it is I am trying to get an HS20. And Epson are confused by lack of sales???
Kane D Williams is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
taboola here
