OFFICIAL Sony HS50(51) thread - Page 189 - AVS Forum | Home Theater Discussions And Reviews
post #5641 of 5686 Old 05-16-2007, 05:15 PM
bsntn99's Avatar
If you try a video or s-video from the cable box to the pj, it has to be 480i and should work. Also try this with another tv or display.
It could be a bad cable box or they may have a filter on the line that only lets certain channels through. Check with the cable company on this as well. I have a filter on mine to remove the analog channels on mine since I only want to pay for digital or HD. The dvd player suggestion above is also good.
bsntn99 is offline
post #5642 of 5686 Old 07-04-2007, 10:28 PM
pyro2003's Avatar
i see this thread is waning, but anyone tried the Toshiba HD-XA2 HD DVD with this projector yet ? the A1 seems to breath new life into the machine, and September firmware for the XA2 for 1080p/24 makes me wonder
anyone ?
pyro2003 is offline
post #5643 of 5686 Old 07-04-2007, 10:32 PM
MoG
MoG's Avatar
Quoted: 18 Post(s)
anyone ?
hi,
i just ordered the XA2. will report back after it's up and running. currently have a PS3 hooked up and picture looks great. (XA2 will be in addition to PS3, not replacing it.)
thx.
snagabag.com - just a click away
MoG is online now
post #5644 of 5686 Old 07-04-2007, 11:32 PM
merv43's Avatar
Quoted: 16 Post(s)
Originally Posted by MoG View Post
hi,
thx.
What screen are you using and how is the picture with the ps3? Is it much better than standard dvd or not much difference?
Mike
merv43 is online now
post #5645 of 5686 Old 07-05-2007, 10:22 AM
Bytehoven's Avatar
Quoted: 35 Post(s)
Liked: 66
May I just add... Any improvement in the source quality made by going from even the better DVD players, to a an HD source, is easily seen in the projectors image.
I dare say this was true not just for the HS50/51 but even a great projector like the NEC HT1000.
XBL GT: J05HB4G05H
PSN ID: Bytehoven
Battle Log: Bytehoven
Bytehoven is offline
post #5646 of 5686 Old 07-05-2007, 11:42 AM
hawkeye3.1's Avatar
hi,
thx.
Do you know what the PS3 sends to your PJ? I am going to guess 720/60p. Can it send 1080/24PsF (aka 1080/48i), if so have you tried it? I am curious about HD at native frame rate also now that I see the HS-51 can accept a 1080/48i source.
hawkeye3.1 is offline
post #5647 of 5686 Old 07-05-2007, 10:34 PM
SVonhof's Avatar
Quoted: 13 Post(s)
If the PS3 has a decent scaler in it (I assume it does), why would you want to send 1080i to a projector that is limited to 720p?
SVonhof is offline
post #5648 of 5686 Old 07-06-2007, 07:33 AM
hawkeye3.1's Avatar
With my sources, 1080i inputs scaled by the PJ looks better to me, I never sent it in to get the 720p blanking issue corrected. But my question was pointed more towards the difference in frame rate (60 vs 48). I am curious just how much improvement can be seen when 3:2 judder is eliminated.
post #5649 of 5686 Old 07-23-2007, 04:42 PM
merv43's Avatar
Quoted: 16 Post(s)
I just purchased a Panasonic dmp-bd10a blu ray player and have it connected to my vpl - hs51 with a bluejeans 6 meter hdmi cable. The info screen reads 1080/60i. How can you adjust the frame rate from 60 to 48? The picture does look good but I am wondering what tricks or adjustments people have made to make it better, if possible. Thanks
Mike
post #5650 of 5686 Old 08-04-2007, 10:09 PM
merv43's Avatar
Quoted: 16 Post(s)
does anybody know how to change the preset signals in the manual? for example with hdmi connection my information menu indicates memory #7. I would like to try some of the others but I don't know how to change them, or if it can be changed. Any advise would be great, Thanks
Mike
post #5651 of 5686 Old 08-07-2007, 07:12 AM
_XipHiaS_'s Avatar
The preset number you see is the number that equals the signal you send from your device. You don't set a preset number in the projector, the projector only describes the signal it receives. If you want another signal you set it at your DVD, receiver or anything you conected to the projector.
The list in the manual is simply showing you a matching number and signals the projector can receive over an input, and the settings you can or cant make at the projector for that signal/input.
_XipHiaS_ is offline
post #5652 of 5686 Old 08-07-2007, 05:33 PM
RoninTech's Avatar
I just put up a description and pic of a problem I'm having with my HS51. Wasn't sure if I should add to this or start separate. For those subscribed to this main HS51 thread check it out here .
Cheers,
Ronin
Calgary, Alberta, Canada
RoninTech is offline
post #5653 of 5686 Old 08-08-2007, 09:18 PM
merv43's Avatar
Quoted: 16 Post(s)
Thanks for the explanation, that makes sense. Thanks again.
Mike
post #5654 of 5686 Old 01-05-2008, 05:09 PM
nigelpearson's Avatar
This summer, my HS50 has started showing blue blotches at the top of the screen. Not visible on an all-black or all-white image, only mid-range tones. It isn't there at start up, but slowly creeps in after a few minutes, so I suspect it is heat-related.
I have only run the PJ up to about 4000hrs, but some that was on weekend marathons of 12hrs, so I suspect this is panel damage.
I have looked through the factory menus, but there doesn't seem to be anything to adjust for fan speed (apart from the high-altitude, which I always turn on in summer). Anyone have ideas for adjustments to minimise this?
| Nigel Pearson, nigel@ind.tansu.com.au
| Telstra Network Engineering, Sydney, Australia
|"Things you own end up owning you"
| Tyler - Fight Club
nigelpearson is offline
post #5655 of 5686 Old 01-05-2008, 11:56 PM
RoninTech's Avatar
Welcome to the blue smear club. Once it started for me (around 3000 hours) it just got worse and worse. 1 person was reported to have gotten it fixed out of warranty, others were quoted $2K to get it fixed (see link a couple of posts above). I just got an AW15 to replace it. Its not known whether newer models also suffer from this disease. Hopefully yours is still under warranty?
Cheers,
Ronin
post #5656 of 5686 Old 01-06-2008, 06:58 PM
Blue-Smear? I wanted to join the Blu-Ray club
Ha. No such luck. It was a factory-refurb when I first got it, and I didn't pay any extra to extend the warranty. But the original globe was still working at 3620 hours, so I don't feel too bad.
I took off the plastic cover at the back to increase airflow, and also found that the globe and panel run a few degrees cooler (i.e. less blue smear) in high lamp mode, so I will keep it in that mode for now.
Now that I know it is a common fault, I probably won't be able to sell it on eBay, so I might have to use it until something dies.
| Tyler - Fight Club
post #5657 of 5686 Old 01-10-2008, 07:06 AM
alopez1986's Avatar
Hey everyone!
New to this forum, just bought a HS-51 I am very happy with it! But i found i wanted to do some calibration for playing to my xbox 360 and watching hd movies...
I find this a very very long thread, can someone give me their settings on their projector for watching hd movies or playing games?
What can you change in service mode? And how do you enter?
Thanks everyone!!
alopez1986 is offline
post #5658 of 5686 Old 01-10-2008, 05:58 PM
JustAsk's Avatar
I would be interested in hearing the answer to alopez1986's post too.
HD-XA1, HD-A2, BDP-S300 and DMP-BD55K owner
JustAsk is offline
post #5659 of 5686 Old 01-11-2008, 06:58 AM
Bytehoven's Avatar
Quoted: 35 Post(s)
Liked: 66
Check out this thread...
http://www.avsforum.com/avs-vb/showthread.php?t=485063
It has a great deal of calibration info worth look thru, including some service menu tweaks which take the 50/51 to the next level.
DO IT. Read thru, take notes or copy paste to create a master calibration guideline for your own setup.
Having a Xbox 360 myself, it requires some additional tweaks compared to calibration for other SD/HD sources.
XBL GT: J05HB4G05H
PSN ID: Bytehoven
post #5660 of 5686 Old 01-11-2008, 08:48 AM
alopez1986's Avatar
hi bytehoven!!
Thanks for your response!
I already read that post, but they talk a lot technically, and i foind the latest config they setup was this one:
CONTRAST: 80
BRIGHTNES: 65
Iris off and Lamp on High
Initial Settings
Open Reg 41-->40
Close Reg 200-->202
No change here.
Low Color Temp Factory/// Middle Color Temp Factory
Red G - 128/// Red G - 128
Green G - 32/// Green G - 37
Blue G - 39/// Blue G - 59
Red B - 118/// Red B - 118
Green B - 128/// Green B - 128
Blue B - 123/// Blue B - 124
As you can see, these settings are very close in the biases but differ in the gains.
Calibrated Settings (Iris Off/Lamp High HDMI)
Red Gain-128
Green Gain-46
Blue Gain-49
Red Bias-86
Green Bias-128
Blue Bias-123
Resulting Color Temp 6513 DE:2
Lumens 381
Gamma 2.51
CR 379:1
For those of you that would want to use the User Menu, just use Custom 3 and these settings:
Red Gain- 0
Green Gain- +6
Blue Gain- -4
Red Bias- -28
Green Bias- 0
Blue Bias- +13
Iris Adj = 0
Open Reg = 41
Close Reg = 200
FOR COMPONENTS:
Calibrated Settings (Component 480i)
Red Gain-128
Green Gain-40
Blue Gain-38
Red Bias-75
Green Bias-128
Blue Bias-124
Resulting Color Temp 6543 DE:1
Lumens 326
Gamma 2.53
CR 2757:1
I willl try this tonight and tell you my opinions
post #5661 of 5686 Old 01-20-2008, 07:56 PM
Alind Saxena's Avatar
Hi...I have a question...
I was watching the latest Harry Potter ( Order Of Phoenix) on my Projector. Most of the picture is excellent but in the begining and sometimes in the middle i get to see a lot of grains ..particularly on the faces...! Should i do something with the settings to adjust that...or is it just the movie. I have also been seeing that the dark scenes (very dark ones) show more grains...! I am sorry if i sound any absolute novice in all this..
Thank you for your comments
BTW...This is with normal DVD.
Alind Saxena is offline
post #5662 of 5686 Old 01-21-2008, 08:29 AM
Bytehoven's Avatar
Quoted: 35 Post(s)
Liked: 66
1) What is your sharpness setting? I have found setting the Sony sharpness to OFF may look soft, but it is indeed a setting which provided ZERO sharpness enhancement rather than a softening from a normal sharpness. Another words, the middle sharpness position on the Sony is adding sharpness enhancement.
2) What is you brightness setting? Try lowering until the artifact goes away and then judge the rest of the program.
3) Do you have any gamma or black level boosting? If yes, try lowering them or turning them off.
I assume you are seeing DVD artifacts that could well be an issue with your DVD player. You might say what player you are using.
Good luck
XBL GT: J05HB4G05H
PSN ID: Bytehoven
post #5663 of 5686 Old 01-21-2008, 10:42 AM
Eric_Apple's Avatar
Anyone seen this problem with their HS51?
It happens with any connection type. Is easiest to see with a white background. I tried a different bulb but that did nothing.
I called Sony and they had no idea. Gave me the number for the local service center.
Projector is just out of warranty (it seems every sony product I have dies as soon as the warranty ends) !!
Thanks for any pointers...
Eric_Apple is offline
post #5664 of 5686 Old 01-21-2008, 11:25 AM
RoninTech's Avatar
You bet Eric, except yours is a different color than mine (yellow) which suggests it might be a different panel/polarizer.
Cheers,
Ronin
post #5665 of 5686 Old 01-22-2008, 11:54 PM
bguzman's Avatar
Quoted: 49 Post(s)
Liked: 518
Sorry to change the topic but does anybody know where I can get a copy of the Image Director 2 software?
HT, Mitsubishi HC6500, 106" screen, Panasonic TC-P50G10, Oppo BDP-103, Toshiba A35, Panasonic LX-1000U, Pioneer Elite CLD-95, Faroudja NRS, DirecTV H21-100, PS3, Pioneer Elite SC-85, Def Tech; SM 450, CLR 2002, BP2X, Klipsch KSB 1.1(X4), Pro Sub 100, Polk PSW125
Old School, Sony PS-5500->Denon 103r->AU-320 SUT, Dual 1219->Shure M91ED, Kyocera DA-610cx, Pioneer SA-1000, Polk Monitor 10A
bguzman is offline
post #5666 of 5686 Old 03-24-2008, 11:45 PM
pyro2003's Avatar
not sure anyone still read this thread (at least not archived yet)
my Sony HS60 appears to be very dark after only 170 hours after I got it for 2 years. When I bought it, it was the best uniform and white balance panel out of 3 samples that I checked. Now Hong Kong could be a dusty place but some believed this projector is sealed light path, any suggestions as to what maybe wrong ?
I am usually running in Cinema Mode and over DVI to VGA converter. Are there other interface that maybe brighter in your experience ? These days I only use the projector to play Wii Tennis and its gotten so bad that I usually cannot follow the tennis ball projecting at 90 inches on a Stewart Studioteck 130 at the closest throw distance... which I can do perfectly when I use my 36" CRT !
I will throw it out if you tell me to change the bulb !
pyro2003 is offline
post #5667 of 5686 Old 03-25-2008, 05:56 AM
longbow's Avatar
Mine is also about 2 years old with 480 hours on bulb #1. So far it has no reduction in brightness. I have never used the VGA input, just HDMI and Component. How do those inputs look? Perhaps the problem is in the VGA port and not the bulb. I would do some trouble shooting then call sony for repair.
EricN"You are in a maze of twisty passages, all alike" HT: Denon 4311CI, Oppo BDP-105D, M&K S-150's LCR & ss-150's SL & SR, SVS PB12+, Epson Home Cinema 1080, Stewart StudioTek 130 92"
longbow is offline
post #5668 of 5686 Old 03-25-2008, 07:51 AM
mlemartien's Avatar
Mine is 3,5 years old with 1000 hours on bulb #1. Used HDMI for the first months and the VGA. No brightness reduction so far either. I'm still enjoying this great projector.
mlemartien is offline
post #5669 of 5686 Old 03-25-2008, 08:07 AM
SVonhof's Avatar
Quoted: 13 Post(s)
My HS51 has almost 300 hours and no noticable dimming of the image. I pulled the filter after 250 hours and it looked pretty clean although I replaced it anyway.
SVonhof is offline
post #5670 of 5686 Old 03-25-2008, 05:42 PM
Cinema mode is the darkest of the three defaults, but a sudden dimming is unusual.
1) When the PJ is warmed up, try the menus. Are their white on grey text a lot brighter than the Wii images? If so, I would suspect the converter, or its power supply.
2) Any reason why you are not using a DVI to HDMI cable?
It may be the bulb, or the projector's HV PSU. If you do throw it out, I will take it off your hands. My HS-50's blue panel damage is starting to annoy me, and your PJ might be an upgrade :-)
| Tyler - Fight Club
