Panny PT-L300U 1:1 mapping using Momitsu 880D - AVS Forum | Home Theater Discussions And Reviews
Old 10-27-2004, 11:34 AM - Thread Starter
ewclam9's Avatar
I am trying to produce 1:1 mapping using the VGA connection on the L300U with the Momitsu 880 Deluxe unit. Someone told me to try the following:
34020Hz, 6000Hz
0960, 0540
1184, 0072
0112, 0040
0567, 0005
0013, 0009
0001, 0001
This setting does not use the full screen of the LCD pannel. It left about 10 rows of pixels unused on all 4 edges. I think the L300U is doing some internal conversion and it makes the 960x540 smaller!
After some experiment, I come up the following setting to use the whole LCD panel.
34020Hz, 6000Hz
1035, 0540
1184, 0072
0112, 0005
0567, 0005
0013, 0009
0001, 0001
I am not expert in this thing. So I am posting them for any 300U owner to try. As you know, only the component and VGA can accept HDTV60 (1080i) signal on this 300U. With the above setting, my 300U sees the HDTV60 signal from the 800D DVD player on the VGA connection.
After you tried the above setting, please come back and tell us if it produces better PQ than the component and DVI connection.
To me, I think it gives better PQ than the DVI at wide786 and better than the component at 1080i. The color using DVI and VGA is more natual compared to component. The contrast using VGA is better than the DVI.
Have fun and please post your findings.
ewclam9
:p
ewclam9 is offline
Old 11-05-2004, 02:17 PM
cc2
cc2's Avatar
I tried (shortly) the VGA with your custom setting. So far (only 1 or 2 scenes from the matrix), I would agree with you. The contrast seems to be better. The details seem also better. I said seem since I would like to see the pattern in Avia to see if there is a difference. I should try it tonigh. Thanks for your setting, like I said before, I like to have fun with only the price of a VGA cable!
cc2 is offline
Old 11-05-2004, 06:07 PM
cc2
cc2's Avatar
After viewing the resolution pattern in Avia, I switch back to wide786. The signal was really degrading at around 4.0mhz. The signa with DVI wide786 was perfect at every level. Anybody looking for 25feet RGB plus a DVI-VGA adapter:-)
cc2 is offline
Old 11-06-2004, 03:20 PM
Monkey_Man's Avatar
Quoted: 85 Post(s)
Liked: 48
The 300u is incapable of 1:1 pixel mapping. You can get close but it will never happen. Shame on Panasonic.
Monkey_Man is online now
Old 11-06-2004, 04:39 PM
cc2
cc2's Avatar
What about sending a resolution that the projector is supposed to be handling better ie: 1080i via VGA instead of using the wide 786?
cc2 is offline
Old 11-06-2004, 06:17 PM
Monkey_Man's Avatar
Quoted: 85 Post(s)
Liked: 48
CC2:
Two years ago this board was full of people trying to make 1:1 mapping happen. Put it this way it never happened. One resolution came close but it was some odd ball rez operating at 49 hertz. I just remember it didn't work well with NTSC films.
Old 11-07-2004, 06:14 AM
cc2
cc2's Avatar
I remember the endless discussion about this 1:1 mapping. This was when I bought my Pl-300U. What I had in mind was to try the VGA at 1080i since the internal scaler of the projector was supposed to do a better job with this resolution because of the 1/4 HD panel. At that point in time, I didn't see any report for this resolution and I didn't have the DVI / VGA adapter. Thus I was always curious about it. Since I have now an adapter, I tried it last nigh and guest what...based on the resolution pattern in Avia, It is not better then the wide768 via DVI. Well... it cost me 20$ to try.
cc2 is offline
Old 11-07-2004, 06:26 AM
Monkey_Man's Avatar
Quoted: 85 Post(s)
Liked: 48
Nothing wrong with trying :) I know I tried everything to get it to work. The problem was the 300u had a odd ball rez that was never used in the PC world. Because of this is was never perfected. Panasonic also never updates firmwares on their products like Sanyo. I had the 300u and 500u and I jumped ships to the Z2 and I never looked back. Seems this is also happening with the new Z3. It's turning out to be a better PJ then the 700u. In terms of pixel mapping and VB.
Old 11-09-2004, 03:27 PM
rnranimal's Avatar
Is 1:1 possible with the 200u (via component or VGA)?
rnranimal is offline
Old 11-15-2004, 08:01 PM - Thread Starter
ewclam9's Avatar
Sorry to hear that someone spent or wasted money to try this rez. I am still using this rez and I still think its contrast is better than DVI. I do not have Avia and I just compare it with my old eyes. It may be just my imagination because I really like to see HDTV60 word in the Option menu :D
ewclam9 is offline
Old 11-16-2004, 04:58 AM
cc2
cc2's Avatar
Don't feel bad about it. Usually, my "try" are really more expensive. Anyway, when I first looked at it, yes it seems better with the exception of the details that had "frills". The AVIA pattern did confirm that the higher freq had problems.
cc2 is offline
Old 11-16-2004, 07:12 AM
cpc
cpc's Avatar
The AE 100 and 200 can do pixel perfect.
cpc is offline
Old 11-16-2004, 07:26 AM
Monkey_Man's Avatar
Quoted: 85 Post(s)
Liked: 48
Funny because when all the dreaming was going on with the 700u back in September I made a sarcastic comment about the 700u having a flaw like not having 1:1 mapping and it turned out to be true or was it over scan, I can't remember?
