Optoma H31 review & screenshots - Page 152 - AVS Forum | Home Theater Discussions And Reviews
post #4531 of 4539 Old 01-19-2010, 03:43 PM
orion456's Avatar
Originally Posted by nickwin View Post
Are you saying you want maximum zoom (biggest image) or the lowest zoom (smallest image)? It seems like the shortest zoom would allow you to put the pj closer to the screen giving you the brightest possible image.
You want the most zoom at the closest distance, which is around 11' = brightest image for that size.
orion456 is offline
post #4532 of 4539 Old 02-02-2010, 03:24 PM
nickwin's Avatar
Quoted: 24 Post(s)
Whats the most accurate factory setting on the H31 over DVI?
I am getting some seriously crushed whites on my unit that I cant seem to fix with the basic controls. Any advice on how to fix this?
nickwin is offline
post #4533 of 4539 Old 02-26-2010, 06:52 AM
dsb411's Avatar
Has anyone replaced the Color Wheel on their H31? Mine fell apart and I was able to get a new wheel for $59 plus shipping from Optoma. Can any one give me some pointers to cracking open the projector and replacing the wheel? Thanks!
dsb411 is offline
post #4534 of 4539 Old 02-26-2010, 10:37 AM
fleaman's Avatar
Quoted: 78 Post(s)
Liked: 121
uh, you didn't try to take it out before you ordered the CW?
(and sorry, I can't help here)
fleaman is offline
post #4535 of 4539 Old 02-26-2010, 11:46 AM
dsb411's Avatar
Uh, no. I know what the problem is so I was just going to wait till i got the part before I opened it up. Didnt want it lying open on a table for a week attracting dust. Thanks for your help. :/
dsb411 is offline
post #4536 of 4539 Old 02-26-2010, 12:01 PM
fleaman's Avatar
Quoted: 78 Post(s)
Liked: 121
no problem (though you should try to read my post before reply to something I didn't say )
fleaman is offline
post #4537 of 4539 Old 02-26-2010, 01:42 PM
dsb411's Avatar
Not much to read. No offence, but it was kind of a pointless post.
I'll just wait patiently until someone with some useful knowledge comes along.
dsb411 is offline
post #4538 of 4539 Old 02-26-2010, 02:13 PM
fleaman's Avatar
Quoted: 78 Post(s)
Liked: 121
Yes I know, hence my 'sorry' in my post.
Never the less, there might be something for others to learn here: Take your CW out before you order a new one.
fleaman is offline
post #4539 of 4539 Old 03-01-2010, 06:34 AM
dsb411's Avatar
why?
dsb411 is offline
