X1 can't install USB driver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-18-2004, 09:37 AM - Thread Starter
kkramer25's Avatar
i'm trying to update my firmware to 4.3, running 4.0. my Windows XP box will not let me update the driver to the Infocus driver. it keeps using usbccgp as the driver. i thought it was a SP2 thing and uninstalled SP2, but still the same result. anyone out there run into this...
kkramer25 is offline
post #2 of 6 Old 12-18-2004, 05:34 PM
Mike777's Avatar
I think the USB driver is different than updating the firmware. You have to follow the instructions precisely, especially the part about holding down the buttons on the X1 while turning it on.
Mike777 is offline
post #3 of 6 Old 12-18-2004, 05:59 PM - Thread Starter
kkramer25's Avatar
i have upgraded before (pre-SP2). you have to have the X1 driver installed. i cannot get XP to let me change the driver to the Infocus driver. thus i cannot proceed to the firmware update utility.
post #4 of 6 Old 12-19-2004, 12:59 AM
bighifi's Avatar
Quoted: 27 Post(s)
You have to Hold both the Keystone Keys when you power on the projector. Then you can choose the right drivers.
If I agree with you then we will both be wrong
bighifi is offline
post #5 of 6 Old 12-19-2004, 07:36 AM - Thread Starter
kkramer25's Avatar
thanks. i was reading that to be after xp saw the device correctly. not to install the device... never thought i'd be a RTFM victim
post #6 of 6 Old 12-19-2004, 09:53 AM
Cyrano's Avatar
Liked: 90
Those two buttons have caused a number of postings like yours. Glad you got it.
Cyrano is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
