Hi, and greetings from Finland
I have had Kodak Dp 1050 about 1 year and i'm very happy with it
used it mainly for looking sport from digital tv(set top box) with composit video.
Now i want to look also DVD movies and bought player with Pro.scan future. connection via VGA and also normal picture via s-video connection.
S-video picture is good and ok (1024x768 resolution)
But i have trouble with VGA, without Prog.scan picture is good except there is horicontal lines (light gray) in back side of picture ( not visible all the time, but sometimes and they are not so bright, but they are there.
And resolution is only ? 640x480 and PJ also informs horizontal 31.1 kHz (-)
and vertical 49 hz (-) what these mean ?
And if i turn Prog scan on, the image is all green, visible and clear but green ?
I use PJ:s own cable for VGA connection and version info says
DL x10 I i have upgraded k version to L ,but is this right version ?
thanks
I was e-mailing this issue with mflaster, and i want to thank him for VERY fast replys and very pro DAVIS support site. And he said i should put this in here for all to see it
seppo
Ps. Santa is from Finland !
thanks
seppo
