Toshiba tdp-t1 HD viewing - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-31-2005, 01:02 PM - Thread Starter
loosechange911's Avatar
I've had this Toshiba tdp-t1 for a few years now with no issues. Recently I've acquired the Comcast HD decoder from motorola DCT6200 and have had quite a few problems getting the HD signal to work on the projector. First things first though, my troubleshooting efforts thus far:
The problem:
If I turn the projector on first, then the DCT I'll see the HD image for a brief 3 seconds (quality looks good, but I also see horizontal lines scrap too) than blank screen. If I had to decribe it, I would say the projector is trying to adjust the image and cannot. Almost as if the refresh rate or signal is causing the projector to fail.
My actions.
-Ordered a cable from in-focus - M1 to DVI-D (30')
-Verified the cable works (Plugged my laptop dvi out to it)
-As I was able to see the image, the projector M1 input obviously works.
-Verified and checked that the projector will accept a 1080i signal. It's stated 3 times in the manual.
-Plugged the projector into the decoder using the s-video cable - ok
I'm about to contact Comcast to inquire if the decoder itself has issues, but I'd rather make that the last resort as I'm doubtful they'll help. I also wanted to check the componant out of the decoder, but couldn't find a componant to M1 or a componant to dvi-d female plug.
Any help or experience with the projector would be great. Any confirmation that it should work would at least send me to the right direction.
loosechange911 is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
