Optoma H27 review and screenshots - Page 26 - AVS Forum | Home Theater Discussions And Reviews
post #751 of 760 Old 04-10-2007, 01:02 AM
bkkumala's Avatar
Originally Posted by rickster904 View Post
Do you have HD source? If you do then IMO you should not consider 480p for a new purchase.
But ... The price on the HD70 package seems high. I know you probably need to pay more in Indonesia, but I think the HD70 package should be within $500 of the H27 package.
Another consideration is that the HD70 contains a white segment on the colour wheel to boost its brightness. This makes it harder to dial in the colours accurately. If you are not a hard core purist this is probably not a big deal. On the other hand if you don't have 100% ambient light control in your HT the HD70 might be a better choice.
I have owned a H27 for 18 months mainly for DVD viewing in a bat cave. This thing gives a beautiful picture. I haven't upgraded to one of the budget 720p DLPs yet mainly because of the white segment concern.
In short to make a decision you should consider the following.
- Price
- HD sources
- HT environment
- White segment might be a concern to some but not to others
thanks rickster
Yes I have to pay more in indonesia...
I alradey came to decision to H27 , even its already discontinued...
in 18 months life-time , did you have any major problem foe your H27.... and how about the lamp replacement ..?
thx again for your share
regards
bk
bkkumala is offline
post #752 of 760 Old 04-10-2007, 03:33 AM
niknik's Avatar
I'm interested in the lamp replacement issue as well. I think H27 is the kind of "picture-thrower" you dig out from your attic in 30 years and hook up to watch something with the family. Then you throw frases around like "what a funny old thing", "still working and it was one of the good small ones back then!", "it's not that bad! Cool!" and "but it makes a hell of a noise! -and we actually thought it was pretty silent back then, how old fashioned.." (that's my hope anyway, I hate all electronic devices that makes any kind of noise).
Ok I'm rambling, but maybe one should buy a pair of extra bulbs now? How long does Optoma keep these in production -I mean do they have a policy in this area?
niknik is offline
post #753 of 760 Old 04-10-2007, 11:19 AM
rickster904's Avatar
I have had zero problem with my H27 in 18 months. I bought a spare lamp when the old lamp was at 600 hours. I have been using the new lamp since then. Both lamps are still good. Things I like:
- Beautiful DVD picture. I don't use it much for anything else.
- VERY quiet. (niknik, I can hardly hear the H27 now. In 30 years I am sure I won't be able to hear it.)
- Zero maintenance required. The air flow only goes through the lamp housing. No dust gets into the optical portion of the pj.
One thing to watch for:
- The H27 has very large offset. I started by tilting the pj upward in my basement with low ceiling. (I had to use keystone correction.) This issue was resolved by a DIY screen tilting downward by 10%. I now get a perfectly square image without using keystone correction.
rickster904 is offline
post #754 of 760 Old 04-19-2007, 01:21 AM
bkkumala's Avatar
@rickster904
finally I bought Optoma H27 + 92 inch fixed screen for abt US$ 864
maybe you can share the calibrating or tweaking process to install
that unit is on the way to my location... may be 2 or 3 days will come to ours..
I have a dvd player with hdmi.... and components
which one is better .... to connect with......
10 mtrs HDMI cables is too expensive i think
except from monoprice its only US 7....
but i'm still negotiating abt shipment and payment
regards
budi
bkkumala is offline
post #755 of 760 Old 04-19-2007, 02:18 AM
niknik's Avatar
Congrats!
If you search a little there are some settings posted around here somewhere.. I have them printed out somewhere -so if you can't find them I could post them later....
I would go with HDMI...
niknik is offline
post #756 of 760 Old 04-19-2007, 09:26 PM
bkkumala's Avatar
Originally Posted by niknik View Post
Congrats!
thx.
will search slowly ..... page per page . hehehe
bkkumala is offline
post #757 of 760 Old 04-20-2007, 04:59 PM
I do find DVI a bit cleaner than components, but not by much. I use Avia for simple tweaking. I didn't have to deviate much from the default settings, but every pj and/or environment is different. So get a calibration disk for yourself. It's a good experience - and fun, too.
post #758 of 760 Old 04-25-2007, 08:09 PM
bkkumala's Avatar
to
rickster904 or all senior here
I have tested my PJ last night and feel OK
while waiting for AVIA and Video essentials , this night will mount the PJ first...
One question
what is the difference between Optoma H27 and H27a
because mine is h27a
thanks
regards
Budi
bkkumala is offline
post #759 of 760 Old 05-01-2007, 01:21 AM
pawarujie's Avatar
It has been a while since i last posted here. I managed to repaint my screen with a more greyish paint and resulted in a better black level and improved contrast. Here are some photos.
Newly painted screen
Some newest screenshots
Swordfish
Kill Bill
pawarujie is offline
post #760 of 760 Old 06-26-2007, 01:55 PM
zyria's Avatar
Can someone explain to me why it'd be beneficial to upconvert the DVDs and then downconvert?
DVDs are natively 480p, as is this projector. So I would think that you would want to keep the DVD at 480p to get the original signal.
If your dvd player is converting up, the projector still has to convert it down, doesn't it?
zyria is offline
