Mitsubishi HC3000 MSRP $2,995 - Page 117 - AVS Forum | Home Theater Discussions And Reviews
post #3481 of 3493 Old 11-24-2010, 04:14 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
It helps if you take digital photos as your take things apart, I have done this with every projector I have disassembled. It can be very helpful when it comes time to put it back together. I was an auto mechanic for many years prior to digital cameras.. and many a time I wished I had a picture when putting back together major engine and dashboard jobs!
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3482 of 3493 Old 11-24-2010, 05:19 PM
golffnutt's Avatar
Quoted: 85 Post(s)
Originally Posted by Scummer View Post
I called 888 307 8404 and let them know that I need a color wheel with the part# 499-D094030.
They faxed me an order form where you can put the part number, quantity and price down and you fax it back to Mitsu part supply with your CC info and you should be having your new color wheel in about 3 business days.
Besides fax, they can also email you the order form.
So, once you have the color wheel in your hands, that's how you proceed:
1. Take the 1 screw out from the lamp lid, remove the lid and unscrew the 3 screws that hold the lamp down. Remove lamp and place in a secure place.
2. Remove the 6 screws from the bottom of the projector and remove top projector lid, exposing a metal shield enclosing the mainboard, a few fans, optics and so on.
3. Remove the screws, which hold the top part of the metal shielding down and remove that shield, exposing the mainboard in the process.
4. Remove all those small connectors from the mainboard. Little tuck here and there and they should pop off.
5. Take all the screws out which hold the mainboard down, careful with the copper tongues, so they don't fall into the projector housing.
6. Removing the mainboard is a little difficult as there is a double sided sticky foam holding the mainboard down. You can see that by shining a flashlight underneath the mainboard. Just pull up the mainboard a little and it will slowly come loose. Once the foam is loose you should be able to completely remove the mainboard.
7. Remove the metal shielding that is exposed now after removing the mainboard.
8. Remove the two small fans in the back of the projector, one is for cooling the lamp, the other cools the DLP chip.
9. Remove the metal shield sitting behind the DLP chip's cooler. 3 very small screws are holding that shield down.
10. Remove the power plug for the lamp, which is being held down by 2 screws.
11. Remove the lamp housing, which is being held down by 3 screws.
12. Now remove the lens/mirror/DLP chip/color wheel assembly which is being held down by 4 screws.
13. Once you got that assembly in your hands, easy access to the color wheel's motor connector. Unclip the flat cable that powers the color wheel motor and remove the cable tie.
14. Remove the two small screws from the color wheel base and replace the old color wheel with the new one.
Reassemble going the steps backwards.
I don't think I have missed something, I may have since I just had a few margharitas and I wrote this down from memory... but hey, if you're not mechanically inclined, I wouldn't suggest you try it anyway.
Enjoy your fixed HC3000.
Thomas
Thanks Thomas for posting this info. It will be a lot of help.
Thank you.Golffnutt"GO DAWGS" !!!!!!!!!!!!!!Panasonic PT-AE 8000U Projector with 10' Screen // Samsung 65" TV UN65KS9500F // Denon X6200W Receiver // Oppo 203 4K Player // Pioneer Elite BDP-05FD Blu-Ray Player (Great CD Player and Excellent Blu-Ray Player) // PSB 9.2 speaker setup with 2ea. M&K 12" Subs // Panasonic Surge Protector // Monoprice Premium Cabling
golffnutt is offline
post #3483 of 3493 Old 11-24-2010, 05:26 PM
golffnutt's Avatar
Quoted: 85 Post(s)
Hey guys I have a question for those of you who are operating your 3000 with a Harmony Universal Remote.
I have the Harmony 890Pro with the RF extenders. I have no porblems operating any part of my 3000 except for one thing, turning it off. Of course as we all know turning it off is a 2 button affair. I have mine programmed now so that my remote, for example, will turn on my receiver, my sat box, and my projector at the same time. It will also turn off the receiver and sat box but will only get to the screen that asks you if you want to turn off the projector, but it WON"T turn it off. I can't for the life of me get it to turn off. Can any of you tell me what I need to do in the programming side of the remote to get it to turn the projector off? I would REALLY, REALLY appreciate it if you could help me out here, this is driving me and my very tech savvy son absolutely crazy. Thank you so much for trying to help me. Any by the way, May you all have a very safe and Happy Thanksgiving.
golffnutt
post #3484 of 3493 Old 11-25-2010, 08:02 AM
jtalden's Avatar
I don't have the Harmony, but also had some problems. Maybe these thoughts will help.
[I noticed that even manually there is difficulty turning off the H3000 if the sat AVR is shutting down first. The loss of HDMI signal to the H3000 interrupts the response to the off commands for maybe 1-3 seconds.]
> Try to shutoff the H3000 first, before the Sat and AVR.
> Optionally you can always create a longer series as, "off-pause-off-pause-off-pause-off-pause-off commands that eventually will be recognized even if it is not the first unit shut down.
> If one of those doesn’t work, be sure you are including enough pause time between the 2 off commands.
jtalden is offline
post #3485 of 3493 Old 11-26-2010, 11:12 AM
golffnutt's Avatar
Quoted: 85 Post(s)
> If one of those doesn't work, be sure you are including enough pause time between the 2 off commands.
Thank you for those words of advice. I tried it your way and it still won't work. I guess the remote is just defective. I give up, too frustrating but again thank you for trying to help me.
post #3486 of 3493 Old 12-09-2010, 09:42 AM
JWKessler's Avatar
Back in 2007 Cine4Home.com posted a review of this projector that included disassembly and a lot of good photos inside the unit. Being a pack rat I saved that review as a PDF. I just checked the original link and see it is not there and was unable to find that review on their site. If you want to see the PDF version, I posted it here.
http://nineveh-junction.com/binaries...hi_HC-3000.pdf
JWKessler is offline
post #3487 of 3493 Old 12-09-2010, 10:28 AM
golffnutt's Avatar
Quoted: 85 Post(s)
Thank you very much JWKessler for that info. I still love my 3000 and have not been convinced to take the 1080p jump yet due to my 3000's super picture quality. Just wish I could find a cheap source for the genuine replacement lamps, I go thru one about every 10-12 months as my projector is used as a TV and not just a movie projector only. Have a great and safe holiday season and thanks again for your post.
post #3488 of 3493 Old 10-29-2012, 10:34 PM
Shift's Avatar
Quoted: 94 Post(s)
Liked: 65
I just pulled mine out of storage since mine been on a 2-year sabbatical leave and notice it only has 540 hours.
My next upgraded PJ will be the BenQ 7000W but before I budge I am just going to get it all hooked back up once we close on our house and if it makes me still smile as it did two-years ago, I think I can hold off for another 500 hours wink.gif This time it should not take as long to add the other 500+ hours (haha)
Either way upgrade is calling soon. The HC3000 will still find a corner of my house to be used, maybe as a backyard party PJ or put into the family room with a portable screen for Super Bowl party. smile.gif
Anyone else still own their hc3000's??
Preponderance
1: a superiority in weight, power, importance, or strength
2a : a superiority or excess in number or quantity
2b : majority
Shift is offline
post #3489 of 3493 Old 10-30-2012, 07:06 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Every night.. put it on the table, put up the screen (one of the last HP 2.8 screens made) .. 3000+ hours on my OEM lamp.. bought used with 4000 hours on the unit.. Have to upgrade the house before It makes sense to upgrade the projector.. even then I will probably just replace the lamp and wait another 3000 hours.. lots of other things to spend money on that will be a bigger bang for the buck the a new projector would be!
Good luck and enjoy!
Doug
post #3490 of 3493 Old 10-30-2012, 10:44 AM
Shift's Avatar
Quoted: 94 Post(s)
Liked: 65
That is amazing lamp life. I think by spec its only 2K lamp life. Good to hear they can last that long.
I really love the colors of this 3000. I also owned a 705HD and didn't like it as much, but loved the lens-shift option.
As in why I am still sticking to DLP and choosing the 7000w cause it has lens shift and also the throw distance and brightness will be better as i'm going to go with a 130" screen and need the extra lumens / throw ratio and big plus on lens shift. wink.gif
Preponderance
2b : majority
Shift is offline
post #3491 of 3493 Old 12-18-2013, 02:26 PM
wayneunit's Avatar
My almost 7 year old HC-3000 is still going strong and, in fact, just went over 4,000 hours on it's original lamp this past weekend! Still as sharp as ever (considering that it's almost 7 years old) and really doesn't appear to have dimmed much - always used on low setting. Not only that but I still have a new spare lamp that I got with my 4-year warranty. So I may still be using this thing in 2021! smile.gif
It is truly sad that Mitsubishi is now out of the projector business. I, for one, would have loved getting one of their 4k projectors in 2020 or so when they got under a grand! rolleyes.gif
wayneunit is offline
post #3492 of 3493 Old 11-18-2014, 10:44 AM
Liked: 0
Thought I'd post my fix to my HC1500 in case it helps anybody else out. The symptoms were noise, humming, and loud buzzing accompanied by flickering and picture loss. I assumed it was the (original) bulb since it has about 3500 hours on it. I bought a bulb which turned out to be a generic and which made things worse. After getting a refund on that, I sourced a bare Ushio bulb on Ebay (at $109, a bargain for a genuine bulb), but installing that didn't help either (the bare bulb is fiddly to change, but not too difficult once you figure out that the spring clip at the top of the bulb is held on by two tabs on the front top of the housing).
From the bulb enclosure, I could see that the color wheel housing was showing signs of breaking due to heat, so following Scummer's instructions (posted above), I dismantled the projector and got the color wheel out. I found it was possible to remove the lens/bulb/wheel assembly without removing the fans, but getting the fans out isn't a big issue anyway. For the faint of heart, this isn't a very complicated job, but it's fiddly, time-consuming, and requires a fair bit of patience. It might also be a bit hairy for anybody not familiar with circuit boards, you have to pull off the connectors from the main board, plus the ribbon connector from the color wheel. It's very helpful, as someone else mentioned, to take photos on your phone as you go.
Once out, the problem with the color wheel was immediately obvious. It's mated to a magnesium casting which on mine had suffered extensive heat damage, I found a photo of one somewhere else and mine was identical. It was warped, cracked, and looked beyond repair. You could see where the color wheel had been rubbing on the surface, in the corner next to the little metal window. The color wheel had some scoring on it and was very dusty, but I got lucky because all the scoring seemed to be on the outer edge of the wheel. I gave the wheel a good clean while it was out.
I called Mitsubishi, and the part is no longer available. It comes as a complete assembly with the housing and color wheel. So, I tried sanding it down which didn't work, so I had to get a bit more radical. Part of the corner had already broken off due to the heat, so I just broke off the whole corner. Unfortunately, it took the mounting point for the little metal window with it, so I had to superglue that back into place. The part of the housing where it screws back into the projector had also broken off, so when reassembling, I was only able to put one screw back in which seemed to hold it securely enough anyway.
Reassembly wasn't too difficult until the end. I got it all back together but it wouldn't power up. The symptoms were both lights would go green, the fans would start, then after a couple of seconds it would power off. I was pretty sure there was an electrical connection missing somewhere since it seemed to be failing at the point where it tried to start the lamp or the color wheel, but I couldn't for the life of me find anything I'd done wrong. The only thing I wasn't convinced about was re-seating the main circuit board, there are two connectors mounted underneath it that mate to the DLP circuit board underneath. There are two slots in the main board next to the screws which allow you to position it correctly, but I thought something might be wrong because the board still had some play in it. After much trial and error, the trick is to angle the board with the edge nearest the lens down and the rear edge up and sort of roll it into place. When you insert it like that, you can feel the connectors locating correctly and there's an audible click when they go in. You can tell right away if you've got it right.
Once I'd got the main board back in, it powered up fine. It now runs like new even with the old bulb back in! There's no noise, no flickering, the only sound is now the low hum it's always made since new. The second best thing is that out of probably 50 screws that I removed, I only had 7 left after reassembly, and at least two of those were from where the housing broke!
invisiblewave is offline
post #3493 of 3493 Old 11-18-2014, 10:51 AM
Liked: 0
One other thing to add. Don't buy a bulb from VisionUSA! Their Amazon advert said they were selling a V7 bulb. What I received turned up in YODN box, but was a cheap generic bulb (the warranty sticker had quite obviously been removed and replaced). After posting negative feedback, they did offer a refund AND a 1 year warranty in return for my feedback being removed (I have the emails to prove it). I took the refund and kept the bulb. The bulb was terrible, it made my symptoms even worse, and after a couple of months I decided to see if they'd make good on their promise. They didn't. I can't complain too much since they gave me a refund, but if they weren't willing to honor a warranty, they shouldn't have offered it. I would have posted this on Amazon, but once you've rescinded negative feedback, you apparently can't reinstate it.
