The 2nd Official Infocus 4805 Thread. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8121 Old 11-30-2005, 06:49 AM - Thread Starter
Super Moderator
Kysersose's Avatar
Quoted: 12 Post(s)
Liked: 34
Here is a LINK to the old thread.
Alright gang, everything directly related to the 4805 goes in this new thread. All other 4805 threads will be deleted.
I will leave open threads that compare the 4805 to other projectors.
Carry on...
EDIT: Please check out The Unofficial Infocus ScreenPlay 4805 FAQ by Ja Phule.
"Good... Bad... I'm the guy with the gun."
Ash - Army of Darkness
Kysersose is offline
post #2 of 8121 Old 11-30-2005, 06:56 AM
DanC-P's Avatar
Alright gang, everything 4805 related goes in this new thread. All other 4805 threads will be deleted.
Carry on...
Wow, I get first post in the new thread. A historical moment .
P4 HTPC, Infocus 4805, nVidia GeForce 6800 pixel mapped, Theater Tek 2.2, Bluegears X-Mystique 7.1 Soundcard, HK AVR-55 A/V receiver.
DanC-P is offline
post #3 of 8121 Old 11-30-2005, 07:25 AM
scooterboy's Avatar
Are you also going to change the title of the original thread?
Apparently, there can be only two.
"If you're not passing anyone, get the hell out of the passing lane!"
scooterboy is offline
post #4 of 8121 Old 11-30-2005, 07:31 AM - Thread Starter
Super Moderator
Kysersose's Avatar
Quoted: 12 Post(s)
Liked: 34
There can only be one................................. at a time.
post #5 of 8121 Old 11-30-2005, 07:33 AM
jwv651's Avatar
Does the 4805 put out a ton of heat...with a ceiling mount a couple of inches from the ceiling is this going to be a problem being that the heat comes from the sides of the 4805...am I looking at a problem here...I only have a 7 foot ceiling...and the 4805 will be 14 feet from the screen. Thanks
Joe V.
jwv651 is offline
post #6 of 8121 Old 11-30-2005, 07:44 AM
tradewinds's Avatar
Quoted: 12 Post(s)
Man, and I was hoping to be the first post in the 600th page of the old thread...oh well...dream on.
Don't forget to subscribe to this thread if not done so automatically.
My Riser | My LED Star Ceiling | My HTPC Build
tradewinds is offline
post #7 of 8121 Old 11-30-2005, 07:52 AM
Ja Phule's Avatar
There is some heat coming out of the 4805 but I don't think it's enough to be a fire hazard (I don't think the projector would even be able to be sold if it was).
But in my own way, I am King. Hail to the King, baby.
My Networked Media/Music/DVD Server
Ja Phule is offline
post #8 of 8121 Old 11-30-2005, 07:52 AM
Ja Phule's Avatar
How about linking the FAQ in the first thread?
Ja Phule is offline
post #9 of 8121 Old 11-30-2005, 08:06 AM
little_blaine's Avatar
I'm a first-time projector owner that jumped on the refurb 4805 deal last week, but I've been following the forum and contemplating a purchase for a long time. I just got the projector yesterday and hooked it up to my laptop for a simple test. Some information first:
1) The unit appears to be like-new. No visible signs of usage. Menu shows 0 hours on the lamp.
2) Firmware revision is 1.1.3
3) The laptop screen resolution is 800x600, connected via the enclosed VGA-to-M1 cable.
I just projected the image to a wall for the first checkout, but even so I was wowed by the clarity and vividness of the picture. However I did notice one problem: The right 1/3 of the screen shows a slight image distortion. The best I can describe it is as rising smoke or rolling clouds, moving from the bottom to the top of the screen. It is faint but noticeable to me, my wife didn't see it at all until I spend a couple of minutes pointing it out to her. Am I experiencing this (from the FAQ):
7.07. I'm noticing a slight pulsing in my picture, what is wrong?
Not to be confused with lamp flicker, for more information on lamp flicker, click here:
There seems to be an issue with the 1.13 and 1.21 firmwares on the 4805. Every now and then while watching on the 4805, there will be some slight strobe-like pulsings in the picture, some people notice it more than others and it seems to vary on anything that you watch, and is most noticeable in darker scenes.
The only solution to get rid of this issue is to revert to the original firmware that you can download here:
1.02 Firmware
InFocus is aware of this problem and is working hard to fix this. There seems to be a fix for this and is going internal testing as we speak Hopefully it will be available in its next firmware update.
If this is something that can be fixed with an upcoming firmware upgrade, I'll hang on the the 4805, otherwise I'll try to send it back for a replacement.
little_blaine is offline
post #10 of 8121 Old 11-30-2005, 08:16 AM
Ja Phule's Avatar
little_blain,
Sounds like you may have either a ground loop problem or a heat problem. It isn't sound like the "pulsing" problem discussed in the FAQ. Try a search for "ground loop" in the forum.
Do you see the image distortion on a blank screen (Press the blank button on the remote)? Have you tried any other sources other than your laptop? Could the distortion be coming from some of the heat out of the front of the 4805?
Ja Phule is offline
post #11 of 8121 Old 11-30-2005, 08:33 AM
skyehill's Avatar
Liked: 52
Quick question about my 4805. I've started noticing that the screen is "blinking" on bright scenes (or if I just view the white background. It's more of a constant shimmer/flicker visible during only bright scenes. Is this a product of the screen or the projector? It's a year old, has about 320 hours on it. The screen is painted Silverscreen by Behr. Thanks for any help.
edit: just read the faq about flicker. Mine occurs even after an hour of usage. I will try the method of putting the unit on high for awhile to see if that corrects it. I'm hoping it will, as this issue is really annoying on bright movies.
skyehill is offline
post #12 of 8121 Old 11-30-2005, 09:21 AM
Gushy's Avatar
Blaine
Do you have the pj sitting on a table? If so that distortion you are seeing is caused by the heat of bulb passing in front of the lens. If it looks kind of wavy, like something you'd see on a long straight road on a hot day, then it is the heat.
It is usually really noticible in bright white scenes correct?
The fact that it moves from the bottom to the top is consistent with heat waves as we all know heat rises.
Wife factor? Hell, my electronics keep me warm at night.
Gushy is offline
post #13 of 8121 Old 11-30-2005, 09:43 AM
tradewinds's Avatar
Quoted: 12 Post(s)
any updates on a new firmware for the 4805?
BTW - does anyone know what bug fixes, features/enhancements will be available in a future firmware?
post #14 of 8121 Old 11-30-2005, 09:56 AM
Thanks for the replies everyone, it sounds like my problem is from the heat rising in front of the lens (Gushy yes it is on a table and noticeable on bright scenes). I'll experiment some more tonight to confirm. What's the best way to deal with it, given that the PJ has to be on a table for a while until I can get a proper HT setup?
post #15 of 8121 Old 11-30-2005, 10:00 AM
skyehill's Avatar
Liked: 52
OK, I bumped up to high power and the flickering appears to have gone away, but now I noticed on the white screen that there appears to be "fumes", if that makes sense, like smoke on the right hand side of the screen on the bright white screen.
skyehill is offline
post #16 of 8121 Old 11-30-2005, 10:21 AM
Ja Phule's Avatar
Bob Wiliams (infocus engineer) mentioned they were testing out a firmware that supposedly fixes the "pulsing" issue. No mention of when it will be released. The September firmware update was finished many months in advance before finally being released, so I imagine it could take a few months for another firmware that fixes the pulsing issue to be released. We can always hope.
Ja Phule is offline
post #17 of 8121 Old 11-30-2005, 11:12 AM
boukante's Avatar
The clouds you are seeing are caused by the heat from the bulb. There is a density difference between the hot air from the bulb and the cooler air of the room as they mix. This same phenomena can be observed when you pour two liquids together, i.e. fresh water and very salty water.
The name for the lines are often refered to as "Schlieren" lines. Do a search for Schlieren Photography to get more detailed explaination of what is causing the lines. (I'd include a link, but I haven't done my 5 posts yet.
Jeff
Now I have 5 posts! Schileren Photography
boukante is offline
post #18 of 8121 Old 11-30-2005, 11:44 AM
Elfman's Avatar
Just renewing my subscription
Carry on.
Elfman is offline
post #19 of 8121 Old 11-30-2005, 12:05 PM
Alex solomon's Avatar
Carry on.
There ia an easier way to do this. From drop down menu, thread tools, click the option to subscribe.
I want to hear opinions from people who don't have a dog in the fight.
Alex solomon is offline
post #20 of 8121 Old 11-30-2005, 12:07 PM
spyder696969's Avatar
Liked: 123
Damn, I wanted to see just how big the original thread was going to get. Guess I'll just have to add up the two different ones now to get the grand total.
spyder696969 is offline
post #21 of 8121 Old 11-30-2005, 12:10 PM
Elfman's Avatar
Thanks for the tip, but I was already aware of that.
Just wanted to add to my post count.
I mean I am still a 4805 owner so I'll make it on topic I guess.
Umm... 600 hours and still going strong.
Elfman is offline
post #22 of 8121 Old 11-30-2005, 12:36 PM
Mako PJ's Avatar
Anyone using a Xbox 360 on the 4805 yet? Curious to know what differences you see from the Xbox1 to the Xbox360, and how the 4805 does in displaying the 360. Very pleased by the 4805 but wondering if I need to upgrade soon.
Mako PJ is offline
post #23 of 8121 Old 11-30-2005, 12:59 PM
Cataphract's Avatar
Do you guys make any adjustments to the Chroma and Luma Detail settings in the menu? I currently have both of them at 5, the default was 0, I think.
I have done the calibration using DVE and was wondering if those 2 need to be tweaked. Are there any patterns in DVE to calibrate these 2 settings.
I also have the 'Color Space' setting at Auto, is that the recommended setting?
Cataphract is offline
post #24 of 8121 Old 11-30-2005, 01:03 PM
nduda78's Avatar
I use my 4805 with my 360. I run it at 720p. I am new to the world of projectors, this is my first , just got it about 4 weeks ago. I know im not at true 720p res, but i can tell a difference over 480i/p for sure....I myself, am trying to find an article about how good the 4805 and 360 really are together....anyways, here are a few real bad pictures of the 4805 running Perfect Dark Zero on the 360.
blah since I am new, first post i cant post urls...i need 5 posts GRRRRR
nduda78 is offline
post #25 of 8121 Old 11-30-2005, 01:32 PM
swift535's Avatar
how's the 4805 do when sitting closer to the image?
i'd like to project at least a 70" image or so, but one of the couches is only a couple feet from the image - maybe 2-3 feet at the close end and 6ft at the far end.
i've heard about some SDE problems from reading around, so how bad is it?
swift535 is offline
post #26 of 8121 Old 11-30-2005, 01:41 PM
Russ D's Avatar
I received my Refurb 4805 yesterday and it was in great shape and for what I know (1st PJ) working great too. It is a great picture... but I think what I'm most excited about is the Fact that I Did Not buy a Plasma! I was so close and this deal, of which we don't mention, came along... How sweet it is.
There is one Small issue that someone may know about...
I'm attributing it to my VCR or Composite cable. When I play my VCR through the composite in of the 4805 there is a small 1/4" line across the bottom of the picture that is distortion of some kind. I rarely play my VCR and I don't think it's the 4805... But if someone might know what it is...?
RD
Russ D is offline
post #27 of 8121 Old 11-30-2005, 01:50 PM
Quaid's Avatar
swift535
The recommended seating is a distance away equal to 2x the image width. Some people are less sensitive to the SDE and sit at 1.5x with no complaints. For a 70" screen this means starting your seating at around 6' rather than ending there. If those seating distances are set in stone, you should possibly look into 1080p and a second mortgage
The only way for you to make a decision concerning SDE (or RBE for that matter), is to view it for yourself. No amount of forum advice will equal a personal viewing. See if there is an Audio Video store in your area, preferably a higher end store with dedicated light controlled rooms. The 4805 will be the bottom end products of a store appropriate for screening IME. If you find the 4805 at future shop or best buy or costco or the like, it will probably be their higher end and they will have terribly viewing conditions.
Quaid is offline
post #28 of 8121 Old 11-30-2005, 01:54 PM
chasw98's Avatar
RD
Ja Phule will know for sure, but I believe if you hit the overscan button on the 4805 remote it will clear up the line. I have never experienced it but I have seen it mentioned before in the TRUE "there can be only one" 4805 thread.
Chuck
chasw98 is offline
post #29 of 8121 Old 11-30-2005, 02:37 PM
Mako PJ's Avatar
Well, if you can some pics later that would be great. I am pleased with watching HDTV on my 4805 just wondering if you get that type of picture. If you can tell the difference between 480p and 720p source via Xbox and 360 that is cool for me to hear. If anyone else has input on this issue or can post pics, I would appreciate it. Right now, I am in wait mode over getting a 360 or PS3.
One other question, does anyone know if it will be possible to view Blu-Ray via component, right now I am watching via component thru a component switchbox??
Mako PJ is offline
post #30 of 8121 Old 11-30-2005, 02:40 PM
Bobby_K's Avatar
ok, I know this has been beaten to death but I am upgrading from my X1 (1st gen. with Faroudja) to either the SP 4805 or the 5000 and I am having a very difficult time deciding. Im hoping if I provide some info you all can help me decide.
theater room is dedicated, basement 0 ambient light.
screen is 92" 16:9 1.0 gain
PJ distance is approx 14 feet from the screen
min. seating is 12 feet from screen.
I watch mostly DVD's occasionaly play PS2 and will be adding HD satellite soon.
I have researched the 4805 extensivly, but because of recent price drops, I have to at least consider the 5000, right? . Is the 4805's DVD capability so much better than the 5000 that it is a big issue? Will the LCD produce less SD effect at 12 feet than the 4805? Isn't the fan in the 5000 much quieter? I like the idea of having 720p and 1080 native res. with the 5000...
please help me decide!
Bobby_K is offline
Infocus Screenplay Projector Sp4805
