SharpVision XV-Z3000 Projector (anyone know about it?) - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 132 Old 08-09-2007, 06:38 AM
Alex solomon's Avatar
Originally Posted by LP30 View Post
Does anyone know if this unit will do 92" at 12 feet? I know it's not supported in the manual, but an installer is saying it will. Seems to me Sharp would have very little reason to greatly under report throw distance.
I have mine at 10.5 feet for a 92" without zoom.
I want to hear opinions from people who don't have a dog in the fight.
Alex solomon is offline
post #122 of 132 Old 08-09-2007, 07:25 PM
LP30's Avatar
Without any zoom at 10.5 feet your setup is in line with the reported specs (I think 10'6" was the max distance for 92"). It sounds like it would be impossibe to keep the size at 92" a foot and half further back, so this installer is way off.
LP30 is offline
post #123 of 132 Old 10-01-2007, 12:33 PM
tradewinds's Avatar
Quoted: 12 Post(s)
I saw Forum sponsor VisualApex has a $200 rebate for the Optoma HD7100 for the month of October bringing the total shipped cost to $1049.
If you are having issues with placement of this PJ (VP4001, Z3K) and cannot get the Z12K MII for the low price, it is worth looking at the HD7100 for its lens shift and placement flexibility.
Art had compared the HD7100 and Sharp z3K:
XV-Z3000 vs. Optoma HD7100
Of the projectors out there selling for under $3000 this Sharp is definitely one of my favorites. It's ability to produce black levels rivalling other DLP projectors that use the Darkchip3 processor instead of its Darkchip2, plus excellent color out of the box, and lots and lots of usable lumens, make it one of my two favorite projectors in the price range. The other, would be Optoma's HD7100, which uses the Darkchip3. I should note that I believe the Sharp outperforms the Optoma at both black levels and shadow detail. The Optoma, has, going for it, lens shift, so it is a far, far more flexible projector in terms of placement, but if that wasn't an issue, I would favor the Sharp.
BTW - I am not a fan of Optoma so I am not sure what issues this PJ has.
My Riser | My LED Star Ceiling | My HTPC Build
tradewinds is offline
post #124 of 132 Old 12-09-2007, 01:36 PM
HDholic's Avatar
How's the fan noise? It would be about 3ft max right above my head. Will it be excessive?
HDholic is offline
post #125 of 132 Old 12-09-2007, 05:06 PM
countach711's Avatar
It is a tad noisy if you are underneath or slightly behind and on the left side, but the picture for the price is unbeatable in my opinion. THat is only if the fan is in high mode where I keep mine so the bulb lasts longer. The wife sits there and has never mentioned it. Any normal audio and you instantly forget about it until the movies over! I have no regrets, although I do plan to box mine in eventually.
countach711 is offline
post #126 of 132 Old 12-09-2007, 05:15 PM
HDholic's Avatar
Is the High Contrast + Eco lamp mode too dim or does it provide good "punch" still? How's 1080i deinterlacing?
HDholic is offline
post #127 of 132 Old 12-09-2007, 05:23 PM
I find those settings too dim for my tastes, but I like a bright, dynamic picture. Some of the lower fan settings were right on the border for me, but since I decided to keep the fan on high, I just went for the brighter settings. As far as 1080i de-interlacing I have no idea what you are talking about. I can say you need to sit about 8 feet away before you notice any pixilation and that's with a standard definition DVD.
post #128 of 132 Old 12-09-2007, 06:18 PM
Steve Dodds's Avatar
I cheat mine (Marantz version) a little in the HC+Eco mode. I run it with the contrast boosted a tad and BC2. This gives it just enough oomph for my 120" screen.
Although I confess I sometimes switch between Narrow and Medium depending on the film.
Steve Dodds is offline
post #129 of 132 Old 12-09-2007, 06:25 PM
HDholic's Avatar
Are you both using white screens? I have my eye on a DT500, so wondered if I should worry about it.
HDholic is offline
post #130 of 132 Old 12-09-2007, 07:01 PM
Itsdon's Avatar
I have the DT-500 and project onto a 92" matte white screen. I leave mine (for the most part) on Eco & HC which yields me the best picture. I admit that sometimes when I play dark movies (Underworld) that I switch to HB but I never need to increase the fan speed. I can only hear it if I listen for it, for the most part it just disappears when the movie starts.
I previously had the Sanyo Z4 which was absolutely silent and had some apprehensions about getting a louder projector but I tell you, five minutes into the first movie and all those worrisome thoughts went away. This is a fabulous projector. Much better than the Sanyo.
"Life is a toy, play with it"
Itsdon is offline
post #131 of 132 Old 12-09-2007, 07:06 PM
HDholic's Avatar
Why do put it in H.B. for dark movies? Wouldn't it raise black levels?
HDholic is offline
post #132 of 132 Old 12-09-2007, 07:32 PM
Itsdon's Avatar
Yeah but sometimes it just looks better, don't ask me why it just does. It's nice to have the choice though!
Itsdon is offline
