HD1000U Ceiling Mount - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 129 Old 02-02-2007, 05:26 PM
merlin2111's Avatar
i just went to hd and spent an hour trying to design a mount. i was going to go with the monkey mount but there were so many peices that they didnt have that i went my own way. only problem is that i got 8x10 sheets of plexi (like the monkey mount) and they are way to small.
merlin2111 is offline
post #122 of 129 Old 02-02-2007, 08:29 PM
Y2KFirehawk's Avatar
Y2KFirehawk is offline
post #123 of 129 Old 02-15-2007, 03:14 AM
jdang's Avatar
Can anyone confirm the weight of this thing? All documentation says 6.5 lbs, but someone else in here quoted 12lbs. That could be with mount, but if it is only 6.5lbs I'm not afraid of mounting this thing with drywall anchors. I plan on doing the wall mount from mount direct, but right up on the ceiling as far up as I can go.
jdang is offline
post #124 of 129 Old 02-15-2007, 05:10 AM
underwhelm's Avatar
The manual says 2.9 kg, which is 6.4 lbs. Though I didn't put mine on a scale, I'm inclined to agree. I mounted it without an assistant, and I don't think I would have done so if it weighed more than 10.
underwhelm is offline
post #125 of 129 Old 04-09-2007, 11:33 AM
msink's Avatar
Im very happy with my PMS ceiling mount. BTW, the ceiling mount also comes with a pole extension which enables you to WALL mount the PJ as well. If you want to wall mount, you can use the extension which comes down and away from the wall at a 45 degree angle. Enough to then mount the PJ away from the wall. This looks better than their wall mount. I didnt do that, but here are some pics of what I did do for a friend.
http://picasaweb.google.com/marksink...stallForFriend
Mark
msink is offline
post #126 of 129 Old 04-10-2007, 09:41 AM
programmergeek's Avatar
msink, looks good nice mount! Please pull thoes speakers out of the cornors though to get the most out of them they should be about 3' fron any wall.
Jason
Note: Any posts are of my personal opinions and not to reflect upon any business.
Jason@programmergeek.com
908 578-6466
programmergeek is offline
post #127 of 129 Old 05-07-2007, 10:20 PM
Cacofonix's Avatar
Just a quick question about the PMS mount. I assembled it for use with my HD1000. I only used three of the holes on the projector. There is a fourth hole but it is too close to one of the holes. Is this what others have done?
Cacofonix is offline
post #128 of 129 Old 05-08-2007, 12:33 PM
dtviewer's Avatar
I ordered the mount from monoprice. It was about $16 plus shipping. Arrived very fast and was easy to put together.
The instructions it came with were a joke. Luckily it was easy to put together anyway. Very sturdy and adjustable.
dtviewer is offline
post #129 of 129 Old 05-08-2007, 01:38 PM
Reid_T's Avatar
Only three of the holes are mounting holes, so it sounds like you did the right thing.
Reid_T is offline
