HD1000U Tweakers and Calibration Thread - Page 49 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #1441 of 1453 Old 04-07-2009, 05:52 PM
Jim McC's Avatar
Quoted: 194 Post(s)
Liked: 69
Originally Posted by Jim McC View Post
I have about 1515 hours on my HD1000, and obviously it's much dimmer. Do you normally wait until the brightness setting is maxed out in low power mode, and then switch to high power mode? How do you know when to switch to high power mode? Thanks.
____________________________________________________________ _____
Anyone ?
Jim McC is offline
post #1442 of 1453 Old 04-07-2009, 08:01 PM
jsegura3's Avatar
Jim McC, I got about a 1000 hours and I can tell it's getting dimmer as well. It doesn't help things when you got a new bright LCD in the next room!! My plan is when I feel the PQ begins to suffer enough I'll switch over to high power mode and then start looking at a bulb replacement. Hope this helps.
jsegura3 is offline
post #1443 of 1453 Old 04-08-2009, 06:53 AM
dogmanky's Avatar
Anyone ?
I just bump up the BC a couple notches when it seems dimmer. The BC essentially just bumps up the lumens the way I understand it.
dogmanky is offline
post #1444 of 1453 Old 04-08-2009, 07:25 AM
Legairre's Avatar
Quoted: 717 Post(s)
Liked: 360
Be carefull with BC. It can cause artifacts if set too high. Pause a movie and increase and decrease BC and you'll see what I mean.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is offline
post #1445 of 1453 Old 04-08-2009, 09:00 AM
dogmanky's Avatar
Yep. Especially noticeable on HDTV Sporting events. But it is a poor man's way to liven up a dimming bulb with correct tweaking.
dogmanky is offline
post #1446 of 1453 Old 04-08-2009, 11:17 AM
Legairre's Avatar
Quoted: 717 Post(s)
Liked: 360
Hey nothing wrong with getting the most out of the lamp. I'll gladly increase it as well if it allows me to get a little more brightness before I reach the 3000 hr mark.
Legairre is offline
post #1447 of 1453 Old 04-10-2009, 04:12 PM
Billbofet's Avatar
Quoted: 53 Post(s)
Anyone in this forum ever dealt with a dust blob on their unit and resolved this issue themselves?
Billbofet is offline
post #1448 of 1453 Old 04-12-2009, 10:05 AM
dovercat's Avatar
Quoted: 100 Post(s)
Liked: 45
Thanks talon95. I don't understand why they even have the Setup option. I know the Off setting definitely adds brightness.
Setup option is for convience with analogue sources. The analogue system for PAL has black at 0 Off, the NTSC system has black at 7.5.
In PAL areas, some dvds, satellite channel films, what have you, are wrongly transcoded NTSC to PAL without changing the black level and some people have players capable of playing imported discs, so it enables them to switch black level easily.
If you select the incorrect setup for your areas analogue, but then calibrate black level using brightness, it should make no difference, you just lose the ability to easily switch between formats.
In practice the different settings seem to have different gamma curves at the near black level.
dovercat is online now
post #1449 of 1453 Old 04-12-2009, 05:30 PM
Jim McC's Avatar
Quoted: 194 Post(s)
Liked: 69
Thanks dovercat. So what's the best setting to use in the USA when I use component for HD satellite, and HDMI for DVD's?
Jim McC is offline
post #1450 of 1453 Old 04-14-2009, 02:28 AM
dovercat's Avatar
Quoted: 100 Post(s)
Liked: 45
In theory setup 7.5 for USA NTSC analogue. I do not know what it should be in theory for digital HDMI or HighDefinition sources as the setting is a relic of analogue.
In practice if you calibrate brightness after selecting any of the setup options 0, 3.75 or 7.5 it will have the correct black level, you just lose the ability to easily switch black level between USA NTSC 7.5 and PAL or Japanese NTSC 0ff.
As I mentioned in the previous post, it appears to have an effect on the bottom end of the gamma curve, how apparant shadow detail is. In theory it should not, in practice it does. How obvious you want shadow detail to be depends on viewing environment, as light colored walls and ceiling will bounce light from the screen back onto it washing out the shadow detail. But if it comes out of black too rapidly, shadow detail maybe very obvious, but perceived contrast of bright scenes maybe less.
I own a Mitsubishi XD460U projector, similar software to the HD1000U. I personally use 3.75 then calibrate brightness, despite living in the UK where I should be using PAL Off. My viewing room is a batcave with a white screen.
post #1451 of 1453 Old 07-11-2009, 02:56 PM
hokie93's Avatar
Can someone give me a good setting. I'm at 1000 hours in low lamp cinema mode and I'm not getting the contrast and brightness I want.
hokie93 is offline
post #1452 of 1453 Old 07-11-2009, 04:43 PM
Jim McC's Avatar
Quoted: 194 Post(s)
Liked: 69
What setting are you talking about?
Jim McC is offline
post #1453 of 1453 Old 07-12-2009, 06:30 AM
Hugh Walton's Avatar
Below is a link to a post I created a while ago in which I collected all of the projector settings at the time. The list is now a little out of date, but plugging in the various settings might help. Keep in mind that no two projectors are identical, so the settings for one person may not work for everyone else.
http://www.avsforum.com/avs-vb/showt...n#post11278891
Hugh
Hugh Walton is offline
