Can PT-AX100U Benefit from Upconversion? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-01-2007, 06:19 PM - Thread Starter
frank1492's Avatar
I have been receiving mixed advice on this point. I am currently using a Samsung progressive scan DVD player, but was recently looking at a Sony upconvert. There is also the issue of using the component inputs VS HDMI.
Best Buy is having a sale on the Sony DVPNS75H.
Will I notice the difference on a 10' diagonal screen?
Thanks for your help!
Frank
frank1492 is offline
post #2 of 2 Old 01-01-2007, 09:54 PM
gwlaw99's Avatar
Well from a technical standpoint digital input should be better. A pure digital signal is, in theory, always better than a digital signal concerted to analog and converted back to digital.
The sony has a good scaler, it may or may not be better than the one in the ax100. If it is, then it is better to upscale using the DVD player rather than the projector.
I would make sure you read about the sony on the DVD forums as there are many valuable insights on this dvd player and how to set it up right.
gwlaw99 is offline
