Originally Posted by
Lawguy /forum/post/0
Here is another review by Cine4Home. Pick your translator.
http://cine4home.de/tests/projektore...harpZ12000.htm
I will try to address your concerns.
First, the HC3000 is not the equal of the 12k in PQ. It is really that simply. If you want better PQ go with the Sharp. If you are willing to sacrifice PQ for smaller size or less noise, go with the Mitsu.
It is not fair to label the 12k as "not bright." It is not as bright with the Iris closed. If you want it brighter, open the iris. It is simple as that. I run it that way myself when I am watching sports and don't want to be in a dark room. The HC3000 has no iris to close. Isn't it nice to have the option?
As for fan noise and size, pick your poison. Have you seen the dimensions of a Ruby, Pearl, Z20000 or RS1? Big projectors tend to be better. I can understand why you don't want to hear the fan. If you think it will bother you that much, don't get this projector. The projector is about 2 to 2 1/2 feet from my head. I hear it when it starts up. I have never been distracted by it during a movie. This is not a guarantee because it might bother you. Just my experience.
How do you plan to mount your projector?
