How do I test my video cable? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-18-2007, 02:00 PM - Thread Starter
raoul's Avatar
Quoted: 40 Post(s)
I just got an RS1. I have a DVI cable with two HDM/DVI adaptors on either end. I want to know if these are introduciing artifacts but I don't know how to see these. The RS1 makes film grain and MPEG noise more visible. Is there a set of test paterns that are noise free for me to use?
raoul is offline
post #2 of 2 Old 04-18-2007, 02:03 PM
Y2KFirehawk's Avatar
Hook up a PC via DVI and project the following pictures.
http://www.lynxxx.nl/barco/patterns/
I think that should do the trick. That way you are digital all the way to the projector.
Y2KFirehawk is offline
