*Official* Optoma HD80 thread - Page 119 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #3541 of 3555 Old 06-16-2014, 10:44 PM
tadawson's Avatar
As a tip for folks with what appear to be lamp problems, be certain that you get any and all crud off the color wheel photo sensor! A detailed read of the service manual (link posted a bit above . . . ) shows that sensor errors will also cause the projector to shut down and give the lamp error! This has happened to me a couple of times, and usually a quick cleanse with canned air will do it, and sometimes an alcohol swab . . .
But alas, I think my sensor is getting a tad tired, and so I will likely need to replace it at some point. Optima in their infinite (lack of) wisdom, no longer has the PCB with the sensor . . . but the opto source/detector at the *ONLY* part on the board . . . and it's leaded, so a component replacement would not be in the slightest bit challenging *IF* I can find a compatible part, and unfortunately, mine has no visible markings, and I have no desire to pull it apart while it is still working . . .
So, might anyone know the component part number (*NOT* Optoma number - component part number . . . ) for this opto detector?
And also, does anyone know the level of/have current firmware for the HD8000/HD80LV?
- Tim
tadawson is offline
post #3542 of 3555 Old 08-25-2014, 03:10 AM
Liked: 0
Unhappy Burned Out Power Supply - HELP!
Hi all
My Optoma HD80 decided to die in a big explosion. With the help of a friend, I've opened the box. Apparently, a bug flew in (A real bug) and caused the the whole power supply to fry.
Where can I find a new power supply or a used one for this unit?
Thanks in advance, Eran
esorek is offline
post #3543 of 3555 Old 10-08-2014, 04:52 AM
Enigma_2k4's Avatar
Unhappy Remote and shutdown issues
So I've tried reading thru many of the pages here but when there are 119 of them it's going to take quite a long time!
My Optoma HD80 is having 2 issues:
1. My PJ shuts down VERy quickly when there is no signal detected (like a matter of seconds). Furthermore, if I switch inputs on the PJ it also shuts down. Lastly, if my source changes resolution then the PJ shuts down too. Can anyone point me in the right direction in this regard?
2. my PJ doesnt receive infrared signals anymore. I've tried with the standard remote and even also bought a new universal remote, that doesnt work either (yes, I've programmed it, etc).
Does anyone have any experience / ideas what I can take a look at too have fixed please? I love this PJ and really want it rocking again....
Enigma_2k4 is offline
post #3544 of 3555 Old 10-08-2014, 11:23 AM
jenielsen's Avatar
Maybe there are still some others who have this projector, but I think not many.
Quite a few people have jumped ship to "something better" over time, but maybe those still subscribed to this thread can also input any advice.
I still utilize my Optoma HD80 almost daily, and have never experienced the issues you describe. Based on your issues, I would ask if you have cleaned the unit regularly or tried to ascertain whether dust is a contributing factor in heat production? That might be my first thought, although it's a bit odd that it only happens upon source switching/no signal. Secondly, I might think it has to do with the electronics - something in the source switching mechanism. This might also be the issue with the remote (electronics).
You might also check out the service manual located here in post 3539: *Official* Optoma HD80 thread
jenielsen is offline
post #3545 of 3555 Old 10-08-2014, 12:33 PM
tanman's Avatar
Quoted: 175 Post(s)
Liked: 134
Enigma_2k4: Check your bulb (number of hours) replacement maybe needed and system maybe overheating due to dust.
tanman is offline
post #3546 of 3555 Old 10-11-2014, 09:51 PM
Liked: 0
I am a total newbie. I have had an optoma hd80 for a few years. changed the bulb twice. This is my third bulb and after only 50 hours the screen is giving me the purple tint. I have not cleaned it out yet. I have gone through the factory menus and done the spoke wheel test etc...
The regular menu display looks ok, it is white/black/blue icons. It is just the picture/video/or source that is all tinted purple. I have checked all my hdmi cable on other tvs and it works fine.
I would just like to try to upgrade the firmware on my system first before trying to open and clean it.
Let me know if anyone still has the newest firmware for HD80. It would be most appreciated.
You can send it to this email address. rudy at thekidworkshop.com
Thank you in advance!!!
imaginegate is offline
post #3547 of 3555 Old 10-13-2014, 12:25 AM
Enigma_2k4's Avatar
@jenielsen
Thanks for the service manual link, I have printed it out and will take a read thru and see if there is any pertinent info.
@tanman
Thats a very good point. I've never cleaned it so I think I will give that a go tomorrow (we have a public holiday then). Esoecially now that I have the service manual. However, as the issues is coming up immediately from when the machine is cold I doubt its a heat issue.
post #3548 of 3555 Old 01-14-2015, 05:06 AM
PaulKemp's Avatar
Hi duders!
How is the Optoma HD 80 holding up today, in early 2015? From my point of view, I can get a used HD80 for under half the price of a Benq W1070 / Optoma HD141x / HD26. This is in NOK, but still, around 400$ for the HD80 used, compare to the 1000$ for the other modern budget projectors.
Even if I add in a new original lamp, for around 100$, this is still pretty cheap. With a used framed screen, I can get a way with only around 500-600$ for the whole thing.
Note that the dollars are in Norwegian Krone, so the prices does not compare to the US or UK.
PaulKemp is offline
post #3549 of 3555 Old 01-14-2015, 10:18 AM
jenielsen's Avatar
If you can get a used Optoma HD80 for 400 Krone (~$55 USD) I would go for it. It has been a great PJ over the years.
post #3550 of 3555 Old 08-20-2016, 02:28 PM
rtchinn's Avatar
Quoted: 17 Post(s)
Hunting for HD80 firmware
My HD80 (like others I've read) is "touchy" with regards to Input source selection, input source mode changes, etc. It will shut off if anything upsets it.
I have found the Optoma pdf document on How to install HD80 firmware, but I can not find the firmware file.
Anyone?
rtchinn is offline
post #3551 of 3555 Old 08-20-2016, 03:27 PM
jenielsen's Avatar
Hi rtchinn,
Send me a PM with your email and I can send you the firmware. I will Zip it and send it later when I get to my home computer. FYI, your email provider may see the firmware as spam so make sure to check your junk mail.
post #3552 of 3555 Old 08-20-2016, 03:30 PM
jenielsen's Avatar
BTW, congrats on getting your extended life out of the HD80! I finally changed mine out after 2 lamp changes and a new color wheel about a year ago.
post #3553 of 3555 Old 08-31-2016, 07:48 AM
Liked: 0
I've had my hd80 for a couple months now after being given it to me for free .its been all in all a great unit I've been using it for gaming @60 hx and watching tv 30hz ,but yesterday after switching from cable to my xbox it froze on a family guy image (I was watching family guy at the time I switched) it was frozen on the still image of Peter griffin in green pixels lol .what could be wrong ? If I go watch my cable it'll work like it did ,if I switch back to the Xbox it still display the green pixel like screen nothing from the Xbox gets displayed.
Please before I go and purchase a new cheap unit
Jordanhd80 is offline
post #3554 of 3555 Old 09-10-2016, 11:01 AM
khillyard's Avatar
Originally Posted by jenielsen View Post
Hi rtchinn,
Hi Jenielsen,
Would it be possible for me to get that firmware as well? I am having a couple of issue with my HD80 and would like to try the latest firmware before determining if I need a new projector.
khillyard is offline
post #3555 of 3555 Old 10-04-2016, 08:31 AM
Liked: 0
Originally Posted by khillyard View Post
Hi Jenielsen,
Ditto on this, if I can get a copy of the firmware I'll be happy to post a google drive link or similar.
survient is offline
Optoma , Optoma Projectors , Optoma Hd80 1080p Home Theater Projector
