*Official* Optoma HD80 thread - Page 49 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #1441 of 3549 Old 09-27-2007, 09:50 PM
guitarman's Avatar
Quoted: 12 Post(s)
Woo hoo! Wing just emailed me. The HD80 new firmware is up on the Optoma website, again that's "is up on the Optoma website. Go get it, go slow, read the instrux carefully. Windows XP needed, it really is a snap to do, you should have no problems.
Let it roll!
PS, just look up HT projectors on the site, look for your HD80. The procedure and firmware is right there in a power Icon.
Tom/guitarman
VideoDementia
Are you twisted also?
http://www.videodementia.com/sales/TomWithWires.jpg
guitarman is offline
post #1442 of 3549 Old 09-27-2007, 10:39 PM
mbw23air's Avatar
Quoted: 117 Post(s)
Liked: 87
Sweet. Here is the link:
http://www.optomausa.com/Product_det...product_id=331
The download instructions and firmware download are on the right side. When someone does it please report back how it went and if they notice any differences in 1080p@24fps.
Mike
JVC RS600(Calibrated with Chromapure using an iD3), Stewart Cima Neve 2.35 115" diagonal screen, Lumagen Radiance XD, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, Oppo BDP-93, Roku 4
mbw23air is offline
post #1443 of 3549 Old 09-27-2007, 10:46 PM
Lonely Surfer's Avatar
My HD80 now holds the iris setting after shutdown and turning it back on! It still doesn't show my Toshiba XA2 as providing 1080p24, but I think that will be the case until Toshiba provides a firmware update "forcing" the 24 (23.97 or whatever) frame rate.
The update was quite easy. Thank you, Tom.
Lonely Surfer is offline
post #1444 of 3549 Old 09-27-2007, 11:06 PM
mbw23air's Avatar
Quoted: 117 Post(s)
Liked: 87
So Lonely Surfer,
I don't have a HD80 just yet but when I read the instructions on the firmware upgrade it says when you connect the cable to your computer to be sure and pick the correct COM port....where is it you make this selection?
Mike
mbw23air is offline
post #1445 of 3549 Old 09-27-2007, 11:36 PM
SeVeReD's Avatar
Hi all, I've just been too happy with the hd80 and haven't felt the bug to stop by, but here I am and look what's out... the new firmware. I may wait a bit before trying, everything's pretty hunky dory with the hd80 and ps3, but I am glad they are on top of updating firmware and letting users do it from home.
SeVeReD is offline
post #1446 of 3549 Old 09-27-2007, 11:43 PM
Charles R's Avatar
Liked: 350
The new firmware loaded great. Now with Blu-ray movies I can hear the color wheel slow down with 24fps. From memory the opening chase in Casino Royale appears smoother... not earth shattering but improved none the less.
Home Theatre Tweets
16x9 120" | Mitsubishi HC7900DW | 7.2.4 Boston Acoustics & Power Sound Audio | Denon AVR-X5200W & AudioSource AMP 110 | OpenELEC/Kodi HTPC Build
Charles R is offline
post #1447 of 3549 Old 09-27-2007, 11:47 PM
mbw23air's Avatar
Quoted: 117 Post(s)
Liked: 87
You know I have been very impressed with the lack of problems people have had with the HD80. Most time people only post when they have problems but if you look at this thread there are only a very very very few minor little problems. Even the HD80 not displaying 24fps correctly is more of a subtle nuance than a real problem. The HD80 seems to be a very reliable projector.
Mike
mbw23air is offline
post #1448 of 3549 Old 09-27-2007, 11:50 PM
Rich4av's Avatar
I also could not get the XA2 to display 1080p24. There must still be a handshake problem and we'll have to wait for Toshiba's next firmware.
The PS3 is working OK at 1080p24. I checked the chase scene at the beginning of Casino Royale and see some smoothing. There is a very quick pan across large plastic tubes and I can remember 1080p60 was not as smooth. 1080p24 is a bit smoother.
So far, it looks great.
I also have the dilemma of whether to adjust brightness/Iris or Gamma as my settings are a bit dark.
One note (I hope no one makes a big deal of this) - if you move your eyes quickly, you may see a few rainbows with white vertical lines - I surmise it is due to the color wheel turning slower...
Rich
Rich4av is offline
post #1449 of 3549 Old 09-28-2007, 12:10 AM
Originally Posted by mbw23air View Post
So Lonely Surfer,
Mike
You go into Control Panel/System/Hardware/Device Manager/Ports. My serial port was already set to COM 1, so I didn't have to do anything except hook up the cable and follow the update instructions.
post #1450 of 3549 Old 09-28-2007, 12:52 AM
robruffo's Avatar
When using the PS3 and selecting "full RGB", rather than "limited", blacks will totally crush-out UNLESS you connect the PS3 to the DVI port. If you do this (via an adapter) you will get more detailed blacks, and generally better contrast, than selecting "limited" and connecting via an HDMI port.
Selecting "full RGB" via an HDMI port gives, as mentionned above, very unpleasantly crushed blacks.
The wider color-range of the DVI port should be of interest to anyone using expanded RBG with any output device.
On my unit, it sure seems that changing the iris has no effect. I hear a clicking sound, but it seems the image does not change at all. Is this normal? Anyone else have this problem?
Are there any other improvements with the new firmware (besides 24p)?
robruffo is offline
post #1451 of 3549 Old 09-28-2007, 06:21 AM
Brajesh's Avatar
Quoted: 262 Post(s)
Liked: 91
Great news! Time to buy this PJ to replace my Mits HC3000U. Can't wait to match this PJ to my PS3 and soon-to-come HD-A35 . Now, where to get the best deal for the HD80...
HD Media Keen Videosaurus
Brajesh is offline
post #1452 of 3549 Old 09-28-2007, 06:48 AM
artoj's Avatar
Who will be brave (?) enought to be the first one to try this firmwire uppdate to the European market version of HD 80 a.k.a. Themescene
artoj is offline
post #1453 of 3549 Old 09-28-2007, 07:41 AM
Charles R's Avatar
Liked: 350
Full RGB uses PC levels (0-255) instead of Video levels (16-235). This will prevent you from seeing BTB and WTW. Most content is encoded with Video levells. If the DVI input is expecting PC levels then it would be the correct setting. If it's expecting Video levels then you would have some issues. Also when you change the setting you need to go back to the projector and calibrate your Brightness and Contrast settings as they will vary based on the setting.
Home Theatre Tweets
post #1454 of 3549 Old 09-28-2007, 07:45 AM
Sink's Avatar
Fantastic news on the firmware. My HD80 arrives this afternoon via Fedex. Do you think I should hook it up, as is first, and test it or do the firmware update and go.
Your thoughts appreciated.
Sink is offline
post #1455 of 3549 Old 09-28-2007, 07:52 AM
Charles R's Avatar
Liked: 350
I would test it out first to ensure every thing is working great. Then load the firmware.
Home Theatre Tweets
post #1456 of 3549 Old 09-28-2007, 07:55 AM
Sink's Avatar
Thanks Charles...I was leaning that way, but greatly appreciate your guidance.
Sink is offline
post #1457 of 3549 Old 09-28-2007, 08:41 AM
kermit@1's Avatar
Guiterman,
Can you ask Wing if this upgrade is also for the European HD80?
Brian
kermit@1 is offline
post #1458 of 3549 Old 09-28-2007, 08:53 AM
guitarman's Avatar
Quoted: 12 Post(s)
I wouldnt try it, in the past Euro firmwares had special tweaks for needs of the area. Plus you'll probably be voiding your warranty as the projector may have different readings not meant for the Euro market. Like our machines start up with a large Optoma logo, there may be other things also. If the repair headquaters there detects these they could figure you've tampered with the PJ.
Sorry to be a spoil sport, just thinking of any negatives.
Tom/guitarman
VideoDementia
post #1459 of 3549 Old 09-28-2007, 09:18 AM
kermit@1's Avatar
We europeans have to send the unit back to the factory for the upgrade. It will not be on the Optoma UK side. Thats the European.
kermit@1 is offline
post #1460 of 3549 Old 09-28-2007, 09:42 AM
mbw23air's Avatar
Quoted: 117 Post(s)
Liked: 87
Ok, thought it was somewhere like that. Thanks!!!
I'm really hoping for a small price reduction next week on the HD80, since it is the start of the 4th quarter. Right now I am $400-$500 from being able to get one.
Mike
mbw23air is offline
post #1461 of 3549 Old 09-28-2007, 10:44 AM
pww118's Avatar
There is an option in the Flash Tool screen to 'Create Binary File', I guess that is for backing up the existing firmware? If so, you guys may try the upgrade, if anything goes wrong, just put back the old firmware. Just a suggestion, don't blame me if...
pww118 is offline
post #1462 of 3549 Old 09-28-2007, 10:53 AM
Onkyo_805_owner's Avatar
Can you guys recommend a mount for HD80? I'm considering buying this one: http://www.perfectmounts.com/Everest...-p/everest.htm Does anybody know if it's a good choice?
Onkyo_805_owner is offline
post #1463 of 3549 Old 09-28-2007, 11:18 AM
jimas's Avatar
Why should there be a significant difference between the U.S. and the european models?
Why don`t they post the firmware on the U.K. site?
If i`m not mistaken,the projector is calibrated at the factory.
Upgrading the firmware resets the calibration?
How do i check which firmware my projector has?
Where does it say which version is the one i downloaded?
jimas is offline
post #1464 of 3549 Old 09-28-2007, 11:27 AM
robruffo's Avatar
Thanks Charles! (For your reply, your very generous settings, and your generally cool attitude
So... I'm still wondering, is there any difference other than 24p and saved Iris on the new firmware?
- Do others have the problem that the Iris does not have any visible effect when moved up and down in values?
- Does anyone think that the firware will make my Iris work, or does anyone have another suggestion?
robruffo is offline
post #1465 of 3549 Old 09-28-2007, 12:20 PM
Charles R's Avatar
Liked: 350
Do you hear the mechanical click when it's changed from setting to setting? The difference from one setting to the next isn't very noticeable and it takes a while to be reflected in the image. With the room fairly dark you should be able to see dark portions of the image becoming darker. I can see the intensity of the black bars on 2.35 material drop as I close down the iris.
Home Theatre Tweets
post #1466 of 3549 Old 09-28-2007, 12:40 PM
guitarman's Avatar
Quoted: 12 Post(s)
You should call the UK tech and ask if you can dowload off the US website. I be interested to hear what they say. You can only see the firmware in the service menu, it's been that way with all the Optoma projectors.
Tom/guitarman
VideoDementia
post #1467 of 3549 Old 09-28-2007, 02:19 PM
tanman's Avatar
To all those who have already upgraded the firmware,
Does the firmware change any of the older settings such as under "User" defined color, brightness, gamma, contrast, tint,...etc, etc?
T
tanman is offline
post #1468 of 3549 Old 09-28-2007, 02:23 PM
kermit@1's Avatar
Guitarman,
This is the answer of Optoma UK.
Hi,
Thank you for your e-mail.
The firmware will be available in the next two weeks & as far as I understand the US & Europe is not the same.
Regards
Customer Service
TSC Europe
tel: + 44 (0) 1923 691 865
fax: + 44 (0) 1923 691 888
kermit@1 is offline
post #1469 of 3549 Old 09-28-2007, 02:36 PM
Charles R's Avatar
Liked: 350
I believe it left them in place but as general rule I'd have a hard copy.
Home Theatre Tweets
post #1470 of 3549 Old 09-28-2007, 02:40 PM
guitarman's Avatar
Quoted: 12 Post(s)
Firmware usually resets everything even the hours so note them down also.
Tom/guitarman
VideoDementia
Optoma , Optoma Projectors , Optoma Hd80 1080p Home Theater Projector
