Reviews of Marantz VP4001? - Page 95 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #2821 of 2850 Old 03-05-2012, 12:15 PM
scooterboy's Avatar
Originally Posted by CZ Eddie View Post
Just so the newbies know, that is not an OEM, but a knockoff.
Scooterboy... how's it working out for you so far? Still doing good?
Yup - still going great.
"If you're not passing anyone, get the hell out of the passing lane!"
scooterboy is offline
post #2822 of 2850 Old 03-05-2012, 01:49 PM
scooterboy's Avatar
And one of my three fans is a "quiet" fan that I put in there at about 500 hours?
Hey, could you elaborate on this? I'm in the process of replacing the "main fain" (the one that exhausts most of the heat) in my Marantz, but still trying to find replacements for the other two.
What model of "quiet" fan did you use, and which fan(s) did you replace? I tried to replace a couple of my fans with Evercool 3-wire fans at one time and the PJ would fail start-up with a flashing red light.
I would LOVE to learn of a replacement fan that would be quieter than the ones in the Marantz. Any info would be much appreciated.
EDIT TO ADD: I just found your posts from back in 2010 about replacing one of the fans (and my replies ). Is the Nexus fan still the one you're using?
post #2823 of 2850 Old 03-06-2012, 10:46 AM
garciab's Avatar
Quoted: 156 Post(s)
Liked: 71
I too would like to hear more about this Nexus fan. TIA.
bg
garciab is offline
post #2824 of 2850 Old 03-30-2012, 05:06 PM
mommacux's Avatar
I got 2568 hours from this lamp. It's still going strong, but I have it in high output mode and want to refresh it to get high contrast back.
Resetting my hours and putting in a 100 hour AN-100LP OEM lamp I got for $87 shipped.
Where did you get that AN-100LP lamp for $87 from?
JUPITER and beyond the INFINITE...
mommacux is offline
post #2825 of 2850 Old 05-01-2012, 04:20 PM
CZ Eddie's Avatar
Quoted: 68 Post(s)
Liked: 33
It's been awhile but I'm pretty sure it was a Nexus fan?
There is a guy on eBay who sells OEM ~100 hour lamps for lots of different projectors.
I don't know or care why they all have ~100 hours, but the first bulb I bought from him like this lasted forever... so I was comfortable buying a second.
I just looked but can't find his ebay ID right now.
"The boom is dead, long live the bass"
CZ Eddie is offline
post #2826 of 2850 Old 05-28-2012, 08:51 PM
lousygolfer's Avatar
I bought a Mack bulb warranty when I replaced my bulb a few years back and a month ago the projector started blinking "Replace Lamp." After a few weeks of that, the brightness reduced by over 50% and the projector started shutting off after 1-2 minutes. So even though there was not yet a "pop" and obvious signs of the bulb blowing, as there had been on the two prior bulbs, it seemed obvious that my bulb was about shot, so I contacted Mack and obtained a new bulb. It is shipped from Pureland Supply and it is listed as an "AN-XR20LP" bulb.
So I replace the old bulb with the new one and vacuum off the projector, now that I've got it down from the ceiling mount. I moderately tighten the screws on the new lamp assembly, which fits fine, screw the lamp cover back on, and plug in the projector. It initially turns on and the fans whir for around 20 seconds and then it turns off, with both the STANDBY/ON and LAMP lights glowing bright orange.
I tried reinstalling the new lamp and putting the old lamp back in, too, but nothing happens - the two lights near the power button on the top of the projector glow orange and there's no signs of life.
I take off the cover and try to press the red reset button on the front of the unit. It does not depress. It slides out a few mm, but doesn't click, or do anything else that a button should do if it is operating properly. I screw the cover back on and put the power cord back in. Nothing happens, the same STANDBY/ON and LAMP buttons glare angrily up at me. I unscrew everything again, take the cover off, try to press the reset button again, but as was the case the first time, the button isn't depresing. This time, I pull the button out as far ais it will go, put the cover back on and still no signs of life.
Any suggestions on something I could do to try to cure the problem and get my projector working again?
lousygolfer is offline
post #2827 of 2850 Old 05-28-2012, 10:09 PM
scooterboy's Avatar
Use a flashlight and make sure all 3 fans are spinning up when you start the projector. If one of them doesn't turn, that's your problem.
post #2828 of 2850 Old 05-29-2012, 08:59 AM
No need to check the fans with a flashlight - they aren't operating. Nothing is - the only signs of life on the projector are the two orange STANDBY/ON and LAMP lights on the top. When I try to turn the unit on by both the large round standby button on the top and by using the remote (even installed new batteries), nothing happens.
Even if I got a bad lamp, the unit should still try to power on, shouldn't it? so I'm thinking it's not just the new bulb to blame.
post #2829 of 2850 Old 05-29-2012, 09:33 AM
scooterboy's Avatar
Ah - I thought that each time it would power up for 20 seconds before quitting.
Sounds like it thinks the bulb door is open or something like that. Strange.
post #2830 of 2850 Old 06-17-2012, 08:10 PM
utopia1956's Avatar
Scooterboy,
Is that Non-OEM lamp still working for you? How many hours do you have on it now?
utopia1956 is offline
post #2831 of 2850 Old 06-19-2012, 05:24 AM
scooterboy's Avatar
Not sure - I'll try to remember to look when I fire it up tonight.
ETA on 6/30: sorry - completely forgot about this! I'll try to remember tonight. The bulb is still going strong though.
ETA#2: I now have 960 hours on the bulb and it still looks good.
post #2832 of 2850 Old 07-07-2012, 05:47 PM
utopia1956's Avatar
Thanks for the info.
post #2833 of 2850 Old 07-08-2012, 12:33 PM
scooterboy's Avatar
Looks like I jinxed myself. The bulb just exploded.
Bulb had a 180 day warranty which ended a couple of weeks ago (of course).
Off to find another...
ETA: Just ordered from Apex Lamps - $188.75 w/180 day warranty. It claims an "OEM bulb with generic housing". We'll see.
post #2834 of 2850 Old 07-08-2012, 06:10 PM
utopia1956's Avatar
Bummer about the lamp. I don't think I'll be ordering one of those...better to stick with OEM. Good luck with the new one.
post #2835 of 2850 Old 07-09-2012, 05:07 PM
scooterboy's Avatar
But on the plus side, I just won an ebay auction for a non-working VP4001. Could be a simple thermal switch reset to get it going again, but at worst I get 3 of the VP4001 fans that are so hard to find these days. smile.gif
post #2836 of 2850 Old 07-17-2012, 05:39 PM
scooterboy's Avatar
Well my ebay projector arrived today. Non-original box, wasn't packed tightly so it might have taken a beating along the way. And no remote (tho none was promised). frown.gif
It was described as "will not power on".
Surprise #1: I opened her up on the dining room table and making a small wish, I pushed the red thermal reset button. CLICK! smile.gif
Surprise #2: I put the cover back on, plugged it in, and it started right up and projected a nice pure white image on the wall. Bulb works! tongue.gif
Surprise #3: I went into the menu, and there are a grand total of 34 hours on the bulb, with 98% life left. biggrin.gif
The auction description said it was used by a non-profit organization and when it failed to power up they decided to just buy a new PJ rather than take a chance that a new bulb would fix it.
So instead of having some backup fans and possibly a backup bulb, I have an entire VP4001 that's barely been used. Score!
Since this practically new unit is much quieter than mine (which has thousands of hours on it), I'm thinking I'll just swap this one onto my mount and put mine away for parts instead of the other way around. cool.gif
Oh - did I mention I paid $20.50 for the PJ plus $20 for shipping?
post #2837 of 2850 Old 07-18-2012, 04:55 AM
garciab's Avatar
Quoted: 156 Post(s)
Liked: 71
Wow, congrats on the great score!
bg
garciab is offline
post #2838 of 2850 Old 07-21-2012, 09:54 PM
scooterboy's Avatar
Thanks! I've put it up on my mount and duplicated the menu settings I had on my old one. The picture is beautiful, and the fans are much quieter.
post #2839 of 2850 Old 07-07-2013, 12:26 PM
CZ Eddie's Avatar
Quoted: 68 Post(s)
Liked: 33
Wow, my VP4001 must have ~10,000 hours on it now. I just installed my fourth or fifth lamp. At an average of $150 for each lamp purchased, I'm doing pretty good.
Got the latest lamp for $157 delivered here:
http://www.ebay.com/itm/251267588102?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
It's got that "new lamp smell" that is burning off right now. I don't remember the last time I smelled that smell since I bought the projector brand new. I hope I'll get some good hours from it.
The last bulb still had a lot of life left in it. But I wanted to get some contrast back (was in full brightness mode).
Super impressed that the VP4001 still looks great after 10k hours. No color issues or anything else. I just make sure to vacuum/dust every ~1000 hours.
CZ Eddie is offline
post #2840 of 2850 Old 11-15-2013, 06:29 PM
brianley's Avatar
I tried the OEM replacement bulb from the link above but unfortunately it blew after 10 minutes. Requesting a refund and looking into other options as I'm hitting 3k hours on the original bulb. Anyone have any other recommendations?
brianley is offline
post #2841 of 2850 Old 11-15-2013, 08:44 PM
CZ Eddie's Avatar
Quoted: 68 Post(s)
Liked: 33
That's too bad. Mine is still going strong several hundred hours later.
CZ Eddie is offline
post #2842 of 2850 Old 11-22-2013, 09:57 PM
brianley's Avatar
I tried the "guaranteed compatible" bulb (ANXR10LP/1) from ProjectorQuest (http://www.projectorquest.com/index.php/catalog/product/view/id/8410) and so far at least its working well. They list an OEM version for $70 more, but I assume its Sharp OEM, not Marantz.
brianley is offline
post #2843 of 2850 Old 07-24-2014, 02:21 PM
CZ Eddie's Avatar
Quoted: 68 Post(s)
Liked: 33
http://www.ebay.com/itm/251267588102?ssPageName=STRK:MEWNX:IT&_trksid=p398 4.m1439.l2649
Ended up with 2400 hours on that lamp and it was still working, but the projector decided to start shutting itself down. Simply resetting the hours would have fixed that. But I figured it's time to change.
My VP4001 now has 12,000 to 13,000 hours on it.
I'm going to order this lamp which is $57 delivered from Amazon Prime.
http://www.amazon.com/dp/B004609GBY/...I22AHVRD3T0CVZ
CZ Eddie is offline
post #2844 of 2850 Old 06-01-2015, 10:21 AM
KrisM's Avatar
Bumping this old thread, for some more bulb talk.
I picked up a bulb awhile back based on one of the reviews. I forget which one, but I think it was projectorquest.
Anyway, it worked, but wasn't as bright as an original. It gave up the ghost, so I order a couple more, from two different places. The first one(from a Canadian seller) showed up in a couple of days, and has issues. It will start up, warm up enough to show a picture for 13-15 seconds, then revert back to the warm up sequence with a blank screen. After doing this cycle a few times it shuts off, and the indicators are red.
I have two 4001s, and the problem is the same on both.
Thoughts?
KrisM is offline
post #2845 of 2850 Old 06-01-2015, 10:49 AM
CZ Eddie's Avatar
Quoted: 68 Post(s)
Liked: 33
Thoughts?
If the other bulb shows up and works fine, then I'd guess this bulb has a short or something or may not be 100% compatible.
CZ Eddie is offline
post #2846 of 2850 Old 06-01-2015, 10:54 AM
KrisM's Avatar
That's what I was thinking.
I figure with two bulbs that are good(in theory, anyway), and two projectors, I should be able to figure it out. I just hope the 2nd one gets here soon. It has to go through customs, though.
KrisM is offline
post #2847 of 2850 Old 09-15-2015, 08:43 PM
sweepsnregs's Avatar
Hey fellow VP4001 owners,
Please give me some insights on how to yank out my old lamp because so far with me yanking with all my might, the old lamp module does not seem to budge at all :'( !!
(For ref, USER MANUAL, pp. 55-56 @ http://us.marantz.com/DocumentMaster..._Final_eng.pdf . Instructions said loosen the 2 screws holding the lamp module inside...but I took the 2 screws out completely...though I don't think this is what's making it so difficult to pull out the module...or is it??!!)
Much appreciation,
sweepsnregs is offline
post #2848 of 2850 Old 09-15-2015, 09:43 PM
CZ Eddie's Avatar
Quoted: 68 Post(s)
Liked: 33
Its as easy as undoing those obviously visible 2 or 3 screws on the lamp and lifting straight up. I don't remember anything weird about it.
CZ Eddie is offline
post #2849 of 2850 Old 09-19-2015, 08:16 AM
Here's an old timer insights...to those youngins should ya grandpapies will ya their old, working 4001's:
1) pride yaself in owning sum Vise-Grippies
2) line the nubby of the lamp module with sum piece of soft cloth
3) put on the Vise-Grip and pull (youngins, y'all shouldn't have to pull that hard at all!)
4) WA-LAH =) ENJOY!
post #2850 of 2850 Old 09-29-2015, 06:48 AM
brianley's Avatar
The ProjectorQuest OEM bulb I purchased died last night after about 9 months. I'm now deciding whether I want to deal with another OEM(ish) bulb or move on to a W1070. Any of you VP4001 diehards interested in another unit? I still have the working original bulb, but that has well over 3000 hours on it and is noticeably dimmer than when new. Everything else with the unit is in excellent condition; still have original box, manual, remote, etc.
Figure it would be better for someone that actually knows the unit, rather than posting on Craigslist or Ebay and having to field complaints like "its only 720P", etc.
brianley is offline
Marantz Vp4001 Dlp Projector
