How many hours on a HD70 bulb? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-26-2007, 01:38 PM - Thread Starter
eeter's Avatar
I bought recently an HD70 form Best Buy and I suspect that it was an open item.
Is there a way to tell how many hours on the bulb knowing that one can always reset the time to zero?
eeter is offline
post #2 of 5 Old 09-26-2007, 02:15 PM
TF Ghost's Avatar
The PJ should tell you how many times the lamp has been reset on the same screen you find the lamp hours on. If you really feel you got a PJ with hours on it you can access the service menu and check there as well.
TF Ghost is offline
post #3 of 5 Old 09-26-2007, 08:39 PM - Thread Starter
eeter's Avatar
How to access the service menu ?
eeter is offline
post #4 of 5 Old 09-27-2007, 06:32 AM
TF Ghost's Avatar
TF Ghost is offline
post #5 of 5 Old 09-27-2007, 08:36 PM - Thread Starter
eeter's Avatar
I tried all of them for the HD70 and none worked.
Any idea??
eeter is offline
