Official AX-200 Owners Thread - Page 105 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
Old 09-04-2014, 12:47 AM
Superjo's Avatar
Originally Posted by Superjo View Post
...Changing the lamp is an obvious and easy process is it? I still have the manual, so I hope it explains what to do in there.
Here's some clown trying to show how to change a lamp...although the internal screw he undoes is obviously a closely guarded secret!
Like the dude in the comments says - it'd be better to have a vid of how to fit a bare bulb into an old casing as that's a very cheap option, and I doubt the casing needs replacing (?).
Superjo is offline
Old 09-12-2014, 12:34 PM
Liked: 0
I developed at problem with My Pt Ax200u. It has been working flawlessly for years. There is 1100 hours on the bulb. I don't have any issues with a dimming bulb or flickering. I have had no warnings to replace the bulb either. The other day when I turned it on it stayed on for about 2 minutes and then the bulb went off and it went into standby mode. Yellow/orange light at the top and the fan is still running. It stays in standby mode for a few more minutes and then turns off, no fan and a red light at the top. The remote control and the buttons on the projector does nothing during this process. You have to unplug it and plug it back in to turn it back on. I have been successful twice last week turing it on and it stays on as if nothing is wrong.
I've read about a sticky iris problem on the 100u that sounds similar to my problem but nothing on the Ax200u. It looks like a easy fix with some WD-40 and a q-tip on the 100u. I opened up the lamp door on the 200U and of course it's different inside. I can't see the iris mechanism at all. Maybe I have to take the whole bottom of the projector apart?
Just seeing if anyone else has this problem. Do you think a new bulb will make any difference? I hate to spend money on a bulb if the projector is broken.
Ryepow is offline
Old 09-12-2014, 02:11 PM
Superjo's Avatar
Wouldn't have thought it was a bulb problem. I've had mine stuck in orange flashing light mode just a few times from 3600hrs, but I don't think the orange light ever went out with the red light replacing it (the fan did turn off though), I had to switch it off with the switch at the back (I wouldn't have thought unplugging it would make a difference).
I've only been stuck in orange mode after I'd cooked the thing for many hours and turned it off myself (it never auto-powers off) and then tried to turn it back on whilst it was still hot and it only would go to orange mode.
In the options try turning SLEEP mode to OFF, maybe it's become tired...Other than that, I have no ideas as I know nothing about the things.
You could try my settings (which work best for me):
Picture:
Picture Mode>Normal;
Dynamic Iris>Off;
Light Harmonizer>Off;
Option:
Auto Search>On;
HDMI Signal Level>Expand;
Installation>Front/Desk;
Sleep>Off;
Altitude>Low;
Lamp Power>Eco-Mode
...I like Eco-Mode - rumoured to cause lamp flicker, but mine lasted about 2600hrs and I then reset the lamp runtime and finally just changed it after 3600hrs (the new lamp now seems too bright! And has exposed that a black screen has a slightly green tint). Maybe you live at high altitude and could change from Low (louder fan?)?...It's probably just a fault though.
...I've seen a newish one of these sell on EBay for £400 with a spare new bulb and not long on the original one - I wanted to buy it twice.
My biggest fault is the high-pitched (which some older people, 50+, can't hear) bulb filament (?) tinkling noise I get when my room/projector gets hot. The tinkling gets less as the bulb gets old and used to my 12hr solid gaming sessions (I don't use Game Mode, it's just a poorer image gimmick), so my new bulb is constantly tinkling/hissing after 30 minutes as my small bedroom soon heats up. Unfortunately, I'm too scared of spiders to open the window!
Superjo is offline
Old 09-18-2014, 08:03 AM
Liked: 0
I recently had to replace the blue polarizer plate of my panasonic projector. Almost everything went smoothly as far as I can tell, but when I removed the mainboard’s wiring to access the polarizer plates, one of the plastic cases broke off (see picture below).
I thought that this wouldn’t be much of a problem, unfortunately though, I didn’t have any idea where the blue and red wire would go exactly. There are three possible options and watching this video (watch?v=FkXzmagj9Co#t=302 ... on youtube, unfortunately I haven't posted enough yet to include links in my posts), I would guess red top, blue bottom with the middle slot unoccupied.
I have tried this, with no luck and the projector doesn’t turn on anymore at all. I can hear a sort of static sound, so I think electricity should be fine.
Do you know exactly how the red and blue wires in the picture below are supposed to connect to the mainboard?
Also, might there be anything else I am missing? Since the projector doesn’t turn on at all, I am not sure whether these wires are my only problem.
ID:	268138   Click image for larger version
jb83 is offline
Old 09-18-2014, 11:30 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
I'm assuming you have the service manual for the AX-200. It's easily found on the internet.
The part you broke off the A-P.C.Board is the 3P connector - A10 - Part number: K1KA03BA0086.
I have seen the YouTube video and a screen capture gives me a different impression of the wire order, but the capture is poor resolution.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
Old 09-19-2014, 04:16 AM
Liked: 0
Yes, I have seen the service manual, although I have to admit that I am far from really understanding any of the circuit diagrams properly. In any case, since I only broke of the plastic around the wires, with no visible damage to either the A-P.C.Board or the wires, I figured that I could just reconnect them. My idea was to just solder them to the board once I figured their configuration.
Would that not work? Do I really need to get the replacement part for this to work properly again? Its not that this is too expensive or anything, but since the projector is not working at all at the moment, I am wondering whether some plastic around the exposed wires would make any difference at all.
Also, is there anything that I could break by just trying trying different configurations for the wires?
jb83 is offline
Old 09-19-2014, 10:36 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
I don't own the AX-200 nor am I an electronics expert. The AX-200 is an older projector model and if you wish to make your own repairs by soldering the wires in place I don't see a problem, you're well beyond the warranty period. You can always use liquid electrical tape to cover the solder points.
Another screen capture from a different angle shows (at least to me) that the blue wire is the farthest up (north) connection and the red wire farthest down (south) in relation to the connector.
The A10 schematic shows the connections, the middle position has no wire.
Disclaimer: I feel obliged to add that I can't take responsibility for any damages that may occur from the help I'm providing.
ID:	269329   Click image for larger version
ID:	269337   Click image for larger version
Mr.G is offline
Old 09-19-2014, 11:36 AM
Liked: 0
Thanks for your feedback. I am aware that this could damage my projector, but as you said, its a very old model and at this stage, i might as well try fixing it myself. Sending it in for any sort of repair would be very uneconomical hence i dont see a way around giving this a shot.
if anyone does happen to have a picture of the apc board, that would be very helpful. Otherwise I will just try some configurations over the weekend and hope for the best.
jb83 is offline
Old 01-11-2015, 01:56 PM
kezug's Avatar
I am at 3000 hours on my original bulb and I am the original owner of the 200u. I am at a point where I will either buy a new bulb or get the new PT-AR100u.
If I choose to go new, I may consider selling my 200u...at this point, how much would this be worth to put up for sale?
kezug is offline
Old 01-12-2015, 08:31 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
A quick look on eBay shows three AX200U projectors going for $300-$600...but no bids. And these projectors have less hours of use than yours. Old tech is often times hard to get rid of unless it's listed at rock bottom prices.
So unless you have an urgent need for more lumens and 1080p, getting a new lamp may be all you need.
Mr.G is offline
Old 01-19-2015, 08:05 PM
kezug's Avatar
Well, I have gone ahead and purchased a new OEM bulb from Provantage. I will keep everyone posted of my experience.
kezug is offline
Old 02-08-2015, 05:14 PM
kezug's Avatar
As I have mentioned, I would provide an update. I got the new bulb from Provantage. Very fast shipping, very well packaging. Replacement was simple.
My brightness is restored, I am finding that my eyes are not fatigued watching with a dim bulb anymore. I had my previous bulb for nearly 7 years. believe I reset it twice. While it was 7 years old, it sure was still performing fine though.
Anyone want to buy my older bulb?
Also, I am finding something odd happening though with the new bulb and that is focus creep. I tend to have to refocus after warm up. I notice it mostly when I put the cable guide up and see the letter blurring. I have to adjust at startup and then once again after ample warm up. I find that odd.
I do wish I would have purchased a new projector just because I like new gadgetry but gosh, this projector is going on 8 years old as a model and it sure is performing optimally!
Dave in Green likes this.
kezug is offline
Old 02-09-2015, 06:47 AM
Liked: 0
Good afteroon I'm from Italy and I've a ax200 projector. I've problem on the red side almost identical the problem of kezug or jambo04 in the same left part of the screen as well... I tried the guide of kezug to remove dust following correctly step by step but the image quality is absolutely the same is there anything else to try? Shuld I assume it's not a problem of dust or the air blow didn't remove the dust? It's strange as it looks like the red on the netflix screen of kezug...
I thought also to replace it with an epson TW3200 whil I can still find it (1000€ new) but I saw in forums that it has dust problems... smone have experience on this projector? I need a projector with a good vertical lens shift and possibly 1080p if I don0't manage to resolve the red problem with my panny....
Thank you!!!
biasiman is offline
Old 02-20-2015, 05:37 AM
bbibb's Avatar
Quoted: 16 Post(s)
I purchased a PT-AX200U in 2008, and a replacement bulb on 11/09/14.
The projector has been great, but I recently noticed some blobs on the screen.
Some have suggested a polorizer problem, and that this projector is near the end of its useful life. I only have about 2200 hours on it.
How long has your projector lasted?
Thanks for the feedback,
Brady
bbibb is offline
Old 02-20-2015, 05:51 AM
bbibb's Avatar
Quoted: 16 Post(s)
Here is a picture of the blobs. They are mostly visible on an orange screen.
Brady
bbibb is offline
Old 02-20-2015, 06:17 AM
premiertrussman's Avatar
Quoted: 17 Post(s)
ooof, those are bad! I'm not sure what that is. Could be dust blobs? I have something similar thats most evident on red screens, but its much less drastic. My bulb is over 3k hours. I'm getting ready to replace.
_____________________________________
Shades of Grey Theater
Currently Playing: Overwatch/WoW - Legion
premiertrussman is offline
Old 02-20-2015, 09:30 AM
Dave in Green's Avatar
Quoted: 1292 Post(s)
Liked: 858
bbibb, when you replaced the lamp did you get a genuine OEM replacement lamp or a cheap knockoff?
Dave in Green is online now
Old 02-20-2015, 12:26 PM
bbibb's Avatar
Quoted: 16 Post(s)
Hi Dave,
I purchased the real bulb from ProjectorPeople. Cost me about $400.
The blobs show up on an orange screen, but I can barely see them on other colors.
I first noticed this during the Super Bowl. The commentator on the right side of the screen had a greenish tint to his skin. I was then watching a Vonage commercial where they showed a mostly orange screen and wham! Sticks out like a sore thumb.
Brady
bbibb is offline
Old 02-24-2015, 03:54 AM
Liked: 0
Have identical problem just my blobs are on the right...
biasiman is offline
Liked: 0
sorry on the left...
biasiman is offline
Old 02-24-2015, 09:50 AM
Liked: 858
It's most likely not a lamp-related problem. Projector People cites the following method to determine if the blobs are caused by dust:
Q:Why do I see green, blue, or red "smudges" or "blobs" on my projected image?
A:More than likely, what you are seeing is dust on one of your LCD panels. Try pausing your image so that these abnormalities are clearly visible (see image). Then simply de-focus your projector in BOTH directions. (see image).
You should see these blobs actually become a solid object either in the form of a string of lint or a spot of dust. To avoid dust blobs from occurring, it's important to perform routine maintenance on your projector. Cleaning of the filter with a vacuum on a monthly basis will help reduce accumulation of dust buildup.
If not dust, it's most likely an LCD panel going bad. I have more than 4,000 hours on mine with no problems to date, but others have reported panel problems with fewer hours than that. Panel life can be shortened by excessive heat, but sometimes it's just luck of the draw that some panels fail much earlier than others.
Old 01-13-2017, 10:21 PM
toups's Avatar
Originally Posted by lethagized View Post
Well, you can see the small red dot on the lcd ribbon cable in the picture, so that's your red lcd panel. The items you have numbered 1 are your polarisers. Don't mess with the number 2 items, they are just dichloric lenses in the light path.
What you want to do is, remove the block that i have painted in yellow. IIRC there are 2 screws holding it in, but be mega careful as not to disturb the lcd panels. This is your LCD array containing the 3 panels and the prism. Don't touch the panel surface with your fingers.
The polarisers (1) can be removed and cleaned both sides, but use a sharp pencil and mark a line like i have painted in the picture (thin yellow lines on each side of each polariser) so you get them in the same place as they were before. Again, don't touch the glass surface with bare fingers and make sure they're spotless before fitting them. Don't use chemicals, but a soft brush will do the trick.
Congrats on diving in though, i know it's very nerve racking, but if you're careful, it will go fine.
Thanks for the info. I had a classic case of what looked like dust on red images. It looked almost exactly the image on this post. (click link to post to see original image)
Attached is the image of my incidence polarizer filter. Notice the two somewhat opaque regions.
Simply blowing it off did nothing. My initial thought was that it looked somewhat burnt but on closer inspection the problem was probably oil on polarizer. (Too much olive oil in the air from cooking.) I ended up using an alcohol based eye glass cleaner and a q-tip to clean it. It took somewhat more aggressive cleaning than I felt comfortable with to get it clean. Thought for sure I would destroy the filter but it survived.
Good news is the incidence polarizer filter is now clean and the image color is better. However, it still has some discoloration on red images but is greatly improved. I am wondering if the lcd may also be dirty.
Since the projector survived this initial surgery, I am somewhat leary of pressing my luck by attempting to clean either the lcd or the projection polarizer. To do this would require removing the optical block. Or maybe the incidence polarizer needs additional cleaning. Any thoughts?
Unfortunately I didn't take a good set of before and after images of the projected screen. (Could do an after now but it looks like the linked image just not as bad as before.)
Since my image is much better, I am tempted to leave well enough alone.
Name:	red polarizer.JPG
toups is offline
Panasonic Pt Ax200u 720p 3lcd Home Theater Projector
