Official AX-200 Owners Thread - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
Old 10-11-2007, 12:22 PM
Rahl's Avatar
The reason why I intially agreed because of my own personal usage of my projector.
When I had my 4805, I mainly used my TV for normal watching and the PJ just for movies and games.
Also, when I had the 4805, viewing during the day was not the best.
But now that I have the Panny, I will be using my PJ a lot more especially in the early evening to watch TV.
I'll still use the TV for kid shows during the day for my children.
So, like I retracted, it depends on how you watch shows/movies and whether you will be happy or not with what you go with; PJ or TV.
Rahl is offline
Old 10-11-2007, 12:43 PM
broadwayblue's Avatar
Originally Posted by BuGsArEtAsTy View Post
So, 92" is too big for my tastes. 88" is OK, but shortly after I set the projector up, I started puking... No, not because of the image, but because I got food poisoning from the restaurant I went to a little earlier. Thus, I didn't get too much testing of the AX200U done yesterday.
Anyways, I think I'll go for an 84" for my 9' seating distance. That's a seating distance of 1.5X screen width. (73" x 1.5 = 110" or 9'2")
What game is that?
broadwayblue is offline
Old 10-11-2007, 12:46 PM
BuGsArEtAsTy's Avatar
Quoted: 326 Post(s)
Liked: 148
It's not a game. It's a movie.
Actually I mentioned it in the post:
Pitch Black, from the 360 HD DVD, over VGA.
BuGsArEtAsTy is offline
Old 10-11-2007, 12:53 PM
Bachiano's Avatar
Quoted: 143 Post(s)
Liked: 66
OMG - now I'm gonna have to go get an HD-DVD player too!
Bachiano is offline
Old 10-11-2007, 01:53 PM
Bachiano's Avatar
Quoted: 143 Post(s)
Liked: 66
Pitch Black.
Can't think of a better movie to check out contrast and shadow detail.
Bachiano is offline
Old 10-11-2007, 01:55 PM
Quoted: 326 Post(s)
Liked: 148
Yes, besides the fact it was handy at the time, it was one of the reasons I chose that movie to demo. Not only are the dark scenes dark, the bright scenes are very bright.
I wonder if I had my IRE settings incorrect though. The default for the 360 is Standard, which is IRE 7.5. I'll try IRE 0 (Expanded) to see if that looks better on the Panasonic. I think I had it on Intermediate and it looked OK but not stellar for blacks. (Note that I'm just viewing it on a painted wall at the moment, so take all these assessments with a grain of salt.)
The other thing to test is to see how IRE 0 looks for games. Perhaps one might want to switch to IRE 0 for movies, but consider IRE 7.5 for dark games like Gears of War.
So much to test, so little time...
Old 10-11-2007, 02:49 PM
Fragster's Avatar
Quoted: 27 Post(s)
Can someone please link me to a 25 feet component cable that I can pair up to the XBox 360 to the PJ?
I'm assuming it should be a male-female styple cable but can't find it at monoprice.com
Appreciated
Frag
"There are 1 0 kinds of people in this world...one that can read binary while the other that can't!!"
My small HT setup:
http://www.flickr.com/photos/27565515@N04/
Fragster is offline
Old 10-11-2007, 02:58 PM
Rahl's Avatar
Appreciated
Frag
You need a coupler that looks like this:
Rahl is offline
Old 10-11-2007, 03:36 PM
Fragster's Avatar
Quoted: 27 Post(s)
Highly appreciated.
On the same note, those that have the older premiums (non-HDMI), are u preferring components over VGA or vice versa for the AX200?
Frag
My small HT setup:
Fragster is offline
Old 10-11-2007, 04:28 PM
bradesp's Avatar
can someone take a photograph of the rear of the unit where the power cord and video cables connect? I'm trying to determine how deep the total space requirement might be for a shelf mount scenario.
Also, if I were to mount my PJ on a rear shelf and I needed / wanted to place the projector upside down (similar to ceiling mounting) so that the lens is oriented on the opposite side of the projector would I need use some rubber grommets (or something similar) to rest the projector? It looks like the top of the projector case is rounded and has menu buttons that would likely not do well if the projector was placed directly on it's casing (in the upside down position).
bradesp
bradesp is offline
Old 10-11-2007, 04:29 PM
Quoted: 326 Post(s)
Liked: 148
From the Projector Central review:
Old 10-11-2007, 04:33 PM
djmas's Avatar
just wondering if this projector upscales or not. I'm trying to piece together a good HT room, and need to know if I should get an AVR that upscales or if this projector will do that for me.
My biggest concern is the quality of my Direct TV HD receiver when watching SD content. I would like to clean up the SD content as best possible so will the Panny do this or do I need to drop big bucks on a AVR with upscaling???
thanks guys!
djmas is offline
Old 10-11-2007, 04:36 PM
Rahl's Avatar
bradesp
Unless you can bend the cables really well, you'll need an additional 4 inches behind the projector. Also, there is a vent back there and on the left of the unit if viewing from the back.
With the lens shift, you won't need to mount it upside down on a shelf. You can go pretty extreme with the movement.
Rahl is offline
Old 10-11-2007, 04:54 PM
scotty144's Avatar
Yeah, this is quite annoying. I'm using VGA cables and I'm trying to get it to display 1280x720 with my Xbox and it won't align the picture.
I did the auto adjust and it shoved it as far right as it could but there's still a 8 inch black bar on the right.
Anyone know how to get into the service menu to adjust the position of the picture?
I'll just keep it in 1280x768 right now since it can align that.
Here's what it did for 1280x768:
H-Position= +42
V-Position= -8
Dot Clock= -6
Clock Phase= +5
Strange. I used to have the same problem with my AE900 over VGA. But Microsoft released a patch awhile back which fixed the issue for me. Are you sure you cant adjust the dot clock and phase more in order to get true 1280x720 over VGA?
JVC HD 250
Benq 1070
B&W
Onkyo
Hsu Research
scotty144 is offline
Old 10-11-2007, 05:02 PM
RadioRon's Avatar
I've just powered my new AX200 up for the first time. I'm very happy with the focus and convergence, they look great even on very close inspection. Fan noise is very low and quite acceptable. Zoom and focus rings rotate very smoothly and easily. The offset control works well.
The brightness is still an open question because I don't have my screen yet and I'm projecting onto a dark green matte wall in a room with no ambient light. Under these conditions it seems a bit dim, but that's to be expected I guess. I don't see all that much change to brightness between the Cinema 1, 2, Natural, Vivid and other modes other than colour intensity shifting a bit, and I don't see anything happen to brightness when I change from Normal to Eco-Mode in the lamp operation. I presume that these observations on brightness don't count until I've got a proper screen of some sort. The DW diy screen will be in place by next Monday.
I taped a few samples of white on the wall and things looked more promising. How do I actually measure the lumens hitting the screen? Anyone have links to technical descriptions of this?
RadioRon is offline
Old 10-11-2007, 05:18 PM
forkdeath's Avatar
I just downloaded the extended warranty form from PP for my new projector. It says 2 year 4000 hour? Can this be correct? I have seen another one that says 2 year 2000 hour. Anyway I am sending in the form that says 4000 hours.
Also, I just hooked it up. On some material it has a blinking white bar across the very top of the image. How can I correct?
forkdeath
forkdeath is offline
Old 10-11-2007, 06:37 PM
karlsch's Avatar
Quoted: 20 Post(s)
Liked: 24
bradesp
You need three inches of clearance for the cables. You could get by with less if you used an HDMI angle adapter.
The sensor for the light harmonizer is on top. If you turn the projector upside down on a shelf you might cover it.
Karl S.
karlsch is offline
Old 10-11-2007, 07:30 PM
Jason Falejczyk's Avatar
forkdeath
It's correct: 2 years / 4000 hours.
Jason Falejczyk is offline
Old 10-11-2007, 07:33 PM
Quoted: 326 Post(s)
Liked: 148
IRE 0 (aka "Expanded") on the Xbox 360 via VGA makes a HUGE difference in quality of black levels in movies.
I haven't tested HDMI or component, but I'm guessing that the projector would use IRE 7.5 ("Standard") just fine. However, for VGA, blacks are simply too light if you give the projector an IRE 7.5 black input.
I guess that Panasonic has (appropriately) configured the PT-AX200U for computer input over VGA, and computer input would be IRE 0.
This is too much of a pain. Its easier to just use IRE 0 all the time, and then switch to Game mode on the projector to increase the light output for dark games. Games like Dead Or Alive 4 are fine in Cinema 1 mode though with my setup.
BTW, while "black" is much blacker now with the IRE 0 setting, dark shadow detail remains OK, but not stellar. But then again I wasn't expecting a CRT. I do own a CRT HDTV so I'm a bit spoiled - I judge all other TVs by that CRT's shadow detail. I do also have a Toshiba Regza LCD TV, and truthfully its shadow detail isn't much better than the Panasonic projector's in Cinema 1 mode, so overall I'm quite pleased with this projector.
Oh and while Game mode decreases lag time, I don't actually notice any lag in Cinema 1 mode, so obviously the amount of lag with this projector isn't huge to begin with. It certainly isn't the laggy mess of TVs from yesteryear.
Old 10-11-2007, 08:07 PM
j-bo's Avatar
forkdeath
You doubted me?
The Truth IS out there!
j-bo is offline
Old 10-11-2007, 08:10 PM
reconlabtech's Avatar
Originally Posted by RadioRon View Post
The brightness is still an open question because I don't have my screen yet and I'm projecting onto a dark green matte wall...
Put up some black out cloth, a white panel board or two coats of killz on the wall and come back with a blinding report.
// Front Projection Enthusiast //
BenQ W1070 - 103" EasyFlex Painted Screen
Onkyo TX-NR646 - JBL Northridge 5.1 - SVS PB-1000
Roku 3 - Amazon FireTv - Sony BDPS5500 - Kangaroo PC
reconlabtech is offline
Old 10-11-2007, 08:12 PM
Rahl's Avatar
I was going to say; I about blinded myself last night.
I walked up to the screen to check out the smooth screen technology and when I turned around I thought I went blind.
Rahl is offline
Old 10-11-2007, 08:18 PM
forkdeath
SD content? That's the SAP audio track and Closed Captioning signal. Use the overscan function to crop that off.
Old 10-11-2007, 08:20 PM
Ouch! BTW: what is your record for the sun stare contest?
Old 10-11-2007, 08:26 PM
Rahl's Avatar
Funny thing is, I don't even think I looked directly into the lens.
But not to sidetrack too much;
Question: Since this projector can handle 1080 really well, should I set my DVD player to that or just keep it at 720. I know the native resolution of the Panny is 720, but I just want to know if it can handle it well enough that it increases PQ.
Rahl is offline
Old 10-11-2007, 08:29 PM
If you were using an HDDVD or Blu-Ray player, I would say set to 1080p and forget about it but for all other sources, send them through at 720p and then at 1080i and see what you like better. That's what really matters!
Old 10-11-2007, 09:06 PM
forkdeath's Avatar
Thanks for the convergence tip. The white bar at the top is just not SD material, I get it on xbox360 over component watching hd video as several solid white dots top row middle. I am running the signal through 2 switch boxes (don't ask). I am going to remove them both tomorrow as a test.
forkdeath
Old 10-11-2007, 09:29 PM
Quoted: 326 Post(s)
Liked: 148
Somebody asked about computer resolutions a while back.
Well, my computer over VGA didn't detect the AX200U as anything specific, just as an LCD. So, I was limited to resolutions like 800x600, 1024x768, and 1280x768, etc. All of these looked terrible.
So, I put a custom rez of 1280x720 on my laptop. The MacBook accepted that resolution, and it looks great on the Panasonic. I tried 1920x1080 (60 Hz), but for some reason it doesn't get displayed correctly. I think it's a problem with the MacBook's output though, because 1920x1080 from the Xbox 360 works fine.
What happens if you use the vertical adjustment to shift the image up? Does it get rid of the white dots without introducing a black bar at the bottom?
Old 10-12-2007, 12:25 AM
jdiehl's Avatar
Pulled the trigger tonight on the AX-200 from Proj. People.
Ordered a 25ft component (Xbox 360) and 25ft HDMI (D* HR-20 DVR) from Monoprice as well.
Time to build my screen, my 8x5ft laminate (Designer White) from Home Depot will be here tomorrow!
Anyone have recommendations for a cheap mount? I need a 2ft pole mount to drop it down from the subfloor in the basement (unfinished) to the proper height.
I found this article on building your own mount and the DIY'er in my is interested in something like that rather than a pivot type of mount that I had in a previous setup:
http://www.gadgetopia.com/post/4850
Jon
jdiehl is offline
Old 10-12-2007, 02:38 AM
ahro's Avatar
Quoted: 2033 Post(s)
Liked: 4130
I'm having mine delivered tomorrow. Reading the whole thread, people seem enthuiastic, but not blown away by this PJ. I bought it to replace my MTS 1000 for the extra lumens, as I have a 133" diagonal screen. When the MITS came out people were falling over themselves saying it was the greatest PJ for the money ever. I don't see that here. Comments?
korsjs likes this.
HENRY
78HU9000, 10 BIT, TS-01; NEW 3500 OCB, WD PASSPORT HDD
ONKYO TX-NR646 ATMOS RECEIVER
ISCAN MINI, UHD 30 PACK. SAMSUNG BJ7500 BLU RAY PLAYER
USB 3.0 4 PORT HOT SWITCHABLE HUB, ROKU 4,SAMSUNG K-8500 BRP
ahro is offline
Panasonic Pt Ax200u 720p 3lcd Home Theater Projector
