Epson Home Cinema 720 Owner's Thread - Page 57 - AVS Forum | Home Theater Discussions And Reviews
Old 01-09-2011, 06:30 PM
AndreasMergner's Avatar
I'm using expanded with a pc. Look for crushed whites and blacks without that setting.
Current HT: HTPC-->Epson 5010 projector-->135" screen, BFM TLAHs x7 & THT
Build log: DIY rotary sub for contemporary HT in 100 year old house?
Andreas' Slow Rotary Sub build
AndreasMergner is offline
Old 01-16-2011, 09:53 PM
Logan 5's Avatar
I feel strangely obligated to give Epson props. My colors went bonko on me after changing the bulb. I called Epson not really expecting anything and was thrilled to find out I was still under the 2 year warranty. After a short round of troubleshooting, the CSR said they'd send me a replacement. Kick ass. Well, I never got it. A week later, I called them to ask what's up, and they said it was delivered. "Not to me," was my response. To make a long story short, they sent me another one. Looks fantastic. Guess I hadn't realized how dim the picture had gotten. Anyway, thrilled with the projector and the Epson service.
Logan 5 is offline
Old 05-17-2011, 06:27 AM
sjwoo's Avatar
I just got an XBOX 360 (mostly to play Kinect), and I'm having trouble connecting it to my Epson 720. I have an ABC component switchbox that I'm using (works fine for the Wii and Dish STB), but with the XBOX, the projector reports No Signal.
The Wii is 480p and the STB is 720P/1080i. Since the XBOX is 1080P, do you think this might be the reason why it isn't working? I have my computer hooked up to the Epson as well, but that's via VGA.
I haven't tried HDMI yet, but I'd rather try to get this to work with component if I can, since I already have all those cables.
- Sung
sjwoo is offline
Old 05-17-2011, 06:43 AM
SKoprowski's Avatar
Quoted: 13 Post(s)
Probably- you should set the Xbox resolution at 720p- 1280 x 720 to match the resolution of the projector. I don't think you can do 1080p over component with the Xbox.
NE Ohio HT Nutt
SKoprowski is offline
Old 05-17-2011, 02:44 PM
sjwoo's Avatar
Bingo! That was it -- thanks.
sjwoo is offline
Old 05-25-2011, 03:31 PM
mather's Avatar
My original bulb just hit 28XX hours and the "replace lamp" box came on the screen. Did others replace your bulbs when the box came up or reset and run the bulb until it dies? Or maybe not even reset, so one can see the total hours?
mather is offline
Old 10-05-2011, 11:15 AM
broadwayblue's Avatar
For those of you who own or owned an Epson 720 would you recommend it to someone as a first projector today? I have a friend who is looking to purchase a FP and he found a used 720 with about 750 hours on it for $550. He's asking me whether he should pull the trigger. I know this model is 4 years old, but assuming it's in good shape it sounds like a decent deal. What do you think?
broadwayblue is offline
Old 10-05-2011, 11:26 AM
wormraper's Avatar
Quoted: 313 Post(s)
Liked: 154
not for that price. you can get the Epson 705HD for $595 brand new with warranty intact from Amazon right now.
wormraper is online now
Old 10-05-2011, 02:07 PM
But unless I am mistaken the 705 has a significantly lower contrast ratio (and a good number of complaints about the blacks), not to mention it lacks lens shift.
Old 10-05-2011, 02:25 PM
wormraper's Avatar
Quoted: 313 Post(s)
Liked: 154
ahh, yes, I forgot that the 720 had lens shift. that would be something to consider
Old 10-05-2011, 07:10 PM
bron's Avatar
If it's in good shape, I'd say that's a fair price and a decent deal. The 720 is a lot better FP than most.
bron is offline
Old 10-05-2011, 07:23 PM
It's not a great deal considering it went for $1200 four years ago, you have a $350 bulb that has half its output left and no warranty. It might be a cheap-ish way to get into a projector, but a new 8350 for ~$1000 would be a better value and give you 1080. It also has organic panels which don't age as well. If you look at a completely white image and notice a very slight change in hue (pink/blue/yellow) across the screen, the LCD panels may be a little burnt. They are probably fine with only 750 hours though.
Don't get me wrong -- I have been very happy with my 720, but I would not buy a used 720 today. Used PJs are not usually good values since technology gets better every year while prices go down.
Old 10-05-2011, 09:16 PM
Thanks for your thoughts. Personally I would agree with you. There is no doubt in my mind that getting a brand new projector for about $1,000 would be worth the extra cash. But my friend is on a pretty tight budget after buying his first home. On top of that he needs to purchase a receiver and surround sound system as well, so I just don't think he can stretch his budget that far. Perhaps I could get him to spend an extra hundred or two...but spending twice as much is probably not in the cards at the moment. While I'm not in love with the idea of him buying used, on the bright side he will love the picture as is just about always the case with a first projector. I just hope the panels or polarizers aren't burnt because the original owner put 750 hours on it in one viewing. lol
Old 10-05-2011, 09:36 PM
You're right, it is my polarizers that are slightly burnt...but I have probably 6000 hours on mine. You can also get the same effect from dust. A good cleaning (not for the faint of heart) improved my image a lot.
It is a cheap way to get into PJs...I can't argue with that. Another choice would be: http://www.newegg.com/Product/Produc...82E16824009223
New, cheap, 720 and 3D, but no lens shift and possible RBE.
Old 01-08-2017, 01:26 AM
mushbert's Avatar
Wow. No one's posted here for quite a while, am I the only one still running this model?
Projector is still going strong, at 5315 hours and getting daily use. Everything is working fine, though about once a week there will be a fault on startup and the projector will shut itself off - the next time it works though. I've since seen several Epson threads that have similar issues caused by fans or the cinema filter needing maintenance. At any rate, it seems it's time to open it up and I was wondering if anyone can help regarding the following:
- Does anyone have the service manual for this? I found the one for the EMP-TW1000/HC1080's on ifixit; most of the mechanical stuff is identical, but the values in the "Software DIP Switches" table don't appear to be the same, or at least the ones I've tried have no effect.
- Panel alignment. I know there's no way to improve convergence without pulling the light engine, loosening the plates that holds the LCDs to the prism, and spending (probably a very long) time poking at them. I should probably leave well enough alone, but if I'm already taking it apart... My convergence isn't terrible, but compared to Green, Red is off by one pixel. Blue is off by less than one, but in a different direction. White is a mess, though it looks ok in motion. It will never be perfect, but I feel like I might be able to do better. If I'm going to try though, I would prefer to know what I'm getting into first. I can't find any close-up photos of the prism assembly - this is the best so far but there's not enough detail. In this thread someone with an Epson 3010 describes the process, and it seems like the LCD is on some sort of rail or guide, presumably to keep it from rotating. I can't find ANY photos of the prism from that model though. Does anyone know if the HC720 has something similar?
mushbert is online now
Old 01-08-2017, 08:29 AM
sjwoo's Avatar
Count me in as a very happy long-time user. On my fourth bulb (the second and third were cheapo knockoffs from Amazon...each lasted about 500 hours before conking out; the fourth was OEM and still going strong after ~1000 hours). I think I know the issue you're talking about -- my 720 goes into some sort of high-speed fan mode and shuts off. When it happened the first time (just happened like 2 months ago), I realized my filter was very dirty. Cleaned it, but then it happened again like a few days later...but then it hasn't happened since. I've had this projector for a long, long time...since 2007, I think. So it's been running for 10 years! So it's all been gravy. As long as it keeps on running, I see no reason to upgrade as the 720 picture is just fine on my 92" screen.
This is the manual I still have, the user manual...not sure about the service manual.
https://files.support.epson.com/pdf/.../plhc720ug.pdf
- Sung
sjwoo is offline
Old 01-08-2017, 11:05 AM
mushbert's Avatar
Yep, those are the symptoms, though the cause depends on how fast the temperature/warning lamp is flashing... the User Guide only refers to one of them as "internal error"... Whereas the HC1080's Service Manual is much clearer about it:
I don't remember it ever happening until I changed to the free spare bulb from Epson, which is what's in there now, so it could be related - but since the unit fires up >90% of the time it's likely the other error.
