Official Mitsubishi HC4900 Owners Thread - Page 125 - AVS Forum | Home Theater Discussions And Reviews
post #3721 of 3723 Old 06-17-2016, 02:42 AM
rtchinn's Avatar
If anyone ever decides to part out their dead 4900, I'd be interested in a lens assy.
Been checking eBay, but they're so old now it's hard to find anything.
HC5000, 6000, 6500 would also be likely donors.
rtchinn is offline
post #3722 of 3723 Old 12-23-2016, 04:30 PM
Liked: 0
Have enjoyed the HC4900 for several years - lately the picture seems washed out and very dark. Tried another bulb and it didn't make a huge difference. Every now and then the image is bright and crisp like when it was new. Most of the time dissapointing and dark.
I've tried:
1 - new bulb
2 - direct connection from PS3 to projector with new hdmi cable.
I'm going to try:
1 - resetting to factory defaults.
2 - anything else you all recommend.
What would you do to revitalize an HC4900?
Eric Nord is offline
post #3723 of 3723 Old 12-29-2016, 06:57 PM
Bohanna's Avatar
Liked: 24
Hi all I seem to be having the same problem many have had with a replacement lamp for the HC4900. The aftermarket one I got on Amazon had the WRONG connector that is supposed to mate with the projector. it looks similar but its slightly different. the slot on top is the original. Does ANYBODY know which after market lamp will actually fit into the unit?? Many Thanks in advance!! Bohanna
Name:	New slot on top.jpg
ID:	1861457   Click image for larger version
Name:	Slot Original.jpg
ID:	1861481   Click image for larger version
Name:	Slot New #2.jpg
Bohanna is offline
Mitsubishi Hc4900 Lcd Projector 1080p
