Optoma HD65 Review & Screenshots - Page 25 - AVS Forum | Home Theater Discussions And Reviews
Old 05-02-2008, 10:42 AM
leakwoon's Avatar
SERIOUS HELP Needed..
My setting on PS3:
Video OutputFormat YPbr/Cb Pr/Cr
SuperWhite- ON
1080p24-ON
on my HD65 setting:
Cinema
contract -6
brightness -6
sharpness +3
Advanced
Degamma : film
Brilliantcolour 0
TrueVivid 0
Ai OFF
Colour Temp: Medium
Colour Space : YCbCr
RGB GAIN/BIAS:
RG-16
GG -5
BG -7
RB -4
GB -1
BB -3
I found the HD65 PQ improved when I set YCbCr compare to auto....but sadly the reddish very badly... I have changed all the gain/bias setting as above.
All these fine with BDs with 1080p/ movie trailer downloaded with 1080p
Weird thing is when i pop-in Mariah Carey MIMI concert BD/Destiny child concert BD
both at 1080i 60hz & it seriously gives me red-pinkish issue again
GOSH! ...wat is going on?
appreciate some one to assist/advise... CHEERS
leakwoon is offline
Old 05-03-2008, 08:30 AM
Gr8full's Avatar
My setting on PS3:
SuperWhite- ON
1080p24-ON
on my HD65 setting:
Cinema
contract -6
brightness -6
sharpness +3
Advanced
Degamma : film
Brilliantcolour 0
TrueVivid 0
Ai OFF
Colour Temp: Medium
RGB GAIN/BIAS:
RG-16
GG -5
BG -7
RB -4
GB -1
BB -3
This might sound way too simple but seeing as these are concert DVD's could it just be that they're using a lot of red spotlights in their concerts? After all, you say it's fine with movies.
Gr8full is offline
Old 05-03-2008, 09:45 AM
leakwoon's Avatar
yes it is perfect fine with movie(1080p) after i changed the colour setting...but when HD65 pick up the signal 1080i from PS3/Blu-ray....it turned into very very "reddish"
Weird
anyone care to share their setting on HD65 via PS3 as "source player" ?
Thank you
leakwoon is offline
Old 05-03-2008, 09:55 AM
leakwoon's Avatar
about the colour space setting on HD65
leave it on AUTO ? RGB? or YCbCr?
*i m using PS3 for blu-ray, at PS3 setting is YCbCr, super white on*
something I did wrongly? miss-ed out?
Thanks !
leakwoon is offline
Old 05-03-2008, 01:25 PM - Thread Starter
guitarman's Avatar
Quoted: 13 Post(s)
Weird
Thank you
For 1080i try a higher color temp setting. What I do is have a graysteps pattern going from a calibration DVD and watch the gray tones. Pick the color temp closer to steely gray tones. I'll bet the grays you're seeing now are very red toned so go to middle or high color temp.
Tom/guitarman
VideoDementia
Are you twisted also?
http://www.videodementia.com/sales/TomWithWires.jpg
guitarman is offline
Old 05-03-2008, 02:29 PM
shadowhankron's Avatar
Hi Everyone, Well Yesterday My Hd 65 Arrived With A Free 55" White Screen....
Set It Up And Changed Some Settings To What I Picked Up On This Forum, While Using A Budget Priced Hdmi Dvd Player With Hdmi Cable Connected I Dont Seem To Get The Kind Of Great Pictures I See On This Forum, Which Leads Me To Believe That The Great Pics Here Are From A Ps3 And Blu-ray As I Dont Play Games A Ps3 Would Be No Use To Me.. Can Anyone Elighten Me Why I Dont Get A Good Pic, Oh And My Throw Range Is 9 Ft .. Thanks
Ronnie
Dublin
shadowhankron is offline
Old 05-03-2008, 05:19 PM
Davidt1's Avatar
Quoted: 92 Post(s)
I am wondering if those great shots have been enhanced with Photoshop because they just look too good.
Davidt1 is offline
Old 05-03-2008, 05:36 PM
Peter_'s Avatar
The pictures I have posted not suffered any further processing.
See my post: http://www.avsforum.com/avs-vb/showp...&postcount=620
Do not judge people hastily.
You are invited to come to my house to see for yourself.
Peter
Peter_ is offline
Old 05-03-2008, 05:57 PM
leakwoon's Avatar
Sir, you are absolutely right...I dont the see the right gray tones ..it turned into reddish toned now
does it mean everytime the HD65 pick up different source, I need to adjust it?
but this will not happen if i leave the colour space to "auto"
leakwoon is offline
Old 05-03-2008, 08:23 PM
heiwi's Avatar
I have the choice from my dvd player to set color space to YCbCr or RGB. What gives the better picture for mainly movie watching on dvd?
heiwi is offline
Old 05-04-2008, 02:08 AM
leakwoon's Avatar
correct me if i m wrong..
movie are normally stored in YCbCr
while those computer/games media in RGB format
leakwoon is offline
Old 05-04-2008, 06:53 AM
heiwi's Avatar
interesting - that would mean no conversion necessary if you can go from YcbCr on dvd player level to YCbCr on projector level.
heiwi is offline
Old 05-04-2008, 09:54 AM
leakwoon's Avatar
it should reduce the artificial effect of "converting process"
leakwoon is offline
Old 05-04-2008, 10:42 AM
leakwoon's Avatar
anyone care to share the setting on HD65 via PS3 for blu-raying?
thanks alot man !
leakwoon is offline
Old 05-04-2008, 02:35 PM
Stix2's Avatar
Just curious I am using the HD65 as a monitor running it at 1920x1080 and games look great but text is fuzzy. Not sure why I thought this did 1:1 mapping. I try to change the resolution to lower and it shakes alot.
Any ideas? I am using HDMI hooked to the projector.
Stix2 is offline
Old 05-04-2008, 03:09 PM
Ronnie
Dublin
I HOPE PETER YOU TOOK NO OFFENCE TO MY QUESTION IT WAS NOT MEANT TO CHALLENGE YOUR PICTURES, ONLY MEANT I COULD NOT GET SUCH GREAT RESULTS SO FAR WITH MY SET UP.
THANKS
RONNIE
Old 05-04-2008, 03:30 PM
David Barteaux's Avatar
Quoted: 16 Post(s)
I think Peter is using a computer and output is set at 720p to achieve 1:1 pixel mapping.
I also can't get as good a picture using Blueray as I think the conversion process from 1080 down to 720p is affecting the result.
David Barteaux is offline
Old 05-04-2008, 04:13 PM
Peter_'s Avatar
a 720p source on a 720p native projector will give more definition that 1080p on the same projector. 1:1 pixel mapping is quite important.
The message where I posted a comment on 720p x 1080p about a 720p projector:
Originally Posted by Peter_ View Post
I did some tests to see the difference between 1080p and 720p send signals to the projector.
I understand that the image in 720p has more sharpness, but is a little cracks in the contours of the objects.
The 1080p image is a little smoother, but the outlines of objects are smoother. It is not blurred, as if it is a filter of "anti-aliasing" being applied where all the cracks disappear. The picture is more natural.
This test I did with the Ratatouile because it is 1080p. I need to do the test again with a film 720p.
Image 1080p at 1280x720pixels:
Image 1080p at 1920x1080pixels:
Peter
Peter_ is offline
Peter_'s Avatar
The whole message where I posted a comment about the increase on image's definition using HTPC:
Is important to say that I don't have Blu-Ray Player and I use the filter Sharpen of ffdshow to increase sharpness of all movies.
I use the Media Player Classic + K-Lite Mega Codec Pack + QuickTime Alternative.
This increases the sharpness of all movies, and with that I can take better sharpness of the projector.
Why buy a projector with good sharpness, if the films are smoothed.
The camera I use is the simplest possible:
Optoma HD 65 - Media Player Classic + ffdshow with Sharpen de 46:
ORIGINAL - Media Player Classic + ffdshow with Sharpen de 46:
ORIGINAL - Media Player Classic without filters:
The settings I use in the Optoma HD65 increase the contrast/sharpness volume and even more, just take a look at the settings in some messages posted ago.
Peter
Excuse the mistakes of English.
Peter_ is offline
Old 05-04-2008, 06:48 PM
leakwoon's Avatar
agreed with u peter...
but on ps3 wise...i feel output-ing the native 1080p resolution from BD is far better to let the HD65 to do the downscalling job
CHEERS
p/s: any other PS3 owners here for blu-ray-ing via HD65?
leakwoon is offline
Old 05-04-2008, 07:13 PM
dreamtheatre's Avatar
Quoted: 54 Post(s)
Liked: 37
CHEERS
I will be once I get the screen up this week. Am I to understand that we should not set the source at 720p, instead at 1080p, and let the HD65 do the scaling? That was what I intended to do.
However, for DVD, I use an OPPO 980H; should I set that player at 720p or 1080p for best results?
Jim
LG 65EF9500 OLED Display
Oppo BDP-203,Schiit Bifrost Multibit DAC, MF V-LINK 192
Parasound P5, Marantz SR-6010, EAD PM 1000 and PM 500 amps
NHT 2.5i (2), NHT AC-1 (1), NHT 1.5 (2), PSB XA (4)
Outlaw Ultra X12 and LFM-1 EX subwoofers
dreamtheatre is offline
Old 05-04-2008, 07:39 PM
leakwoon's Avatar
JIM,
my sammy DVDP just capable of 1080i so i let it at 1080i
leakwoon is offline
Old 05-04-2008, 07:43 PM
Quoted: 54 Post(s)
Liked: 37
JIM,
I will probably leave mine at 1080i, too, as my RPTV (the screen will drop down in front of it) will only accept 1080i (first generation SXRD). I will play around with it, and see what's best.
Jim
Old 05-04-2008, 08:13 PM
leakwoon's Avatar
should the DVDP to be set at YCrCb4:4:4 or 4:2:2 ?
leakwoon is offline
Old 05-04-2008, 08:23 PM
Quoted: 16 Post(s)
From what I understand it is best to send the projector highest signal possible and let the projector do the scalling unless you can send it native 720p.
Old 05-05-2008, 08:47 AM
leakwoon's Avatar
My HD65 vis PS3 (HDMI) on blu-ray-ing setting :
Room Condition: almost 80-90% dark
PS3:
HDMI:1080p24
superwhite : on
RGB : limited
Video: YCrCb
HD65:
Cinema
Contract : -4
Brightness : -5
sharpness: 0
Degamma : Video
BC: 1
TV: 1
AI: 0
Temp: Warm
Colour Space: AUTO
ADVANCE:
RG:0
GG:0
BG:4
RB:0
GB:-1
BB:-1
all feedback & welcome...CHEERS
leakwoon is offline
Old 05-05-2008, 08:52 AM
Quoted: 54 Post(s)
Liked: 37
Meaning you would need an HTPC? Or is there another way to do 1:1 pixel mapping?
Jim
Old 05-05-2008, 12:58 PM
Hi Forum Partners
Hooked Up My Hd 65 To Magnavox Hard Drive / Recorder With A S-video Cable But Got No Colour Picture Only B/w.
Now I Have Satellite Hooked To Recorder With S-video Cable Then From Output Of Recorder I Got Another S-video Cable Into The Hd 65.
Using Ordinary Cables Red/ White / Yellow I Got Colour.
What Is Wrong With S-video Hook Up Please.
Thanks In Advance
Ron
Old 05-05-2008, 03:08 PM
Quoted: 16 Post(s)
Jim
Any PC with a good graphics card can do this. If you send the projector a 1280x720 signal at 60Hz from any source the projector will map this pixel per pixel as this is the native resolution of the projector, therefore no scalling and no picture artifacts in the process. Mind you there are very expensive scallers out there that do a very fine job.
Old 05-05-2008, 03:10 PM
Quoted: 16 Post(s)
Hi Forum Partners
Thanks In Advance
Ron
Try different Svideo cables? Run cable from satellite directly to the projector and bypass the Recorder?
Optoma Hd65 720p Dlp Home Theater Projector
