Optoma HD65 Review & Screenshots - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 2885 Old 12-21-2007, 12:34 PM
parimal's Avatar
Guys. I got this projector yesterday and have been trying to configure it. Here is my setup
DVD - Philips DVP5982/37 upconverting DVD player
Projector- Optoma HD65
Connectivity - HDMI to HDMI
The problem I am having is that the projector does not lock in to the DVD's resolution. When I connect, it identifies the resolution e.g. 720p at 60HZ and then when it tries to lock ( screen goes blank for a second) it cant and then it projector goes back into search mode, identifies the resolution again and this goes on in a loop. It only plays when its at 480p. I tried various combinations but to no avail. I upgraded the firmware on the DVD player.
Wondering if anyone has any idea on what may be causing this problem ?
Parimal
parimal is offline
post #92 of 2885 Old 12-22-2007, 12:12 PM - Thread Starter
guitarman's Avatar
Quoted: 13 Post(s)
First set auto lock on in the projectors menu. Then you hit the direct button only on your remote. Looking to settle on Digital/RGB keep hitting the button till you see that on the screen. Have the projector going first before you turn on the DVD player, for the proper hand shake.
good luck
Tom/guitarman
VideoDementia
Are you twisted also?
http://www.videodementia.com/sales/TomWithWires.jpg
guitarman is offline
post #93 of 2885 Old 12-22-2007, 09:15 PM
parimal's Avatar
I have 480p and 576p working. As soon as I go to 720p, its okay when its at the setup screen but as soon as a DVD starts playing, the projector goes back in the searching , locking and searching blue screen loop.
Also is there a menu option to go into Eco mode or Brite mode. I thought I choose bright mode at one point and now I find the fan to be too loud. For some reason I cant find the option to go back into eco mode.
Thanks again for you help
parimal is offline
post #94 of 2885 Old 12-24-2007, 07:26 PM - Thread Starter
guitarman's Avatar
Quoted: 13 Post(s)
Undo AI to use econo mode. Try another DVD and cable setup up if you can.
Tom/guitarman
VideoDementia
post #95 of 2885 Old 12-28-2007, 02:59 PM
pedg's Avatar
Have an HD65 and a 5980 philips upscaling DVD player and also having problems getting the HDMI connection to work. Question is which is the end causing the problem?
pedg is offline
post #96 of 2885 Old 12-28-2007, 07:21 PM
cheeks80's Avatar
Does the problem happen with a component connection too?
cheeks80 is offline
post #97 of 2885 Old 12-29-2007, 04:42 PM - Thread Starter
guitarman's Avatar
Quoted: 13 Post(s)
The one I had I used a Tosh HD player and a 25' HDMI cable, never a problem. Run tests with a shorter cable, or try different resolutions from the player.
Tom/guitarman
VideoDementia
post #98 of 2885 Old 12-30-2007, 09:33 AM
Flanners's Avatar
How would this compare to my old Panny Ae500, was thinking of this as it is £416 over here in the UK or paying for the AX200 at £793 or a secondhand AE900 for £400.
Having never had a DLP I am not sur I would/can see rainbows?
Flanners is offline
post #99 of 2885 Old 12-30-2007, 01:14 PM - Thread Starter
guitarman's Avatar
Quoted: 13 Post(s)
I had the AX100 and tried it for the high brightness, the HD65 measured higher in brightness by a few hundred lumens, it has more basic contrast than the LCD. I did like the Panasonic though if rainbows are a problem it's worth a look. More money though
Tom/guitarman
VideoDementia
post #100 of 2885 Old 12-31-2007, 06:08 AM
pedg's Avatar
Component connection is fine for me. For the moment I am sorting my problem between HD65 and Philips by rearranging what connection is used for which so as to free up the component cables for the DVD player (have cable box, dvd, PC and Wii using different connections)
pedg is offline
post #101 of 2885 Old 01-01-2008, 06:25 AM
Digi247's Avatar
Hi Guys
Have a problem here in the UK and was hoping someone could help i got the HD65 and the Toshiba HD EP35 here in the UK and have just purchased the Onkyo 875 with latest firmware. Now heres the problem and i have tried several solutions and none work everytime i turn on the HD65 signal coming from 875 with HDMI the 875 throws a wobbly and will not see my HD EP35 or the 875.
Funny thing is itried the 875 and EP35 on my Pionner 507 and it worked no problem, Tried once again on the Optoma Hd65 and it wont work, If i connect the Tosh HD EP35 directly to the Optoma HD65 it locks onto the picture straight away.
Anyone with the same setup have a solution at all
Digi247 is offline
post #102 of 2885 Old 01-02-2008, 10:09 AM
cheeks80's Avatar
I plan to connect my HD65 to PC. Now i am confused whether to go for the Component or HDMI.
http://www.newegg.com/Product/ShowIm...E3R+Video+Card
The main concern here is the graphics card has a component cable off the s-video port. How good will be compared to the hdmi dongle off the dvi port?
I plan to use the PC for gaming and movies.
Please help.
Ramesh R
cheeks80 is offline
post #103 of 2885 Old 01-02-2008, 10:27 PM
parimal's Avatar
guys.. i got the PS3 and connected using the same HDMI cable which i thought was giving me problems with the philips 5982. everything works like a charm so i think the problem was with the dvd player.
Cheers!
parimal is offline
post #104 of 2885 Old 01-03-2008, 12:06 AM - Thread Starter
guitarman's Avatar
Quoted: 13 Post(s)
Yeah this device vs HDMI vs cable is frustrating. Right just keep searching for what will work is all we can do. Personally I'm not all the peachy keen on the HDMI program. But once we find a way to make it work all is bliss.
Tom/guitarman
VideoDementia
post #105 of 2885 Old 01-04-2008, 05:07 AM
speedtriplex's Avatar
Hi there,
I placed an order on new year's eve on what I thought was the best deal on the net, only to find very bad ratings on resellerratings.com for the website which scared me away and I cancelled a day later.
I'm talking about electotronics, any of you bought your HD65 or anything from there? The price is too good to pass over, but all the classic features of a "dubious website" fit it well. Any help or info would be appreciated.
Cheers.
EDIT:I'm sorry I'm not sure if I'm breaking any forum rules here, but if I am, MOD delete my post.
speedtriplex is offline
post #106 of 2885 Old 01-05-2008, 12:47 PM - Thread Starter
guitarman's Avatar
Quoted: 13 Post(s)
I'll use a credit card to be protected when buying on the web. If the deals good it's worth a shot.
This is a pretty cool little projector, very high power for such a little size. Flush mounted on a white ceiling you would hardly notice it.
Tom/guitarman
VideoDementia
post #107 of 2885 Old 01-05-2008, 01:46 PM
Thanks Tom for your feedback
Hmmm, yeah you're right about the CC being safe as you can always dispute the charges with the CC company
Maybe I'll give it a go and hope for the best
post #108 of 2885 Old 01-05-2008, 02:04 PM
Originally Posted by p@55w0rd View Post
Interesting thing though... It looks like there is a tripod mount screw located in the center of the three ceiling mount screw holes. No mention of it's purpose in the manual. This thing is really small!
Yeah I want to know the if there is really a tripod mount screw on the HD65?... Any owners please?
post #109 of 2885 Old 01-07-2008, 05:28 AM
anirbana's Avatar
Can anyone tell me what lamp module it uses? is the same as HD70 or a different one.
Somehow I am not able to find this info. Appreciate if someone can update...
anirbana is offline
post #110 of 2885 Old 01-07-2008, 02:19 PM
heiwi's Avatar
Deciding right now between the HD7100 and the HD65 - I like the short throw of the 7100 and the great picture. Is there picture wise a significat difference between the old technology of the 71000 compared to the 65? Is it also more reliable?
Any thoughts?
heiwi is offline
post #111 of 2885 Old 01-09-2008, 10:40 AM
heiwi's Avatar
Originally Posted by jherring69 View Post
Thanks for the info guys. I plan on getting this as soon as it releases in Canada. The HD 70 is still over a grand up here. Plus no rebates.
If this costs about the same or even a bit more it should be a great deal. I am looking forward to trying out the Superwide feature. I'll gladly give up a small bit of picture info on the sides in order to fill my screen.
Any confirmed dates for when the HD65 will begin shipping?
Jason
the hd65 is already here in canada - under the name of hd640 at costco warehouses - not on online shopping costco - below $1000 with screen
heiwi is offline
post #112 of 2885 Old 01-09-2008, 03:06 PM
swynjones's Avatar
can anyone comment on the fan noise of this projector?
some of the literature states 34 db in economy mode and 35 db in standard mode. Have also read that is it 29 db in economy and 30 in standard.
I am looking to upgrade from the Infocus SP4805 which I find quite noisy especially during quiet scenes. thanks.
swynjones is offline
post #113 of 2885 Old 01-09-2008, 03:34 PM - Thread Starter
guitarman's Avatar
Quoted: 13 Post(s)
Any thoughts?
The HD7100 is DC3 and does a great picture, it's been buggy and drove some owners crazy. The HD65 is a different animal, it's main thing is how bright it is. The fan sound is low in econo, in high lamp it comes close to the 4805 which I have heard.
Tom/guitarman
VideoDementia
post #114 of 2885 Old 01-09-2008, 04:26 PM
swynjones's Avatar
thanks Tom. picture quality wise would you say that the hd65 is a noticeable step up from the infocus 4805? I'm not too bothered about the advantage of the HD65 brightness as my cinema room is pretty dark and most use is for watching films in the evening anyway.
post #115 of 2885 Old 01-09-2008, 07:23 PM
Bsims2719's Avatar
Quoted: 26 Post(s)
I read one review or maybe it was on the Optoma website indicating that sending the HD65 a 1080p/24 signal resulted in a much cleaner picture. Is this true and would you list this as a significant advantage over the other low cost 720p projectors that can't accept this signal.
thanks
Bsims2719 is offline
post #116 of 2885 Old 01-10-2008, 06:15 AM
heiwi's Avatar
But isn't a DC2 with much newer technology better then a 3 year old DC3? I heard the fan in econo and it whispers compared to a HD7100 in econo. The size of this machine is unbelievable - it practially disappears in a room.
heiwi is offline
post #117 of 2885 Old 01-10-2008, 11:41 AM - Thread Starter
guitarman's Avatar
Quoted: 13 Post(s)
DC3 is still a more expensive chip, a larger chip also which means more light. On for a dark theater room which one the HD7100 or HD65? I'd have to go with the HD7100 and pray there are no bugs.
The HD65 with its new brilliant color 2 and special RGBCYM color wheel produces a super bright and and lets say jovial color array. Many will like this kind of image and blasting colors.
Tom/guitarman
VideoDementia
post #118 of 2885 Old 01-10-2008, 11:56 AM
heiwi's Avatar
Thanks for your advice.
I will have the opportunity to see both of them next to each other on the weekend. Will be great to see the differnce and I will report back here.
heiwi is offline
post #119 of 2885 Old 01-10-2008, 03:44 PM
mindgam3's Avatar
Thanks, I really really want to read more about this projector before buying it. How does it compare to the HD72?
mindgam3 is offline
post #120 of 2885 Old 01-10-2008, 04:47 PM
Yeah I'll second that!
How does it compare to the Acer PH530?
Also, how big a picture can the HD65 handle considering it's 1600 lumens?
This will be a major deciding factor for me as I'm seriously thinking of going 12' wide in 2.40:1 CIH setup with this projector
Optoma Hd65 720p Dlp Home Theater Projector
