Optoma HD65 Review & Screenshots - Page 97 - AVS Forum | Home Theater Discussions And Reviews
post #2881 of 2885 Old 05-08-2014, 09:54 AM
leproos's Avatar
Been using the HD65 for about 5-6 years now. I still love it. Recently i have a problem with it. My PC wont recognize the beamer anymore. I use this for watching movies so its a big problem for me. The xbox360 and TV reciever still work fine. I already did a clean Win7 install and i even tried a laptop from a friend with windows 8 on it. I tried 3 different hdmi cables. The result is the same.. It just wont pick up signal from my PC but xbox and TV reciever work fine. Can someone help? I have no ideas left what to do. It all worked fine for 5 years. And all 3 sources work fine on my LCD TV.
leproos is offline
post #2882 of 2885 Old 05-10-2014, 06:19 AM
Stanton's Avatar
Quoted: 1550 Post(s)
Liked: 798
Have you tried connecting the PC's HDMI to something else? Seems to me that it's NOT the HD65; could be a fried HDMI output on the PC.
Yamaha RX-A2050 AVR (5.0.2)
(4) Polk Monitor 10B's (R/L F/R), (2) Polk Monitor 4's (TM), Polk CS300 center channel
Analog: B&O TX2 Turntable, Nakamichi Cassette Deck 1
Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-Ray
LG 65EF9500 4K OLED
Stanton is online now
post #2883 of 2885 Old 05-10-2014, 06:43 AM
Ftoast's Avatar
Quoted: 2249 Post(s)
Liked: 708
Does the computer still seem to recognize when it's plugged in to the optoma, can it show a list of usable resolutions refresh rates? ..assuming your PC has two usable video outputs..
Easy $25 DIY black (or any color) ALR paint +$40-$50sprayer screen mix smooth/clean and very easy to learn spraying with little/no mess.
Simple $25-40 DIY black/dark-grey ambient-light rejecting screen, grab two things from a local store..mix..roll..done.
Quick <$250 dedicated black-fabric theater room "A store that sells blinds can help your picture more than a store that sells projectors many times." -bud16415
Ftoast is online now
post #2884 of 2885 Old 05-15-2014, 01:48 AM
leproos's Avatar
Thanks, after removing the graphic card (ATI) i found out that my onboard GPU (Nvidia) also has a HDMI output :D It worked instantly. BUT i can get the resolution higher than 1024x768 :(
In my old setting (when it worked) WIN7 even recognized the beamer and it said 'optoma hd65' in the resolution settings. It was on 720p for years and i could even set it on 1080p. Now its says 'non pnp screen'.
Is it possible to get 720P with my onboard GPU with the beamer? And how? On my LCD TV its on 1080P so i guess its possible.
leproos is offline
post #2885 of 2885 Old 09-09-2014, 07:45 AM
leproos's Avatar
Still not working I want to download the 3d upgrade but i cant find it anymore.. Anyone has a good link? Maybe the update will give me picture
leproos is offline
Optoma Hd65 720p Dlp Home Theater Projector
